Was wondering if anyone has tried integrating WFSV with the current GeoServer 2 trunk build ? I have a postgis datastore and would like to implement versioning.
Any help is highly apprecitated.
Thanks and Warm Regards
Debasish Sahu
Debasish Sahu
Debasish Sahu ha scritto:
I've just made sure it was building properly a 2-3 weeks ago.
Besides this, the instructions for 1.7.x should work on trunk as well, but I haven't tested them (haven't worked with versioning for months lately).
Andrea Aime
OpenGeo - http://opengeo.org
I have had some success getting the datastore show up in geoserver admin ui.But when I try to save a newly created versioned postgis datastore , get the following stack trace
2009-06-03 14:21:26,565 ERROR [lang.Objects] - Error serializing object class org.geoserver.web.data.store.DataAccessNewPage [object=[Page class = org.geoserver.web.data.store.DataAccessNewPage, id = 4, version = 0]]
org.apache.wicket.util.io.SerializableChecker$WicketNotSerializableException: Unable to serialize class: org.geoserver.ows.util.ClassProperties
Field hierarchy is:
4 [class=org.geoserver.web.data.store.DataAccessNewPage, path=4]
private java.lang.Object org.apache.wicket.MarkupContainer.children [class=[Ljava.lang.Object;]
private java.lang.Object org.apache.wicket.MarkupContainer.children[8] [class=org.apache.wicket.markup.html.form.Form, path=4:dataStoreForm]
java.lang.Object org.apache.wicket.Component.data [class=org.apache.wicket.model.CompoundPropertyModel]
private java.lang.Object org.apache.wicket.model.CompoundPropertyModel.target [class=org.geoserver.catalog.impl.DataStoreInfoImpl]
org.geoserver.catalog.WorkspaceInfo org.geoserver.catalog.impl.StoreInfoImpl.workspace [class=$Proxy1]
protected java.lang.reflect.InvocationHandler java.lang.reflect.Proxy.h [class=org.geoserver.catalog.impl.ModificationProxy]
org.geoserver.ows.util.ClassProperties org.geoserver.catalog.impl.ModificationProxy.cp [class=org.geoserver.ows.util.ClassProperties] <----- field that is not serializable
at org.apache.wicket.util.io.SerializableChecker.check(SerializableChecker.java:339)
at org.apache.wicket.util.io.SerializableChecker.checkFields(SerializableChecker.java:607)
at org.apache.wicket.util.io.SerializableChecker.check(SerializableChecker.java:530)
at org.apache.wicket.util.io.SerializableChecker.check(SerializableChecker.java:385)
at org.apache.wicket.util.io.SerializableChecker.writeObjectOverride(SerializableChecker.java:675)
at java.io.ObjectOutputStream.writeObject(ObjectOutputStream.java:322)
at org.apache.wicket.util.io.IObjectStreamFactory$2.writeObjectOverride(IObjectStreamFactory.java:125)
at org.apache.wicket.util.lang.Objects.objectToByteArray(Objects.java:1091)
at org.apache.wicket.protocol.http.pagestore.AbstractPageStore.serializePage(AbstractPageStore.java:197)
at org.apache.wicket.protocol.http.pagestore.DiskPageStore.storePage(DiskPageStore.java:811)
at org.apache.wicket.protocol.http.SecondLevelCacheSessionStore$SecondLevelCachePageMap.put(SecondLevelCacheSessionStore.java:332)
at org.apache.wicket.Session.requestDetached(Session.java:1371)
at org.apache.wicket.RequestCycle.detach(RequestCycle.java:1130)
at org.apache.wicket.RequestCycle.steps(RequestCycle.java:1418)
at org.apache.wicket.RequestCycle.request(RequestCycle.java:529)
at org.apache.wicket.protocol.http.WicketFilter.doGet(WicketFilter.java:356)
at org.apache.wicket.protocol.http.WicketServlet.doPost(WicketServlet.java:145)
at javax.servlet.http.HttpServlet.service(HttpServlet.java:637)
at javax.servlet.http.HttpServlet.service(HttpServlet.java:717)
at org.springframework.web.servlet.mvc.ServletWrappingController.handleRequestInternal(ServletWrappingController.java:158)
at org.springframework.web.servlet.FrameworkServlet.processRequest(FrameworkServlet.java:571)
at org.springframework.web.servlet.FrameworkServlet.doPost(FrameworkServlet.java:511)
at org.apache.catalina.core.ApplicationFilterChain.internalDoFilter(ApplicationFilterChain.java:290)
at org.apache.catalina.core.ApplicationFilterChain.doFilter(ApplicationFilterChain.java:206)
at org.vfny.geoserver.filters.SetCharacterEncodingFilter.doFilter(SetCharacterEncodingFilter.java:108)
at org.apache.catalina.core.ApplicationFilterChain.internalDoFilter(ApplicationFilterChain.java:235)
at org.acegisecurity.util.FilterChainProxy$VirtualFilterChain.doFilter(FilterChainProxy.java:264)
at org.acegisecurity.intercept.web.FilterSecurityInterceptor.invoke(FilterSecurityInterceptor.java:107)
at org.acegisecurity.intercept.web.FilterSecurityInterceptor.doFilter(FilterSecurityInterceptor.java:72)
at org.acegisecurity.util.FilterChainProxy$VirtualFilterChain.doFilter(FilterChainProxy.java:274)
at org.acegisecurity.ui.ExceptionTranslationFilter.doFilter(ExceptionTranslationFilter.java:110)
at org.acegisecurity.providers.anonymous.AnonymousProcessingFilter.doFilter(AnonymousProcessingFilter.java:125)
at org.acegisecurity.ui.rememberme.RememberMeProcessingFilter.doFilter(RememberMeProcessingFilter.java:142)
at org.acegisecurity.wrapper.SecurityContextHolderAwareRequestFilter.doFilter(SecurityContextHolderAwareRequestFilter.java:81)
at org.acegisecurity.ui.AbstractProcessingFilter.doFilter(AbstractProcessingFilter.java:217)
at org.acegisecurity.ui.logout.LogoutFilter.doFilter(LogoutFilter.java:106)
at org.acegisecurity.context.HttpSessionContextIntegrationFilter.doFilter(HttpSessionContextIntegrationFilter.java:229)
at org.acegisecurity.util.FilterChainProxy.doFilter(FilterChainProxy.java:148)
at org.acegisecurity.util.FilterToBeanProxy.doFilter(FilterToBeanProxy.java:98)
at org.geoserver.filters.LoggingFilter.doFilter(LoggingFilter.java:73)
at org.geoserver.filters.ReverseProxyFilter.doFilter(ReverseProxyFilter.java:176)
at org.geoserver.filters.GZIPFilter.doFilter(GZIPFilter.java:41)
at org.apache.catalina.core.StandardWrapperValve.invoke(StandardWrapperValve.java:233)
at org.apache.catalina.core.StandardContextValve.invoke(StandardContextValve.java:191)
at org.apache.catalina.core.StandardHostValve.invoke(StandardHostValve.java:128)
at org.apache.catalina.valves.ErrorReportValve.invoke(ErrorReportValve.java:102)
at org.apache.catalina.core.StandardEngineValve.invoke(StandardEngineValve.java:109)
at org.apache.catalina.connector.CoyoteAdapter.service(CoyoteAdapter.java:286)
at org.apache.coyote.http11.Http11AprProcessor.process(Http11AprProcessor.java:857)
at org.apache.coyote.http11.Http11AprProtocol$Http11ConnectionHandler.process(Http11AprProtocol.java:565)
at org.apache.tomcat.util.net.AprEndpoint$Worker.run(AprEndpoint.java:1509)
at java.lang.Thread.run(Thread.java:619)
Caused by: java.io.NotSerializableException: org.geoserver.ows.util.ClassProperties
at java.io.ObjectOutputStream.writeObject0(ObjectOutputStream.java:1156)
at java.io.ObjectOutputStream.defaultWriteFields(ObjectOutputStream.java:1509)
at java.io.ObjectOutputStream.writeSerialData(ObjectOutputStream.java:1474)
at java.io.ObjectOutputStream.writeOrdinaryObject(ObjectOutputStream.java:1392)
at java.io.ObjectOutputStream.writeObject0(ObjectOutputStream.java:1150)
at java.io.ObjectOutputStream.defaultWriteObject(ObjectOutputStream.java:416)
at org.apache.wicket.Component.writeObject(Component.java:4265)
at sun.reflect.GeneratedMethodAccessor74.invoke(Unknown Source)
at java.io.ObjectStreamClass.invokeWriteObject(ObjectStreamClass.java:945)
at java.io.ObjectOutputStream.writeSerialData(ObjectOutputStream.java:1461)
at java.io.ObjectOutputStream.writeArray(ObjectOutputStream.java:1338)
at java.io.ObjectOutputStream.writeObject0(ObjectOutputStream.java:1146)
at java.io.ObjectOutputStream.writeObject(ObjectOutputStream.java:326)
at org.apache.wicket.util.io.IObjectStreamFactory$2.writeObjectOverride(IObjectStreamFactory.java:117)
… 68 more
2009-06-03 14:22:08,906 ERROR [lang.Objects] - Error serializing object class org.geoserver.web.data.store.DataAccessNewPage [object=[Page class = org.geoserver.web.data.store.DataAccessNewPage, id = 4, version = 0]]
Field hierarchy is:
… 68 more
2009-06-03 14:23:43,474 ERROR [lang.Objects] - Error serializing object class org.geoserver.web.data.store.DataAccessNewPage [object=[Page class = org.geoserver.web.data.store.DataAccessNewPage, id = 4, version = 0]]
Field hierarchy is:
… 68 more
2009-06-03 14:23:45,192 ERROR [lang.Objects] - Error serializing object class org.geoserver.web.data.store.DataAccessNewPage [object=[Page class = org.geoserver.web.data.store.DataAccessNewPage, id = 4, version = 0]]
Field hierarchy is:
… 68 more
I’ve just made sure it was building properly a 2-3 weeks ago.
Besides this, the instructions for 1.7.x should work on trunk as well, but I haven’t tested them (haven’t worked with versioning for months lately).Cheers
Andrea–
Andrea Aime
Debasish Sahu
Hmmm... I've seen this error some minutes and I believe it has been recently introduced. However, this happens only if the connection
to the datastore fails for me, and the actual error is present
in the stack trace before this one in the logs.
Opened a report for this one (the wicket serialization issue)
http://jira.codehaus.org/browse/GEOS-3116
But the failure to connect for WSFV should be something else. You
sure you don't have anything else in the logs?
Andrea Aime
Please see the comments on <http://jira.codehaus.org/browse/GEOS-3116> too see the cause and the fix. Waiting for approval for the submitted patch.
Gabriel
in the stack trace before this one in the logs.Opened a report for this one (the wicket serialization issue)
http://jira.codehaus.org/browse/GEOS-3116But the failure to connect for WSFV should be something else. You
sure you don't have anything else in the logs?Cheers
Gabriel Roldan
