Hi folks,
I wanted to do a quick poll of where people think the build and release scripts should go. I can see three options.
Under the src tree. Maybe in a directory called “build”. We could throw them under “maven” which is where some current build stuff lives… or maybe even rename that directory to “build”
Outside of the main source tree parallel to doc, data, and src in a folder called “build”
In a separate github repo.
A bit more info about what the contents of this folder will be. At first it should be some release scripts, something like files named:
release.sh → build the release and prep all the artifacts, putting them to some staging ground
release_publish.sh → upload the artifacts to final destination, and do any other meta tasks
Eventually I would like to put all the scripts currently living in hudson config in this same directory. So eventually there should be stuff like:
build.sh → main build script
build_nightly.sh → nightly build script
build_deploy.sh → deployment script
And so on.
Thoughts?
Will send a similar email for the geotools build scripts as well.
-Justin
Justin Deoliveira
OpenGeo - http://opengeo.org
