[Geoserver-devel] WFS-NG Stored Query parameter configuration UI
I’m now looking into exposing the stored query parameter configuration to the administrator configuring the layer derived from a stored query.
To recap: this configuration relates to how the stored query parameters are constructed from viewparams in a request and a context derived from the query filter (access to query filter bounds, etc).
First of all we should decide where to put the UI. To me there are two logical options:
  1. In the layer configuration “Data” tab under feature type details
  2. As a new tab in the layer configuration view
I’d vote for 1) because this is practically mandatory configuration. Without this configuration, the layer would require clients to provide all required viewparams to get any meaningful data out of the layer.
The UI would list all parameters supported by the stored query and offer a choice for each one. The choice would be either: ‘No default’, ‘Static value’, ‘Expression’. Selecting either of the last two options would display an input box or textarea respectively for the user to fill in the static value or expression value.
Each parameter would also be accompanied by a checkbox to configure whether the user may override the configured value via a viewparams option or not.
Any thoughts?
Sampo
Sampo Savolainen
R&D Director, Spatineo Oy
sampo.savolainen@anonymised.com
+358-407555649
Linnankoskenkatu 16 A 17, 00250 Helsinki, Finland
www.spatineo.com, twitter.com/#!/spatineo
www.linkedin.com/company/spatineo-inc
This message may contain privileged and/or confidential information. If you
have received this e-mail in error or are not the intended recipient, you
may not use, copy, disseminate, or distribute it; do not open any
attachments, delete it immediately from your system and notify the sender
promptly by e-mail that you have done so.
I may be late to the conversation, I would expect it to be handled in a consistent fashion to the sql view (http://docs.geoserver.org/stable/en/user/data/database/sqlview.html) as these are both “data binding” problems.
Jody Garnett
On Fri, May 30, 2014 at 5:37 PM, Sampo Savolainen <sampo.savolainen@anonymised.com> wrote:
Any thoughts?
Sampo
Sampo Savolainen
+358-407555649
Time is money. Stop wasting it! Get your web API in 5 minutes.
www.restlet.com/download
http://p.sf.net/sfu/restlet
Geoserver-devel mailing list
Hi Jody,
Thanks for the tip. It does seem that model could work well in this case as well. However there lies a nasty problem here. The SQL View code relies in many places on the DataStore to be an instance of JDBCDataStore. Like we discussed earlier with Andrea, this is method is slightly dubious because a DataStore might have to be wrapped in a retyping DataStore.
Retyping causes headaches with WFS-NG as that happens almost always. As I’ve understood, retyping is required when colons are used in the localPart of a feature name. Stored query id’s will contain colons (the mandatory stored query in WFS 2.0.0 is “urn:ogc:def:query:OGC-WFS::GetFeatureById”). Because of the retyping, it’s difficult to detect which features are backed by WFS-NG. But even more troubling is the fact that I can’t access the underlying store in any sane way.
Andrea, you mentioned that you had a plan to refactor the parts affecting this. Is there any movement on this, or should I hack a “getUnderlyingDataStore()” into RetypingDataStore?
Sampo
On Fri, May 30, 2014 at 2:51 PM, Jody Garnett <jody.garnett@anonymised.com> wrote:
Sampo Savolainen
+358-407555649
Jody Garnett
Any thoughts?
Sampo
Sampo Savolainen
+358-407555649
Sambo I was referring to the user experience / workflow :slight_smile:
I know the SQL view code uses JDBC datastore, but if you could take your design queues - and even cut and paste some UI code - GeoServer will be that much more consistent and easy to use.
Jody Garnett
On Fri, May 30, 2014 at 10:26 PM, Sampo Savolainen <sampo.savolainen@anonymised.com> wrote:
Hi Jody,
Sampo
Sampo Savolainen
+358-407555649
Jody Garnett
Any thoughts?
Sampo
Sampo Savolainen
+358-407555649
Hi Jody,
Yeah. I knew you meant the UI, not the backend. I just pivoted fast to the issue at hand :slight_smile:
Sampo
On Fri, May 30, 2014 at 3:44 PM, Jody Garnett <jody.garnett@anonymised.com> wrote:
Sampo Savolainen
+358-407555649
Jody Garnett
Hi Jody,
Sampo
Sampo Savolainen
+358-407555649
Jody Garnett
Any thoughts?
Sampo
Sampo Savolainen
+358-407555649
On Fri, May 30, 2014 at 2:26 PM, Sampo Savolainen <
Hi Jody,
I've understood, retyping is required when colons are used in the localPart
of a feature name. Stored query id's will contain colons (the mandatory
stored query in WFS 2.0.0 is "urn:ogc:def:query:OGC-WFS::GetFeatureById").
Because of the retyping, it's difficult to detect which features are backed
by WFS-NG. But even more troubling is the fact that I can't access the
"getUnderlyingDataStore()" into RetypingDataStore?
No movement whatsoever, sorry. Hmm.. I'd probably roll a WrappingDataStore
interface, and have it be implemented by all wrappers,
or simply a generic Wrapper interface, like the java.sql.Wrapper one, but
without the SqlExceptions...
Meet us at GEO Business 2014! in London! Visit http://goo.gl/fES3aK
for more information.
Ing. Andrea Aime
@geowolf
Technical Lead
Via Poggio alle Viti 1187
mob: +39 339 8844549
