Practically I don’t think I am a position to block anything given that I am not very active at the moment, so I guess I would give a -0 vote. I still don’t really understand the need for XML over JSON, aside from a personal preference?
Going this direction will negatively impact the only known client (that I know of) for the importer [1], which I know is being used in production currently. What if the new xstream / xml based api could be developed alongside what’s already there? That would at least give people using the current api an out. And depending how the two evolve, deprecate one in the future.
On Fri, Feb 20, 2015 at 5:04 AM, Andrea Aime <andrea.aime@anonymised.com…> wrote:
so to get practical, if I had to support XML, and made a pull request
that used xstream instead of hand conding, preserving the current json structure of course,
would it be accepted? If not, I’m open to suggestions… Should I start a new rest module
more aligned with the other GeoServer rest api?
In case it’s ok to modify the existing one, would I have to limit xstream usage to xml representation, or would it
make sense to also drop the current hand written json bindings?
From what I can tell xstream would produce the current json output with minimal customization, but I may
be wrong of course (please advise).
I may also need to provide full layer representation as opposed to the custom/limited
one currently supported by the json bindings, to allow userscontrol over the full layer configuration
(still discussing it, but the current minimum representation can really only address simple needs).
On Thu, Feb 19, 2015 at 4:39 PM, Andrea Aime <andrea.aime@anonymised.com> wrote:
Ing. Andrea Aime
@geowolf
Technical Lead
Via Poggio alle Viti 1187
mob: +39 339 8844549
On Thu, Feb 19, 2015 at 4:37 PM, Ian Schneider <ischneider@anonymised.com> wrote:
It is indeed a matter of preference. I live in a parallel universe where XML is more popular among server side developers apparently
Ing. Andrea Aime
@geowolf
Technical Lead
On Thu, Feb 19, 2015 at 8:21 AM, Andrea Aime <andrea.aime@anonymised.com> wrote:
The assertion of ‘software preferring to talk XML’ is quite subjective at best and an anthropomorphism at worse
When software does become self-aware, my guess is it’s ‘preference’ will be to communicate in binary
I believe when Justin mentioned ‘rest client developers’, he was referring to ‘API client’ - as in, the consumer of the service. Indeed, the existing importer API client is used server-side and is quite capable of being used via cron without even knowing that JSON is used as the protocol.
On Thu, Feb 19, 2015 at 4:17 PM, Justin Deoliveira <jdeolive@anonymised.com> wrote:
Server side software prefers to talk XML normally, and mass imports are not something to be restricted to clients, on
the contrary, coupled with a cron-like engine they are the very source of life of any system doing continous data
publishing (typical in metoc).
Yeah, I guess so. Although if the api is to support both xml and json making everything use xstream becomes more attractive despite all of the above. Our initial rationale was that supporting json would be enough as I don’t see a lot of rest client developers that ask for xml when json is available. If anything it’s always the other way around.
Long story short, to support XML one has to build a DOM or something similar and then perform a similar manual parse and encoding, right?
