I've reconfigured all four builds on the win32 Hudson to send hate
mails on the respective mailing lists when the build fails.
You can get to the build server here:
http://hudson.opengeo.org/win32
The "normal" builds are actually in a path with spaces, the
jdk6 ones are in path with spaces and with Sun JDK 1.6.0_14
or something (triple insult build, win32, spaces, non official
JDK)
The builds do run once a day, between midnight and 4AM NY time,
and it's also possible to login with the "usual" username/password
combination to run a build manually (usual as in the same as
the other hudson, ask in private if you need it).
Please use the ability to start builds manually sparingly,
as the build box is not fast and very much taxed, especially
by the GT2 build, that takes over 30 minutes
Andrea Aime
OpenGeo - http://opengeo.org
