the Windows build is almost working. Actually, it just never fails on my win7
box, but on the build server, hosted in a VM, it still does a bit (7 out of last 10
builds working fine):
http://winbuild.geo-solutions.it/jenkins/job/GeoServer-Master/
One failure that keeps on happening every now and then is this one:
Tests run: 10, Failures: 1, Errors: 0, Skipped: 0, Time elapsed: 20.202 sec <<< FAILURE!
testOutputFormatWrongCase(org.geoserver.wfs.xslt.GetFeatureXSLTTest) Time elapsed: 15 sec <<< FAILURE!
java.lang.AssertionError
at org.junit.Assert.fail(Assert.java:86)
at org.junit.Assert.assertTrue(Assert.java:41)
at org.junit.Assert.assertTrue(Assert.java:52)
at org.geoserver.wfs.xslt.GetFeatureXSLTTest.setupXSLT(GetFeatureXSLTTest.java:47)
at sun.reflect.NativeMethodAccessorImpl.invoke(NativeMethodAccessorImpl.java:57)
at java.lang.reflect.Method.invoke(Method.java:606)
And the code where it happens leaves me quite baffled:
@Before
public void setupXSLT() throws IOException {
File dd = getTestData().getDataDirectoryRoot();
File wfs = new File(dd, “wfs”);
File transform = new File(wfs, “transform”);
if (transform.exists()) {
FileUtils.deleteDirectory(transform);
assertTrue(transform.mkdirs()); << this is line 47
FileUtils.copyDirectory(new File(“src/test/resources/org/geoserver/wfs/xslt”), transform);
// makes sure the output format list is updated
XSLTOutputFormatUpdater updater = applicationContext.getBean(XSLTOutputFormatUpdater.class);
updater.run();
So, before each test we clean up a directory in the data dir. The FileUtils.deleteDirectory
supposedly cleans up a directory recursively, and will throw an exception in case it
cannot.
So apparently we are able to delete the directory, but then sometimes the subsequent mkdirs()
fails to create it back? This would fail only if the directory creation is impossible, or if
it was there already, but neither case should really be happening,
when testOutputFormatWrongCase runs it’s the 6th times setupXSLT() is called,
Anybody has a clue?
The other error is also rather maddening:
Ing. Andrea Aime
@geowolf
Technical Lead
Via Poggio alle Viti 1187
mob: +39 339 8844549
