[Geoserver-devel] Why Install as Windows service requires 32 bit JRE?
What is the reason that installing Geoserver as a Windows service with the Windows installer requires 32 bit JRE? Is it because the service wrapper is architecture dependent and 64 bit version is not even available as Community edition https://wrapper.tanukisoftware.com/doc/english/download.jsp?
Have we other options for making the installer to install Geoserver as Windows service with 64 bit JRE? 32 bit JRE is rather uncommon nowadays.
-Jukka Rahkonen-
On Wed, Apr 18, 2018 at 11:00 AM, Rahkonen Jukka (MML) <
jukka.rahkonen@anonymised.com> wrote:
I believe so.
Finding some windows developer that wants to put time in finding or
building an alternative, or sponsor someone to do the same (e.g., personally
I would not touch windows with a 10 feet pole in my spare time, but during
working hours one has to do what he's paid for, like or not like :-p ).
A quick search turned out this, which also has links to other alternative
setups... mind, I did not check if the project is good or even alive:
http://yajsw.sourceforge.net/
GeoServer Professional Services from the experts! Visit http://goo.gl/it488V
for more information.
Ing. Andrea Aime
@geowolf
Technical Lead
Via di Montramito 3/A
mob: +39 339 8844549
