[Geoserver-devel] WFS exception reports call for improvement
I'd like to suggest better/more detailed error reports when WFS
transactions fails.
My use case is that I've put a constraint in PostGIS st_isvalid(geom)
= true which means that certain updates or inserts will be rejected.
I'd like to be able to communicate to users what the cause of the
error is, but from Geoserver (1.7.3) the below exceptionreport is as
detailed information I can get - unless I'm missing something?
My analysis of the current code is that the WFSException is thrown in
UpdateElementHandler.java line 239 and then put togheter into a
response in Transaction.java but the cause of the WFSException is only
used for logging not the response. Wouldn't it be nice if the
exception that caused the WFSException would be output into the
response in some way (the first cause, at least)
I'd be happy to contribute improvement, if I can and if this is
something that you folks can agree is needed :slight_smile:
<ows:ExceptionReport version="1.0.0"
  xsi:schemaLocation="http://www.opengis.net/ows
http://10.250.250.2:80/geoserver/schemas/ows/1.0.0/owsExceptionReport
.xsd"
  xmlns:xsi="http://www.w3.org/2001/XMLSchema-instance&quot;
xmlns:ows="http://www.opengis.net/ows&quot;&gt;
  <ows:Exception exceptionCode="InvalidParameterValue">
    <ows:ExceptionText>update error</ows:ExceptionText>
    <ows:ExceptionText>Details:</ows:ExceptionText>
    <ows:ExceptionText>org.geoserver.wfs.WFSException:
      update error at
      org.geoserver.wfs.response.v1_1_0.TransactionResponse.write(TransactionResponse.java:49)
      at
      org.geoserver.ows.Dispatcher.response(Dispatcher.java:711)
      at
      org.geoserver.ows.Dispatcher.handleRequestInternal(Dispatcher.java:215)
      at
      org.springframework.web.servlet.mvc.AbstractController.handleRequest(AbstractController.java:153
      at
      org.springframework.web.servlet.mvc.SimpleControllerHandlerAdapter.handle(SimpleControllerHandlerAdapter
.java:48)
      at
      org.springframework.web.servlet.DispatcherServlet.doDispatch(DispatcherServlet.java:875)
      at
      org.springframework.web.servlet.DispatcherServlet.doService(DispatcherServlet.java:809)
      at
      org.springframework.web.servlet.FrameworkServlet.processRequest(FrameworkServlet.java:571)
      at
      org.springframework.web.servlet.FrameworkServlet.doPost(FrameworkServlet.java:511)
      at
      javax.servlet.http.HttpServlet.service(HttpServlet.java:637)
      at
      javax.servlet.http.HttpServlet.service(HttpServlet.java:717)
      at
      org.apache.catalina.core.ApplicationFilterChain.internalDoFilter(ApplicationFilterChain.java:290
      at
      org.apache.catalina.core.ApplicationFilterChain.doFilter(ApplicationFilterChain.java:206)
      at
      org.vfny.geoserver.filters.SetCharacterEncodingFilter.doFilter(SetCharacterEncodingFilter.java
:108)
      at
      org.apache.catalina.core.ApplicationFilterChain.internalDoFilter(ApplicationFilterChain.java:235
      at
      at
      org.acegisecurity.util.FilterChainProxy$VirtualFilterChain.doFilter(FilterChainProxy.java:264)
      at
      org.acegisecurity.intercept.web.FilterSecurityInterceptor.invoke(FilterSecurityInterceptor.java
:107)
      at
      org.acegisecurity.intercept.web.FilterSecurityInterceptor.doFilter(FilterSecurityInterceptor.java
:72)
      at
      org.acegisecurity.util.FilterChainProxy$VirtualFilterChain.doFilter(FilterChainProxy.java:274)
      at
      org.acegisecurity.ui.ExceptionTranslationFilter.doFilter(ExceptionTranslationFilter.java:110)
      at
      at
      org.acegisecurity.providers.anonymous.AnonymousProcessingFilter.doFilter(AnonymousProcessingFilter
.java:125)
      at
      at
      org.acegisecurity.ui.basicauth.BasicProcessingFilter.doFilter(BasicProcessingFilter.java:178)
      at
      at
      org.acegisecurity.context.HttpSessionContextIntegrationFilter.doFilter(HttpSessionContextIntegrationFilter
.java:229)
      at
      at
      org.acegisecurity.util.FilterChainProxy.doFilter(FilterChainProxy.java:148)
      at
      org.acegisecurity.util.FilterToBeanProxy.doFilter(FilterToBeanProxy.java:98)
      at
      at
      at
      org.geoserver.filters.LoggingFilter.doFilter(LoggingFilter.java:73)
      at
      at
      at
      org.geoserver.filters.ReverseProxyFilter.doFilter(ReverseProxyFilter.java:163)
      at
      at
      at
      org.geoserver.filters.GZIPFilter.doFilter(GZIPFilter.java:41)
      at
      at
      at
      org.apache.catalina.core.StandardWrapperValve.invoke(StandardWrapperValve.java:233)
      at
      org.apache.catalina.core.StandardContextValve.invoke(StandardContextValve.java:191)
      at
      org.apache.catalina.core.StandardHostValve.invoke(StandardHostValve.java:128)
      at
      org.apache.catalina.valves.ErrorReportValve.invoke(ErrorReportValve.java:102)
      at
      org.apache.catalina.core.StandardEngineValve.invoke(StandardEngineValve.java:109)
      at
      org.apache.catalina.connector.CoyoteAdapter.service(CoyoteAdapter.java:286)
      at
      org.apache.jk.server.JkCoyoteHandler.invoke(JkCoyoteHandler.java:190)
      at
      org.apache.jk.common.HandlerRequest.invoke(HandlerRequest.java:283)
      at
      org.apache.jk.common.ChannelSocket.invoke(ChannelSocket.java:767)
      at
      org.apache.jk.common.ChannelSocket.processConnection(ChannelSocket.java:697)
      at
      org.apache.jk.common.ChannelSocket$SocketConnection.runIt(ChannelSocket.java:889)
      at
      org.apache.tomcat.util.threads.ThreadPool$ControlRunnable.run(ThreadPool.java:690)
      at java.lang.Thread.run(Thread.java:619) </ows:ExceptionText>
  </ows:Exception>
</ows:ExceptionReport>
Hmmm... this one is sort of tough, dealing with atomic transactions means we have catch the exception and track it, rather than deal with it directly. And tracking it means that we only get the message from teh exception, which in this case is not descriptive at all.
We could modify ActionType (which is the class that holds on to the exception message) to hold a reference to the actual exception itself. Then it could report the entire stack trace.
transactions fails.
.xsd"
      update error at
      at
      at
      at
      at
.java:48)
      at
      at
      at
      at
      at
      at
      at
      at
      at
:108)
      at
      at
      at
      at
:107)
      at
:72)
      at
      at
      at
      at
.java:125)
      at
      at
      at
      at
.java:229)
      at
      at
      at
      at
      at
      at
      at
      at
      at
      at
      at
      at
      at
      at
      at
      at
      at
      at
      at
      at
      at
      at
      at
      at
      at
      at
  </ows:Exception>
OpenSolaris 2009.06 is a cutting edge operating system for enterprises looking to deploy the next generation of Solaris that includes the latest innovations from Sun and the OpenSource community. Download a copy and enjoy capabilities such as Networking, Storage and Virtualization. Go to: http://p.sf.net/sfu/opensolaris-get
Geoserver-devel mailing list
Justin Deoliveira
OpenGeo - http://opengeo.org
