Near as I can tell:
- locks are held in a static repository HashMap in TypeRepository
- the Locks are held by TypeRepository.InternalLock which track which
Features are under their control.
- Datasource transactions are supported, using commit and rollback
Any suggestions on how this work could proceed would be appreciated.
Some quick ideas I had were to approach the geotools team about creating
a TransactionDatasource interface that contained explicit feature
locking methods. Creating a postgis implementation of this, and adding
a series of checks and calls from the TypeRepository.InternalLock
implementation. While this smacks of wearing a belt and braces it would
allow the use of GeoServer with PostGIS and pave the way for similar
OracleSpatial support.
I still have not looked into the Datasource management strategy for
GeoServer located in (getTransactionDataSource()?) and would be hard
pressed to reattach Locked operations to their correct Datasource.
Thinking about this more and more I do not envy your task at all. There
are a lot of pitfalls, and tons of special cases to think through. I
think I'd pretty much blocked locking from my mind, as the first iteration
was annoying to implement. It definitely could use beefing up, as doing
the locking just in java is not ideal. But there are a ton of little
things that you need to get exactly right, which get harder when you start
doing locking on the backend as well.
As I think about it more I think that you're probably going to have to
more or less completely redo how geotools jdbc datasources handle their
database connections. I think first I'll give a base description of how
geoserver handles locks/connections, to make sure we're on the same page,
though you've probably figured most of this out. I'll highlight the
tricky things, and the things we don't implement very well right now, and
then detail how I think we should perhaps proceed.
First off, database connections. Each postgis datasource is created using
a java.sql.Connection object, which is generated from
PostgisConnectionFactory (which implements java.sql.Datasource for reasons
that were never clear to me, and looking just now at the
java.sql.Datasource interface it seems to make less sense, as that
interface should be implemented by the driver, which it is for postgres -
PostgresqlDataSource.java, in their source tree, but we actually can't
just use that, as it doesn't allow you to set the charset, which is
something our users need...but I digress). GeoServer currently makes use
of the geotools DataSourceFinder, which will find the appropriate
DataSourceFactory based on the parameters. The postgis factory is called
PostgisDataSourceFactory, and it creates a PostgisConnectionFactory, and
uses that connection to make the PostgisDataSource.
The DataSourceFinder is quite nice because it allows us to add new
geotools datasources with no additional work if they are implemented
correctly. No code would need to change, the only thing required for a
user to use the new datasource is for them to fill out their info.xml
correctly - they just need to put the right geotools params in the
DatasourceParams element, and DataSourceFinder does the rest of the work.
Where this falls short is connections, since a new connection is made each
time the DataSourceFinder is used. A geotools connection pooling object
for all jdbc datasources to share could help out here.
GeoServer currently gets around that by holding on to a datasource for
each featureType. Well, actually 2 datasources if transactions are being
used. TypeInfo supplies the datasources with getDataSource and
getTransactionDatasource, both of which lazily initialize DSes with the
DataSourceFinder - the params are stored in the TypeInfo, read in with
FeatureType (yes, should probably be renamed to avoid conflict with
geotools). The reason for the two different datasources is that we don't
want a getFeature that comes in while a transaction is waiting to complete
to return its view. This is because the transaction may rollback if a
later operation (each transaction request can have more than one insert,
update and delete) fails. If a getFeature is on the same connection then
it would see the database from the view of an altered but not yet
committed transaction.
Of course, having all transactions on the same connection is bad, because
two different transactions may access it at the same time. I didn't worry
too much about this, since it's a fairly rare case - two transactions need
to come in at the same time, and need to be operating on the same
features, and it would only mess things up in cases when locking was not
used. If one of the transactions had used the lockFeatures operation,
then only one would have the lockId, and thus it would be the only one
allowed to operate - the other transaction wouldn't be successful until
the lock was released.
Another shortcoming of the current implementation is that on shutdown
all the open connections fail ungracefully - they don't call
connection.close(). I tried for a bit to put in finalize() to
postgis datasource, but I never got it working, I think I didn't
successfully get rid of all references to it or something.
As for locking - it's a lot easier when you don't have to deal with
connections. And it still was a damn bitch to implement. The simple case
is one lock on one datasource. And this would be easy to implement with a
lock interface - either the features are locked, or they're not and can be
operated on. But you also have to add different locks operating on one
datasource - lockid 45 could hold features rail.1-30, and lockid 55 could
hold rail.31-70. And 55 could come in and request rail.20-70, but with
release action SOME, and it has to check what's already locked and grab
what it can. And when a transaction with lockid 55 comes in with
releaseAction=ALL then 55 must know which ones it holds. But it doesn't
stop there, you also have to deal with one (or more) lock operating on
more than one datasource. This means lock 55 can also be locking road.23,
and if it a transaction with releaseAction=ALL comes and updates rail.43,
then road.55 also needs to be released after the transaction is complete.
The current implementation successfully deals with all of these -
internalLocks know all the features they lock, and thus can release them
all. The lockedFeatures map allows quick look-up to see if a given
feature is locked, as lockedFeatures.contains(featureId) just needs to be
called. Every lock or transaction must first get all the features that it
is trying to operate on from the datasource (just gets the fids, to save
overhead of constructing geometries) - the hope with doing stuff in the db
is that we can get rid of this huge overhead, everything checking that
is, though I haven't thought through a good way yet (that's where you come
in, right? :). If one of those features that it is about to operate on is
locked then lockedFeatures hashes the lockId, and compares to see if the
transaction holds the same lockId, and if it does it is allowed to
proceed. The internalLock also has a timer to manage the expiry, and can
reset it's timer if releaseAction some comes through (spec says expiries
are reset in that case).
I've been thinking through what you want to do, and it's looking like we
will probably always need both the belt and braces. I'd still like to
move the code to geotools eventually, but even there I think we will still
need a lock manager, and some sort of internal lock that can keep track of
which datasources are locked by the same lockId. It'll manage the
expiries as well.
I'm having trouble figuring out how the postgis datasource will be able to
handle locking. I think the way to start out is for each internalLock to
hold pointers to the datasources that they affect, then they can call
unlock() when they need to. But I think even for unlock we need to redo
postgis so it deals with connections better, if we are going to do locking
in the database. This is where my knowledge runs thin, and you are
obviously in a better place to figure things out, with all the postgis
team right there. But as far as I can tell, the only way to get row level
locking in postgis (from java) is to setAutoCommit false, and then call
select where (Filter) for update. I guess you could use the same
unpacking mechanism as getFeatures(), and then also lock the fids. But to
keep the lock, you have to hold on to that connection. Of course,
geoserver holds on to that connection, so things are fine from that end.
But from the geotools side, the lock will be lost as soon as someone calls
commit(). Oh, but this extends to geoserver as well, as soon as you get
into two locks on the same datasource, since they will be on the same
connection, and when one calls commit the other is lost. Or am I thinking
about this wrong? Is there another way to acquire a lock?
My initial thoughts are that postgis datasource is going to have to be
reimplemented with better connection management, and it will have to have
its own internalLocks, each of which will have a connection to the
database, where its locks are open. And then it'd also make sense to have
a lockedFeatures map, so that an isLocked operation doesn't have to query
each connection to see if it holds a given row. But I guess this will
make locking with lockAction some a bit better, since creating the
featuresLocked and featuresNotLocked lists will be easier. But each
datasource internal lock - lets call them subInternalLocks, will in turn
have to have a superLock - like the InternalLock of our current
TypeRepository. Of course the only information that would be useful in
the subInternalLock is the Connection that it holds, as my first intuition
is that its other information will be lists of features locked, which may
function better in the superLock/InternalLock. But either way, postgis
will need to be able to handle its connections better, so that
transactions with lockIds can operate on the connections that hold the
locks.
Another thing I'm having trouble with figuring out in postgis is that I
can't seem to get Locking to fail if it can't get what it wants. Like if
something else is already locking something I try to lock, then the
connection that I'm on just sits there and waits until it clears. But for
wfs locking and updating, we need to know that it can't acquire the lock.
I guess the alternative would be a way to query postgis to see what rows
are locked, but I couldn't figure out how to do that either. And then
ideally we could figure out which connection actually held that lock, but
I'm not sure that's possible.
I think an initial interface extension might be able to get by with
something like:
lock(Filter filter, Connection conn);
unlock(Set fids, Connection conn);
transaction(TransactionRequest trans, Connection conn);
This way you could generate connections in GeoServer, and perhaps manage
them there. The TransactionRequest would be just like the wfs transaction
- with lockid, and one or more update/delete/insert. The transaction
operation would use the exisiting interface -
setAutoCommit(false);
add/remove/modify for each operation in the request,
commit() or rollback() depending if they go through.
Of course you'd have to do something to get the add/remove/modify to use
the same connection as the one where the lock is. Not sure if this is the
right way, but if it worked then you could start to think through how
PostgisDataSource uses/generates connections - it should perhaps take
PostgisConnectionFactory in its constructor or something.
Ok, so now I'm rambling into confusion, as I'd need to actually start to
implement some of this stuff to see how it goes. But I'd say start with
the simple case - one datasource with one lock, and then expand from
there. I think it may get nasty fast. There may be much better solutions
out there, that I just can't think through right now, as I've put lots of
thought into the way that I did it, so extensions seem to stem from that.
But I'll think through other options. An initial thought that hit me
while writing this email was something like a LockedFeatureCollection,
that would have a datasource backend, so that it could call lock
operations as needed. Perhaps lock management could take place using it.
That's all I have for now. I hope this email wasn't too incoherent and
hard to understand - feel free to ask questions about any parts of it.
good luck,
Chris
