[Geoserver-devel] What to do with WMS GetFeatureInfo FORMAT parameter
Guys, Michael is requiring FORMAT parameter in WMS GetFeatureInfo being not
mandatory. I certainly understand it.
My only concern about it is if WMS CITE tests requires it? I guess some of you
used to run WMS CITE?
Michael Adair commented on GEOS-532:
I'll let you guys decide if you shoudl re-open, but I think this should be
fixed in Geoserver. FORMAT should not be a required parameter for the WMS
GetFeatureInfo request.
OGC has buried their older spec documents so I can't check v1.1.1, but in WMS
1.3 it is definitely not required, and any other WMS 1.1.1 we have tested
against didn't require FORMAT as a param.
We implemented a workaround in MapBuilder that adds on an empty FORMAT param
to the request, but that doesn't seem like the correct way to do that.
         Key: GEOS-532
         URL: http://jira.codehaus.org/browse/GEOS-532
     Project: GeoServer
        Type: Bug
  Components: WMS
    Reporter: Michael Adair
    Assignee: Gabriel Roldán
The GetFeatureInfo WMS request takes an INFO_FORMAT parameter, not FORMAT.
for reference: http://jira.codehaus.org/browse/MAP-8
For more information on JIRA, see:
Gabriel Roldán (groldan@anonymised.com)
Axios Engineering (http://www.axios.es)
Tel. +34 944 41 63 84
Fax. +34 944 41 64 90
This might be a good thing to apply at the start of 1.4.x. If need be we could use the scrict cite conformance hack to enable / disable the check for the format paramter.
Gabriel Roldán wrote:
Guys, Michael is requiring FORMAT parameter in WMS GetFeatureInfo being not mandatory. I certainly understand it.
My only concern about it is if WMS CITE tests requires it? I guess some of you used to run WMS CITE?
        Key: GEOS-532
    Project: GeoServer
       Type: Bug
Components: WMS
Justin Deoliveira
The Open Planning Project
http://topp.openplans.org
So my reading of the spec actually implies that it is required. The
section, in both 1.1.1 and 1.3 says:
The mandatory "map request part" entry in Table 9 represents a sequence
of parameters from the GetMap
request that generated the original map. Two of the GetMap parameters
are omitted because GetFeatureInfo
provides its own values: VERSION and REQUEST. The remainder of the
GetMap request shall be embedded
contiguously in the GetFeatureInfo request.
So the FORMAT part is part of the original map request, and thus it's
one of the parameters that needs to be embedded. CITE obviously sends
requests this way, or we wouldn't be passing.
That said, I agree it's silly, and thought it was silly the first time I
read it, since there's no way it'd ever be used.
I'd prefer this wasn't a config option, as I don't believe it will
actually mess up cite tests, since they'll just send the param and
nothing will happen.
It shouldn't be that hard for us to fix, and if every one else is
letting it slide than I'm fine to. We actually just use the same
parser for GetFeatureInfo and GetMap, we just pass that portion along,
and it is mandatory for a GetMap request. So we'd have to pass a dummy
value in.
Note that we do implement INFO_FORMAT, it's not confusion on our part,
it's the spec.
Go ahead and re-open the bug and attach my comments. We just have to
make sure to run through cite after the fix, but I don't believe it
will affect the tests.
Chris
Quoting Justin Deoliveira <jdeolive@anonymised.com>:
we
check
being not
some of you
should be
the WMS
but in WMS
tested
FORMAT param
that.
>> Key: GEOS-532
>> Project: GeoServer
>> Type: Bug
>> Components: WMS
FORMAT.
administrators:
Justin Deoliveira
Chris Holmes
thoughts at: http://cholmes.wordpress.com
This mail sent through IMP: https://webmail.limegroup.com/
