kept on inserting feature after reprojecting the coordinates
to 4326... it took me quite a bit to understand what was going
on, but it seems that:
* the feature parser in WFS insert request is not attaching
CRS information to geometry attributes
parsed feature types do not have CRS inforamtion (it seems
it's not using the datastore provided feature types)
* the insert engine, not finding a CRS, is assuming 4326, and
thus reprojects my geometries.
A quick fix would be to disallow reprojection in the insertion
engine if the feature type does not have CRS information,
and that's what I did as a quick fix on my local copy,
but I guess it would break the WFS 1.1 cite test, ain't it?
The real fix would be to have a complete schema attached
to my features, but I don't know where to put my hands to
handle that.
I think it should assume the CRS associated with the FeatureType should it not?
handle that.
I think you need justin's magic parser And I am not sure he hooked up things for GML2 yet?
Jody
Hmm, are you using the 1.0 or 1.1 parser. I am certain that the crs gets
set on parsed geometries in the "userData" attribute.
Hmm, i guess it falls back on getDefaultGeometry() which will not be the
crs specified on the point. Yes this is a problem.
No because the 1.1 tests always specify geometries in 4326 anyways. I
think the real problem is that there is no really good way to attach a
crs to a feature so that it can override what is specified in the type.
handle that.
Hmmm, i thought i changed the bidnings to do this. To actually use the
feature types from geoserver instead of trying to parse manually the
application schema. Perhaps I only did it for gml3? I will check into this.
1.0
And the code is looking for the default geometry, not the actual
geometries, to set a target crs.
