the windows build keeps on running once per hour to locate spurious failures,
as far as I could see during the last week we are down to two common failures:
a) XML security tests leaving files open, which cannot be cleaned up after (, e.g. http://winbuild.geo-solutions.it/jenkins/job/GeoServer-Master/org.geoserver$gs-main/1422/testReport/junit/org.geoserver.security.xml/XMLRoleServiceTest/testInsert/)
b) a rare failure that makes EPSG:4326 impossible to decode, with no information on how to debug it (no errors in the HSQL setup), and no way to reproduce it
a) happens every 10-20 builds, b) seems to happen every 20-50 builds
I was thinking to make the build server start sending hate mails in case of build failures once we fix a),
given than b) seems to be un-crackable and relatively rare.
What do you think?
Ing. Andrea Aime
@geowolf
Technical Lead
Via Poggio alle Viti 1187
mob: +39 339 8844549
