[Geoserver-devel] Who force pushed to 2.12.x?
I’ve been seeing some errors today that suggest someone force pushed changes to the geoserver/2.12.x branch.
At first I though it was just my local state that was out of order, but I see similar issues on remote build servers. I’m also seeing some missing commits on 2.12.x (Things that were backported from master but are no longer there).
As far as I can tell, this happened sometime around October 19th - 25th. Anyone who commited to the branch in that range may want to double check the commit history, as no commits are showing up there anymore.
And as a reminder to everyone, NEVER force push to ANY release branch (master, 2.12,x, etc) on a repository you do not personally own.
Torben
Upon further investigation, it appears the following commits are now missing from 2.12.x (There may be more, these are just the ones I have been able to track down):
Based on the last commit in that tree that matches the current state of 2.12 (8e75e08) , It seems likely that the commit that was force pushed is 74e01ef. Alessio - any comments?
Torben
On Fri, Oct 27, 2017 at 3:48 PM, Torben Barsballe <tbarsballe@anonymised.com> wrote:
Torben
I am picking through the Github events. The force-push happens on this page:
https://api.github.com/repos/geoserver/geoserver/events?page=3
This push resets the head of 2.12.x to the last common commit 8e75e0856a360798ca2bf2a09989ff799f981720 (this I think is the force push):
     "id": "6763084956",
     "type": "PushEvent",
     "actor": {
       "id": 1278021,
       "login": "afabiani",
       "display_login": "afabiani",
       "gravatar_id": "",
       "url": "https://api.github.com/users/afabiani&quot;,
       "avatar_url": "https://avatars.githubusercontent.com/u/1278021?&quot;
     "repo": {
       "id": 2751199,
       "name": "geoserver/geoserver",
       "url": "https://api.github.com/repos/geoserver/geoserver&quot;
     "payload": {
       "push_id": 2075721342,
       "size": 0,
       "distinct_size": 0,
       "ref": "refs/heads/2.12.x",
       "head": "8e75e0856a360798ca2bf2a09989ff799f981720",
       "before": "601a842e661450c908b5821bc5ae606a19954f3b",
       "commits": [
     "public": true,
     "created_at": "2017-10-25T10:13:09Z",
     "org": {
       "id": 186522,
       "login": "geoserver",
       "gravatar_id": "",
       "url": "https://api.github.com/orgs/geoserver&quot;,
       "avatar_url": "https://avatars.githubusercontent.com/u/186522?&quot;
    - 6544ca5
    <https://github.com/geoserver/geoserver/commit/6544ca542a0a8b19a6bf905777a636b4ecad3e48&gt;
    - 5fbe3a2
    <https://github.com/geoserver/geoserver/commit/5fbe3a21b0d5586996c908181b747e6b2eaf5789&gt;
    - e672ef0
    <https://github.com/geoserver/geoserver/commit/e672ef07d0fb33c957050a887e73be9de9443986&gt;
    - 8a1e06a
    <https://github.com/geoserver/geoserver/commit/8a1e06a418826bca527db0938dfbd204e2c2b470&gt;
    - 08c0d02
    <https://github.com/geoserver/geoserver/commit/08c0d024873a5810ea80dfcfdd4fc7a52f6b40d3&gt;
    - 05352fe
    <https://github.com/geoserver/geoserver/commit/05352fe7cec3b1ac8fcc4b7e144ed4aa78981748&gt;
2.12 (8e75e08
<https://github.com/geoserver/geoserver/commit/8e75e0856a360798ca2bf2a09989ff799f981720&gt;\)
<https://github.com/geoserver/geoserver/commit/74e01efe27511faea96f680242a79e7fdcbfd311&gt;\.
Torben
I've been seeing some errors today that suggest someone force pushed
see similar issues on remote build servers. I'm also seeing some missing
longer there).
Torben
Check out the vibrant tech community on one of the world's most
Geoserver-devel mailing list
Ben Caradoc-Davies <ben@anonymised.com>
Director
Transient Software Limited <http://transient.nz/&gt;
New Zealand
I have the following commits in my local repo (latest first). There are six substantive commits, and the last one is the common one we have in the current 2.12.x:
e9b63ca199d1d6d0b6d983965e4495c9f00bb568 (old_2.12.x) Fix link to uDig manual CQL page
6544ca542a0a8b19a6bf905777a636b4ecad3e48 [GEOS-8349] Monitor REST API won't return xml/json representation for request since 2.12.0
5fbe3a21b0d5586996c908181b747e6b2eaf5789 Updating Script REST API from Restlet to Spring MVC enabling this module to work with GeoServer's REST API.
e672ef07d0fb33c957050a887e73be9de9443986 [GEOS-8333] Reverting part of the previous change, as the SLD 1.1 encoder support is severely lacking at the moment
8a1e06a418826bca527db0938dfbd204e2c2b470 [GEOS-8333] Uploading a SLD 1.1 style over a SLD 1.0 style causes runtime parsing errors
08c0d024873a5810ea80dfcfdd4fc7a52f6b40d3 Merge pull request #2604 from emerkle826/geogig-config-npe-2.12
05352fe7cec3b1ac8fcc4b7e144ed4aa78981748 Fix an NPE when using the plugin in a GeoNode context
8e75e0856a360798ca2bf2a09989ff799f981720 Merge pull request #2601 from jdgarrett/fix_geogig_npe_2.12.x
You can see action in our Jenkins flight data recorder:
This is where my 2.12.x branch got to:
https://build.geoserver.org/view/geoserver/job/geoserver-2.12.x/35/changes
Two commits from Andrea that are I think now lost:
https://build.geoserver.org/view/geoserver/job/geoserver-2.12.x/36/changes
Five commits from Alessio that are I think now lost:
https://build.geoserver.org/view/geoserver/job/geoserver-2.12.x/37/changes
And another from Alessio, also lost, reverting one of the five:
https://build.geoserver.org/view/geoserver/job/geoserver-2.12.x/38/changes
And the first build after the force push:
https://build.geoserver.org/view/geoserver/job/geoserver-2.12.x/39/
So I think we can identify all the missing commits.
Kind regards,
Director
New Zealand
I have submitted a pull request:
https://github.com/geoserver/geoserver/pull/2613
This pull request contains:
- The six substantive commits on my local 2.12.x branch (listed earlier)
- Cherry-picked from master (I *assume* this was a straightforward cherry-pick to backport to 2.12.x): 9dfdf50de9094d778302be467bf11c334485515f [GEOS-8353] Ensure KML validates without being online.
I did *not* include:
Commit 3f472c02b06a7d13851ee9e8523684ca7b752397 by Andrea Aime
[GEOS-8360] xStream security warning
because I think it has already been cherry-picked onto the new 2.12.x as https://github.com/geoserver/geoserver/pull/2613.
This leaves only the changes listed in this Jenkins build:
Alessio, I do not know if you intended to remove these changes. Please re-apply them to 2.12.x if that was your intent.
Kind regards,
Director
New Zealand
Merged.
Kind regards,
Director
New Zealand
I am sure folks are aware but GitHub supports “protected branches” that outright disable force pushes. Extremely useful feature :slight_smile: Looking in github it looks like it was used in the past: master, and branches 2.5.x - 2.8.x are protected but no others are. Probably a useful thing to add to the process when creating a new maintenance branch would be to go into GitHub and add that branch as a protected one. It looks like it is possible to do it via the GitHub api as well, so also possible to add to the release scripts as well.
$0.02
On October 27, 2017 at 7:18:38 PM, Ben Caradoc-Davies (ben@anonymised.com) wrote:
Merged.
  • The six substantive commits on my local 2.12.x branch (listed earlier)
  • Cherry-picked from master (I assume this was a straightforward
I did not include:
Kind regards,
Director
Transient Software Limited <http://transient.nz/>
New Zealand
Outstanding! I am running amok enabling branch protection for all release branches. Just the basic protection, same as master, and we can turn it off if there are any unwanted side-effects.
While status checks and mandatory reviews may seem appealing, I am sure they would wear quite thin.
Kind regards,
Ben.
scripts as well.
$0.02
wrote:
Merged.
Kind regards,
Director
New Zealand
I have also enabled basic branch protection on all GeoTools release branches (same as master). This prevents force pushes and deletion of these branches.
Yes, this should be part of our RC-release-create-new-stable-branch procedure for GeoTools and GeoServer. Branching is still a manual step so this will be as well. For example:
http://docs.geotools.org/latest/developer/procedures/release.html#if-you-are-cutting-the-first-rc-of-a-series-create-the-stable-branch
Any objections?
Kind regards,
Ben.
Kind regards,
Ben.
scripts as well.
$0.02
wrote:
Merged.
Kind regards,
Director
New Zealand
Hi Justin,
I remember that, it happened after another forced push… and thought we protected all branches from
forced pushes?
I guess that this actually needs to be done manually for each newly created branch eh?
On Sat, Oct 28, 2017 at 5:08 AM, Justin Deoliveira <jdeolive@anonymised.com> wrote:
$0.02
Merged.
I did not include:
Kind regards,
Director
New Zealand
Geoserver-devel@anonymised.comsourceforge.net
Andrea Aime
GeoServer Professional Services from the experts! Visit http://goo.gl/it488V for more information.
Ing. Andrea Aime
@geowolf
Technical Lead
Via di Montramito 3/A
mob: +39 339 8844549
On Sat, Oct 28, 2017 at 1:43 PM, Ben Caradoc-Davies <ben@anonymised.com>
branches.
Awesome, thanks for doing that.
Yep, agreed it should be part of the release process.
Andrea Aime
Ing. Andrea Aime
@geowolf
Technical Lead
branches.
Done.
Kind regards,
Director
New Zealand
It seems it was my fault. I only remember to have reverted a wrong commit, did not want to do a push force. It was a mistake.
Protecting branches for sure is the best way to avoid similar mistakes in the future. Please let me know if I can do something else.
On Sun, Oct 29, 2017 at 12:05 AM, Ben Caradoc-Davies <ben@anonymised.com> wrote:
branches.
Done.
Kind regards,
Director
New Zealand
GeoTools-Devel mailing list
GeoTools-Devel@anonymised.comge.net
https://lists.sourceforge.net/lists/listinfo/geotools-devel
Alessio Fabiani
Ing. Alessio Fabiani
@alfa7691
Founder/Technical Lead
mob: +39 331 6233686
No problem, Alessio. You are not the first (or even the third) to force-push, and we now have the safety catch we need: branch protection.
There are five commits of yours that were on 2.12.x but were removed by your force push and have not yet been restored. I do not have these commits, and I was not sure if you removed any of these intentionally. Conveniently, these five commits are listed in a single Jenkins job:
Please review these missing commits and apply those that you would like to keep to the 2.12.x branch.
Kind regards,
Ben.
Alessio Fabiani
@alfa7691
these
branches.
-stable-branch
Done.
Kind regards,
Director
New Zealand
GeoTools-Devel@lists.sourceforge.net
Director
New Zealand
We already had protection on 1.11.x and master for GWC but this reminded
me to add 1.12.x
I need to look into whether there's a way to automate this as part of
the GWC release script when it generates a new stable branch.
these branches.
Any objections?
Kind regards,
Ben.
Kind regards,
Ben.
2.5.x -
add to
possible
release
scripts as well.
$0.02
wrote:
Merged.
earlier)
2.12.x as
Kind regards,
Kevin Michael Smith
<smithkm@anonymised.com>
