On Thu, Sep 25, 2014 at 1:32 PM, Alex van den Hoogen | Geodan <
alex.van.den.hoogen@anonymised.com> wrote:
Yesterday I issued a pull request for issue GEOS-6688 and it works now
with the test I provided this morning. However when issuing this query the
returned file is a multipart .eml file as stated in
"org/geoserver/wcs2_0/response/WCS20GetCoverageMultipartResponse.java:141",
but this file is 'unusable'.
However using the store=true parameter, the file will be stored as the
requested image/file format and it is downloadable and usable in GIS
software.
If there are no objections I propose to request that GeoServer returns the
appropiate image/file format that is requested with the GetCoverage
request, like with the store=true parameter. But is there any reason to
stick with .eml for this request?
Spec conformance would be one
The WCS 1.1 specification _demands_ that a mime multipart is returned, so
that cannot be changed, and store=true is the only way to get back a
sane-ish response (a xml that links to the actual file to be downloaded).
However the WCS 2.0 does not unless you ask for one, can we see the full
request you made?
Ing. Andrea Aime
@geowolf
Technical Lead
Via Poggio alle Viti 1187
mob: +39 339 8844549
