[Geoserver-devel] Where is SchemaPublisher?
Hi Justin,
I was using SchemaPublisher in community/web-c the same way it was used in
web, now I see the SchemaPublisher class is gone.
I'm going to try to track the changes, but it would be appreciated if you
could comment how should I proceed on this regard?
thanks
Gabriel
Whoops, Sorry Gabriel. I totally forgot that your module would be
depending on that too. I killed it and replaced it with a more generic
FilePublisher. Should have just deprecated, apologies. The configuration
is the same, you should be able to just change the bean class in the
context and it should be fine. I can also restore the one i killed if
that is easier for you.
-Justin
Gabriel Roldán wrote:
Hi Justin,
thanks
Gabriel
Justin Deoliveira
The Open Planning Project
jdeolive@anonymised.com
it seems it's ok, sorry if I've sound a bit hard.
So, should I map /schemas/**/*.xsd to filePublisher too, as it were before?
Gabriel
-Justin
> Hi Justin,
> in web, now I see the SchemaPublisher class is gone.
> thanks
> Gabriel
Yup, its pretty much the same class except it can serve up any type of file, not just a schema.
-Justin
Gabriel
-Justin
Hi Justin,
thanks
Gabriel
Justin Deoliveira
http://topp.openplans.org
