Hello,
I am in the process of migrating the geotools gt-property module (PropertyDataStore) to extend the newer ContentDataStore rather than AbstractDataStore. If this migration is succsessful, geoserver should be updated to use the new version.
In order to simplify this transfer, I am currently testing this new module against geoserver, and have run into a strange set of test failures in the WFS component:
For example:
org.geoserver.wfs.GetFeaturePagingTest
testStartIndexMultipleTypes(org.geoserver.wfs.GetFeaturePagingTest)
junit.framework.ComparisonFailure: expected:<[6]> but was:<[7]>
at org.custommonkey.xmlunit.XMLAssert.assertXpathEvaluatesTo(XMLAssert.java:858)
at org.geoserver.wfs.GetFeaturePagingTest.doTestStartIndexMultipleTypes(GetFeaturePagingTest.java:153)
at org.geoserver.wfs.GetFeaturePagingTest.testStartIndexMultipleTypes(GetFeaturePagingTest.java:137)
Trying to figure out what was causing this issue, I changed the assert to check for 7 instead of 6, and got:
junit.framework.ComparisonFailure: expected:<[7]> but was:<[6]>
at org.geoserver.wfs.GetFeaturePagingTest.testStartIndexMultipleTypes(GetFeaturePagingTest.java:136)
So I am seeing the correct value when I test for the wrong value, and vice versa. Has anyone run into this issue before?
If anyone is interested in the the new gt-property-ng module I am using, it can be found here: https://github.com/geotools/geotools/pull/646
The full list of test failures follows. Most of them are similar to the example above; the other primary type of failure is getting 0 results when 1 or more were expected:
at junit.framework.Assert.assertEquals(Assert.java:100)
at junit.framework.Assert.assertEquals(Assert.java:107)
at sun.reflect.NativeMethodAccessorImpl.invoke(NativeMethodAccessorImpl.java:57)
at java.lang.reflect.Method.invoke(Method.java:606)
at org.eclipse.jdt.internal.junit4.runner.JUnit4TestReference.run(JUnit4TestReference.java:50)
at org.eclipse.jdt.internal.junit.runner.TestExecution.run(TestExecution.java:38)
at org.eclipse.jdt.internal.junit.runner.RemoteTestRunner.runTests(RemoteTestRunner.java:459)
at org.eclipse.jdt.internal.junit.runner.RemoteTestRunner.runTests(RemoteTestRunner.java:675)
at org.eclipse.jdt.internal.junit.runner.RemoteTestRunner.run(RemoteTestRunner.java:382)
at org.eclipse.jdt.internal.junit.runner.RemoteTestRunner.main(RemoteTestRunner.java:192)
testStartIndexMultipleTypesPOST(org.geoserver.wfs.GetFeaturePagingTest)
at org.geoserver.wfs.GetFeaturePagingTest.doTestStartIndexMultipleTypesPOST(GetFeaturePagingTest.java:186)
at org.geoserver.wfs.GetFeaturePagingTest.testStartIndexMultipleTypesPOST(GetFeaturePagingTest.java:174)
org.geoserver.wfs.v2_0.GetFeatureTest
testNumReturnedMatchedWithMaxFeatures(org.geoserver.wfs.v2_0.GetFeatureTest)
org.junit.ComparisonFailure: expected:<[1]> but was:<[7]>
at org.junit.Assert.assertEquals(Assert.java:115)
at org.junit.Assert.assertEquals(Assert.java:144)
at org.geoserver.wfs.v2_0.GetFeatureTest.testNumReturnedMatchedWithMaxFeatures(GetFeatureTest.java:462)
testGetWithFilter(org.geoserver.wfs.v2_0.GetFeatureTest)
junit.framework.ComparisonFailure: expected:<[1]> but was:<[0]>
at org.geoserver.wfs.v2_0.GetFeatureTest.testGetWithFilter(GetFeatureTest.java:171)
testGetWithBBOX(org.geoserver.wfs.v2_0.GetFeatureTest)
at org.geoserver.wfs.v2_0.GetFeatureTest.testGetWithBBOX(GetFeatureTest.java:163)
testPostWithMatchingUrnBboxFilter(org.geoserver.wfs.v2_0.GetFeatureTest)
java.lang.AssertionError: expected:<1> but was:<0>
at org.junit.Assert.fail(Assert.java:88)
at org.junit.Assert.failNotEquals(Assert.java:743)
at org.junit.Assert.assertEquals(Assert.java:118)
at org.junit.Assert.assertEquals(Assert.java:555)
at org.junit.Assert.assertEquals(Assert.java:542)
at org.geoserver.wfs.v2_0.GetFeatureTest.testPostWithMatchingUrnBboxFilter(GetFeatureTest.java:332)
testResultTypeHitsNumberMatched(org.geoserver.wfs.v2_0.GetFeatureTest)
at org.geoserver.wfs.v2_0.GetFeatureTest.testResultTypeHitsNumberMatched(GetFeatureTest.java:425)
testGetWithCount(org.geoserver.wfs.v2_0.GetFeatureTest)
org.junit.ComparisonFailure: expected:<5> but was:<[1]5>
at org.geoserver.wfs.v2_0.GetFeatureTest.testGetWithCount(GetFeatureTest.java:88)
org.geoserver.wfs.GetFeatureHitsIgnoreMaxFeaturesTest
testHitsIgnoreMaxFeaturesDisabled(org.geoserver.wfs.GetFeatureHitsIgnoreMaxFeaturesTest)
org.junit.ComparisonFailure: expected:<1> but was:<1[5]>
at org.geoserver.wfs.GetFeatureHitsIgnoreMaxFeaturesTest.testHitsIgnoreMaxFeaturesDisabled(GetFeatureHitsIgnoreMaxFeaturesTest.java:82)
org.geoserver.wfs.v2_0.GetFeaturePagingTest
testStartIndexMultipleTypes(org.geoserver.wfs.v2_0.GetFeaturePagingTest)
at org.geoserver.wfs.v2_0.GetFeaturePagingTest.doTestStartIndexMultipleTypes(GetFeaturePagingTest.java:203)
at org.geoserver.wfs.v2_0.GetFeaturePagingTest.testStartIndexMultipleTypes(GetFeaturePagingTest.java:188)
testNextPreviousPOST(org.geoserver.wfs.v2_0.GetFeaturePagingTest)
java.lang.ArrayIndexOutOfBoundsException: 1
at org.geoserver.wfs.v2_0.GetFeaturePagingTest.assertStartIndexCount(GetFeaturePagingTest.java:396)
at org.geoserver.wfs.v2_0.GetFeaturePagingTest.doTestNextPreviousPOST(GetFeaturePagingTest.java:383)
at org.geoserver.wfs.v2_0.GetFeaturePagingTest.testNextPreviousPOST(GetFeaturePagingTest.java:370)
testNextPreviousHitsGET(org.geoserver.wfs.v2_0.GetFeaturePagingTest)
at org.geoserver.wfs.v2_0.GetFeaturePagingTest.doTestNextPreviousHitsGET(GetFeaturePagingTest.java:539)
at org.geoserver.wfs.v2_0.GetFeaturePagingTest.testNextPreviousHitsGET(GetFeaturePagingTest.java:525)
testStartIndexMultipleTypesPOST(org.geoserver.wfs.v2_0.GetFeaturePagingTest)
at org.geoserver.wfs.v2_0.GetFeaturePagingTest.doTestStartIndexMultipleTypesPOST(GetFeaturePagingTest.java:236)
at org.geoserver.wfs.v2_0.GetFeaturePagingTest.testStartIndexMultipleTypesPOST(GetFeaturePagingTest.java:224)
testNextPreviousGET(org.geoserver.wfs.v2_0.GetFeaturePagingTest)
at org.geoserver.wfs.v2_0.GetFeaturePagingTest.doTestNextPreviousGET(GetFeaturePagingTest.java:325)
at org.geoserver.wfs.v2_0.GetFeaturePagingTest.testNextPreviousGET(GetFeaturePagingTest.java:311)
org.geoserver.wfs.LockFeatureTest
testLayerQualified(org.geoserver.wfs.LockFeatureTest)
org.junit.ComparisonFailure: expected:<[wfs:FeatureCollection]> but was:<[ServiceExceptionReport]>
at org.geoserver.wfs.LockFeatureTest.testLayerQualified(LockFeatureTest.java:245)
testWorkspaceQualified(org.geoserver.wfs.LockFeatureTest)
at org.geoserver.wfs.LockFeatureTest.testWorkspaceQualified(LockFeatureTest.java:205)
testUpdateWithLockId(org.geoserver.wfs.LockFeatureTest)
at org.geoserver.wfs.LockFeatureTest.testUpdateWithLockId(LockFeatureTest.java:148)
testLockActionSomeAlreadyLocked(org.geoserver.wfs.LockFeatureTest)
at org.geoserver.wfs.LockFeatureTest.testLockActionSomeAlreadyLocked(LockFeatureTest.java:39)
org.geoserver.wfs.v2_0.SrsNameRequestTest
testHttpUrlNativeBbox(org.geoserver.wfs.v2_0.SrsNameRequestTest)
at org.geoserver.wfs.v2_0.SrsNameRequestTest.runTest(SrsNameRequestTest.java:127)
at org.geoserver.wfs.v2_0.SrsNameRequestTest.testHttpUrlNativeBbox(SrsNameRequestTest.java:223)
testEpsgCodeBbox(org.geoserver.wfs.v2_0.SrsNameRequestTest)
at org.geoserver.wfs.v2_0.SrsNameRequestTest.testEpsgCodeBbox(SrsNameRequestTest.java:197)
testHttpUriNativeBbox(org.geoserver.wfs.v2_0.SrsNameRequestTest)
at org.geoserver.wfs.v2_0.SrsNameRequestTest.testHttpUriNativeBbox(SrsNameRequestTest.java:357)
testUrnBbox(org.geoserver.wfs.v2_0.SrsNameRequestTest)
at org.geoserver.wfs.v2_0.SrsNameRequestTest.testUrnBbox(SrsNameRequestTest.java:332)
testUrnExperimentalBbox(org.geoserver.wfs.v2_0.SrsNameRequestTest)
at org.geoserver.wfs.v2_0.SrsNameRequestTest.testUrnExperimentalBbox(SrsNameRequestTest.java:286)
testHttpUriBbox(org.geoserver.wfs.v2_0.SrsNameRequestTest)
at org.geoserver.wfs.v2_0.SrsNameRequestTest.testHttpUriBbox(SrsNameRequestTest.java:375)
testHttpUrlBbox(org.geoserver.wfs.v2_0.SrsNameRequestTest)
at org.geoserver.wfs.v2_0.SrsNameRequestTest.testHttpUrlBbox(SrsNameRequestTest.java:241)
testUrnNativeBbox(org.geoserver.wfs.v2_0.SrsNameRequestTest)
at org.geoserver.wfs.v2_0.SrsNameRequestTest.testUrnNativeBbox(SrsNameRequestTest.java:314)
testUrnExperimentalNativeBbox(org.geoserver.wfs.v2_0.SrsNameRequestTest)
at org.geoserver.wfs.v2_0.SrsNameRequestTest.testUrnExperimentalNativeBbox(SrsNameRequestTest.java:268)
testEpsgCodeNativeBbox(org.geoserver.wfs.v2_0.SrsNameRequestTest)
at org.geoserver.wfs.v2_0.SrsNameRequestTest.testEpsgCodeNativeBbox(SrsNameRequestTest.java:179)
org.geoserver.wfs.v2_0.GetFeatureWithLockTest
testLayerQualified(org.geoserver.wfs.v2_0.GetFeatureWithLockTest)
org.junit.ComparisonFailure: expected:<[wfs:TransactionResponse]> but was:<[ows:ExceptionReport]>
at org.geoserver.wfs.v2_0.GetFeatureWithLockTest.testLayerQualified(GetFeatureWithLockTest.java:381)
testUpdateLockedFeatureWithoutLockId(org.geoserver.wfs.v2_0.GetFeatureWithLockTest)
org.junit.ComparisonFailure: expected:<[wfs:FeatureCollection]> but was:<[ows:ExceptionReport]>
at org.geoserver.wfs.v2_0.GetFeatureWithLockTest.testUpdateLockedFeatureWithoutLockId(GetFeatureWithLockTest.java:112)
testGetFeatureWithLockReleaseActionSome(org.geoserver.wfs.v2_0.GetFeatureWithLockTest)
java.lang.NullPointerException
at org.geoserver.wfs.v2_0.GetFeatureWithLockTest.testGetFeatureWithLockReleaseActionSome(GetFeatureWithLockTest.java:171)
testUpdateLockedFeatureWithLockId(org.geoserver.wfs.v2_0.GetFeatureWithLockTest)
org.junit.ComparisonFailure: expected:<[http://www.opengis.net/wfs/2.0]> but was:<>
at org.geoserver.wfs.v2_0.WFS20TestSupport.assertGML32(WFS20TestSupport.java:41)
at org.geoserver.wfs.v2_0.GetFeatureWithLockTest.testUpdateLockedFeatureWithLockId(GetFeatureWithLockTest.java:51)
org.geoserver.wfs.MaxFeaturesTest
testCombinedLocalMaxesBiggerRequestOverride(org.geoserver.wfs.MaxFeaturesTest)
java.lang.AssertionError: expected:<4> but was:<3>
at org.geoserver.wfs.MaxFeaturesTest.testCombinedLocalMaxesBiggerRequestOverride(MaxFeaturesTest.java:140)
testCombinedLocalMaxesBigger(org.geoserver.wfs.MaxFeaturesTest)
java.lang.AssertionError: expected:<5> but was:<4>
at org.geoserver.wfs.MaxFeaturesTest.testCombinedLocalMaxesBigger(MaxFeaturesTest.java:119)
testCombinedLocalMaxes(org.geoserver.wfs.MaxFeaturesTest)
java.lang.AssertionError: expected:<4> but was:<2>
at org.geoserver.wfs.MaxFeaturesTest.testCombinedLocalMaxes(MaxFeaturesTest.java:99)
org.geoserver.wfs.json.GeoJSONTest
testGetFeatureLine3D(org.geoserver.wfs.json.GeoJSONTest)
net.sf.json.JSONException: Invalid JSON String
at net.sf.json.JSONSerializer.toJSON(JSONSerializer.java:143)
at net.sf.json.JSONSerializer.toJSON(JSONSerializer.java:103)
at net.sf.json.JSONSerializer.toJSON(JSONSerializer.java:84)
at org.geoserver.test.GeoServerSystemTestSupport.json(GeoServerSystemTestSupport.java:1185)
at org.geoserver.test.GeoServerSystemTestSupport.getAsJSON(GeoServerSystemTestSupport.java:1180)
at org.geoserver.wfs.json.GeoJSONTest.testGetFeatureLine3D(GeoJSONTest.java:341)
org.geoserver.wfs.GetFeatureWithLockTest
testLayerQualified(org.geoserver.wfs.GetFeatureWithLockTest)
org.junit.ComparisonFailure: expected:<[wfs:WFS_TransactionResponse]> but was:<[ServiceExceptionReport]>
at org.geoserver.wfs.GetFeatureWithLockTest.testLayerQualified(GetFeatureWithLockTest.java:377)
testWorkspaceQualified(org.geoserver.wfs.GetFeatureWithLockTest)
at org.geoserver.wfs.GetFeatureWithLockTest.testWorkspaceQualified(GetFeatureWithLockTest.java:240)
testUpdateLockedFeatureWithoutLockId(org.geoserver.wfs.GetFeatureWithLockTest)
at org.geoserver.wfs.GetFeatureWithLockTest.testUpdateLockedFeatureWithoutLockId(GetFeatureWithLockTest.java:103)
testGetFeatureWithLockReleaseActionSome(org.geoserver.wfs.GetFeatureWithLockTest)
at org.geoserver.wfs.GetFeatureWithLockTest.testGetFeatureWithLockReleaseActionSome(GetFeatureWithLockTest.java:164)
testUpdateLockedFeatureWithLockId(org.geoserver.wfs.GetFeatureWithLockTest)
at org.geoserver.wfs.GetFeatureWithLockTest.testUpdateLockedFeatureWithLockId(GetFeatureWithLockTest.java:41)
org.geoserver.wfs.TransactionTest
testDoubleDelete(org.geoserver.wfs.TransactionTest)
org.junit.ComparisonFailure: expected:<[WFS_TransactionResponse]> but was:<[ServiceExceptionReport]>
at org.geoserver.wfs.TransactionTest.testDoubleDelete(TransactionTest.java:111)
org.geoserver.wfs.GetFeatureCurvesTest
testLinearizeWFS10(org.geoserver.wfs.GetFeatureCurvesTest)
at org.junit.Assert.fail(Assert.java:86)
at org.junit.Assert.assertTrue(Assert.java:41)
at org.junit.Assert.assertTrue(Assert.java:52)
at org.geoserver.wfs.GetFeatureCurvesTest.testLinearizeWFS10(GetFeatureCurvesTest.java:105)
Torben Barsballe
