[Geoserver-devel] WFS-T Insert: Fids being returned in incorrect order
I was looking at the WFS-T response for Inserts (it’s a list of FIDs). The spec says these should be in the same order as the features in the request’s Insert elements.
However, I’m seeing these in a “strange” order. I think I’ve tracked it down to the DefaultFeatureCollection implementation. This stores the features in a SortedMap<String, SimpleFeature>, and the iterator just returns them in the text-natural-id-order (ie. “new0”, “new1”, “new11”, “new2”, “new3”,… – “new11” is in the wrong order). This messes up the order of the new fids for the inserted features.
Here’s it using the DefaultFeatureCollection;
https://github.com/geoserver/geoserver/blob/2.9.x/src/wfs/src/main/java/org/geoserver/wfs/InsertElementHandler.java#L98
and the passing it (incorrectly ordered) off to the underlying datastore;
https://github.com/geoserver/geoserver/blob/2.9.x/src/wfs/src/main/java/org/geoserver/wfs/InsertElementHandler.java#L189
Here’s the DefaultFeatureCollection implementation;
https://github.com/geotools/geotools/blob/master/modules/library/main/src/main/java/org/geotools/feature/DefaultFeatureCollection.java#L330
I’m surprised that no one’s seen this and there aren’t any test cases for it - am I seeing things?
Aside - does anyone know how to have WFS-NG preserve FIDs for inserts? I havent been able to figure out how set it to use idgen=UseExisting instead of idgen=GenerateNew?
Dave
Interesting, DefaultFeatureCollection has always used a TreeSet (to support fast fid lookup since I figured that was important when initially designing feature collection, my mistake).
There is a quick fix we could try using a ListFeatureCollection in this section of code, care must be taken to avoid duplicate Fids since it is only a wrapper.
ArrayList list = new ArrayList();
list.add( SimpleFeatureBuilder.build( TYPE, new Object[]{ wkt.read(“POINT(1,2)”), “name1”}, null) );
list.add( SimpleFeatureBuilder.build( TYPE, new Object[]{ wkt.read(“POINT(4,4)”), “name2”}, null) );
SimpleFeatureCollection collection = new ListFeatureCollection(TYPE,list);
For more background/code examples see docs.
On 20 March 2017 at 21:45, Dave Blasby <dblasby@anonymised.com> wrote:
Dave
Geoserver-devel mailing list
Geoserver-devel@anonymised.com.366…sourceforge.net
Jody Garnett
Hi, Jody,
I also refactored code using DefaultFeatureCollection to use ListFeatureCollection - so I expect this is a quick patch (wasn’t sure if it would cause issues). I will look at the test cases…
Dave
On Mon, Mar 20, 2017 at 10:02 PM, Jody Garnett <jody.garnett@anonymised.com> wrote:
Jody Garnett
Dave
Geoserver-devel@anonymised.comrge.net
Consider that this issue was not found by test cases, or cite tests even I assume you will be pretty well in the clear.
Can you or your team patch for wednesday? I am onto windows installer tomorrow.
On 20 March 2017 at 22:19, Dave Blasby <dblasby@anonymised.com> wrote:
Hi, Jody,
Dave
Jody Garnett
Jody Garnett
Dave
On Tue, Mar 21, 2017 at 5:45 AM, Dave Blasby <dblasby@anonymised.com>
I don't know what WFS-NG does, but mind one thing, this control over index
generation is available only in WFS 1.1, it was not there in WFS 1.0, it
got removed in WFS 2.0 (and I don't believe it got wide implementation in
WFS 1.1 either, even in GeoServer if memory serves me well it works only
for JDBC data sources with a non auto-generated primary key).
So... I would not try to rely on it too much unless you're sure about the
server and target store.
Ing. Andrea Aime
@geowolf
Technical Lead
Via di Montramito 3/A
mob: +39 339 8844549
Thanks!
On Mar 21, 2017 12:29 AM, “Andrea Aime” <andrea.aime@anonymised.com> wrote:
I don’t know what WFS-NG does, but mind one thing, this control over index generation is available only in WFS 1.1, it was not there in WFS 1.0, it got removed in WFS 2.0 (and I don’t believe it got wide implementation in WFS 1.1 either, even in GeoServer if memory serves me well it works only for JDBC data sources with a non auto-generated primary key).
So… I would not try to rely on it too much unless you’re sure about the server and target store.
Ing. Andrea Aime
@geowolf
Technical Lead
wrote:
I was looking at the WFS-T response for Inserts (it's a list of FIDs).
request's Insert elements.
I never heard of this requirement so I went and check, indeed all 3 spec
say so. However, it seems that at least the old
WFS CITE test we're running did not verify that.
So, you're not seeing things, but I believe you're the first one to care
about it enough to report the problem
Ing. Andrea Aime
@geowolf
Technical Lead
On mardi 21 mars 2017 09:24:13 CET Andrea Aime wrote:
On Tue, Mar 21, 2017 at 5:45 AM, Dave Blasby dblasby@anonymised.com
WFS CITE test we’re running did not verify that.
So, you’re not seeing things, but I believe you’re the first one to care
Well, getting out of order IDs would certainly mess up things in the QGIS WFS client when doing multiple inserts at once, especially if doing later updates of the features (the wrong feature would be modified on the server)
I’m surprised this wasn’t raised before, but I can see we have this logic :
/* Fix issue with GeoServer and shapefile feature stores when no real
feature id are returned but new0 returned instead of the featureId*/
Q_FOREACH ( const QString &v, idList )
if ( v.startsWith( “new” ) )
reloadData();
return true;
which makes that we don’t trust such Ids and have to re-issue a GetFeature request. But if the ids do not start with “new”, we would have the issue.
Even
Spatialys - Geospatial professional services
http://www.spatialys.com
On Tue, Mar 21, 2017 at 9:41 AM, Even Rouault <even.rouault@anonymised.com>
if ( v.startsWith( "new" ) )
reloadData();
return true;
Nope, this is another issue. With shapefiles our current code has no way to
know the new feature ids generated
(they are being collected before the transaction ends) so it gives back
fake results.
Well known issue, ticket here, second oldest open ticket in the system:
https://osgeo-org.atlassian.net/browse/GEOS-662
And then a repeat here with some other discussion (we should really close
one of the two):
https://osgeo-org.atlassian.net/browse/GEOS-6390
What David reports instead happens also for database backends and was not
known until today.
Ing. Andrea Aime
@geowolf
Technical Lead
