I think this question belongs more to the dev list than the users list.
When trying to setup a WFS with a different URL than .../wfs (e.g. /ows/railroads) I saw that the "wfs" part of the URL is hard coded in the source: ResponseUtils.appendPath(proxifiedBaseUrl, "wfs"). Is this nessecary? Are there plans to change this using the detected URL as this is already done for the path-substring in the URL?
Thank you!
Martin
afaik there's no plan to do so so far.
Why is it a problem though? it's machine to machine communication so it
shouldn't matter at all.
path-substring detection (aka, proxifiedUrl) is there to get the actual root context. From there on it's up to the server to define the service end points. If there's a strong use case to change that we could see, but I don't quite get the point?
Gabriel
Martin Kofahl wrote:
Hi, I think this question belongs more to the dev list than the users
list.
Thank you! Martin
Come build with us! The BlackBerry® Developer Conference in SF,
CA is the only developer event you need to attend this year.
Jumpstart your developing skills, take BlackBerry mobile applications
to market and stay ahead of the curve. Join us from November
9-12, 2009. Register now! http://p.sf.net/sfu/devconf _______________________________________________ Geoserver-devel
mailing list Geoserver-devel@lists.sourceforge.net https://lists.sourceforge.net/lists/listinfo/geoserver-devel
Gabriel Roldan
OpenGeo - http://opengeo.org
