[Geoserver-devel] Which GWC do I need to build to release GeoServer 2.7.5?
I’m about to cut a GeoServer release based on the new GeoTools 13.5 release, I’m unable to work out which version of GWC is required for this. Is it documented anywhere?
Ian
Ian Turton
Ian,
I recommend releasing GeoServer built against GWC 1.7.3. I do not think it is necessary to release a new 1.7.x GWC.
GeoServer 2.7.x is built against GWC 1.7.x. To determine whether a new GWC is needed, we have to look at the 1.7.x branch at the time GeoServer is to be released. As the only changes in GWC 1.7.x since 1.7.3 are two repository tweaks, I recommend using 1.7.3 for GeoServer release purposes:
https://github.com/GeoWebCache/geowebcache/commits/1.7.x
https://github.com/GeoWebCache/geowebcache/commits/1.7.3
Both GeoServer 2.7.3 and 2.7.4 were built against GWC 1.7.3:
http://ares.boundlessgeo.com/jenkins/view/release/job/geoserver-release/86/consoleText
http://ares.boundlessgeo.com/jenkins/view/release/job/geoserver-release/89/consoleText
Kind regards,
Ben.
On 19/12/15 05:10, Ian Turton wrote:
I'm about to cut a GeoServer release based on the new GeoTools 13.5
release, I'm unable to work out which version of GWC is required for this.
Ian
Geoserver-devel mailing list
Ben Caradoc-Davies <ben@anonymised.com>
Director
Transient Software Limited <http://transient.nz/&gt;
New Zealand
Yes, stick with 1.7.3.
Kevin Michael Smith
<smithkm@anonymised.com>
