[Geoserver-devel] Where to put app-schema tutorial?
Andrea,
where should I put the app-schema tutorial when I write it? Should it go in the user docs for 2.0? And if so, when will work start on them?
Kind regards,
Ben Caradoc-Davies <Ben.Caradoc-Davies@anonymised.com>
Software Engineer, CSIRO Exploration and Mining
Australian Resources Research Centre
26 Dick Perry Ave, Kensington WA 6151, Australia
I am not Andrea but if I may respond you have a couple of options:
1) put it on the wiki now, and port it to sphinx later
2) do it in sphinx now
1) has the benefit that you can put it online now, since we don't have user docs for trunk in sphinx yet
2) has the benefit of not duplicating work
Your call, if you do it in confluence now someone will eventually port it to sphinx if you don't have time to do it.
What is your time frame for having it done? Or starting it for that matter? I was planning on copying the 1.7.x docs to trunk tomorrow (today actually, just never got around to it).
I can do that now if you wish, but the docs still won't be online until we update docs.geoserver.org.
-Justin
Ben Caradoc-Davies wrote:
Andrea,
Kind regards,
Justin Deoliveira
OpenGeo - http://opengeo.org
Where is sphinx? Do I have an account?
8 June.
2 June.
Great!
I am confused. I still don't understand the docs update procedure. Is this a wiki, or something generated from source? I'd better read the procedure ...
Kind regards,
docs on the GeoServer Sphinx setup:
http://docs.geoserver.org/1.7.x/docguide/
8 June.
> matter?
2 June.
Great!
procedure ...
Kind regards,
David Winslow
OpenGeo - http://opengeo.org/
Also of reference is the proposal that was put forth to do user and developer docs in sphinx:
http://geoserver.org/display/GEOS/GSIP+25+-+New+Documentation+Framework
The motivation was that the wiki is great for quick and dirty, but not good for high quality documentation. So the informal policy is use a good doc tool for good docs, and use the wiki for other more community focused stuff like download pages, R&d pages, proposals, road maps, etc...
8 June.
2 June.
Great!
Kind regards,
David Winslow
Justin Deoliveira
