[Geoserver-devel] Windows build server ready
the Windows build server I’ve been working on is finally online:
http://office.geo-solutions.it/jenkins/
The machine is a Vista 64 bits one, with the build running in paths with embedded
spaces over Java 6.
Right now the builds are running during the italian night, once a day.
The GeoServer build is now fine, the GeoTools one is not but the main build server
is reporting the same problem (process name refactoring caused a failure
in the documentation module).
About making them work: geotools was relatively easy, just shapefile-ng was not
building properly, GeoServer required a lot of changes in tests to avoid
having the code keeping a finger on some files that were impossible to delete
under the teardown phase (and a few changes in the actual code too to make
sure GridCoverage objects are getting disposed of).
These changes have been committed on master only, I guess I can backport
them if/when we also do the backport of the “fast test” proposal (in GeoServer
land at least, GeoTools wise things are easier).
As we previously discussed we should setup some new mailing list for
these “extra” builds.
How about two new google groups, geotools-builds and geoserver-builds?
Ing. Andrea Aime
@geowolf
Technical Lead
Via Poggio alle Viti 1187
mob: +39 339 8844549
Well Done Andrea.
I love that the build path has an embedded space with in it.
Keep up the good work,
Brett
Sent from my iPad
On 22/10/2012, at 11:03 PM, “Andrea Aime” <andrea.aime@…1268…> wrote:
spaces over Java 6.
Ing. Andrea Aime
@geowolf
Technical Lead
Everyone hates slow websites. So do we.
Make your web apps faster with AppDynamics
Download AppDynamics Lite for free today:
http://p.sf.net/sfu/appdyn_sfd2d_oct
GeoTools-Devel mailing list
GeoTools-Devel@lists.sourceforge.net
https://lists.sourceforge.net/lists/listinfo/geotools-devel
On Mon, Oct 22, 2012 at 8:03 AM, Andrea Aime <andrea.aime@anonymised.com> wrote:
spaces over Java 6.
Nice!
+1. I see that geotools-builds already exists… but i don’t think i created it. At least I am not currently a member. I don’t see a geoserver-builds list when i search.
Ing. Andrea Aime
@geowolf
Technical Lead
GeoTools-Devel@anonymised.coms.sourceforge.net
Justin Deoliveira
OpenGeo - http://opengeo.org
Yes! That's great.
Mike Pumphrey
On 10/22/2012 5:24 AM, Brett Walker wrote:
Well Done Andrea.
Brett
Sent from my iPad
On 22/10/2012, at 11:03 PM, "Andrea Aime" <andrea.aime@anonymised.com<mailto:andrea.aime@anonymised.com>> wrote:
the Windows build server I've been working on is finally online:
spaces over Java 6.
them if/when we also do the backport of the "fast test" proposal (in GeoServer
these "extra" builds.
Ing. Andrea Aime
@geowolf
Technical Lead
GeoTools-Devel@lists.sourceforge.net<mailto:GeoTools-Devel@lists.sourceforge.net>
Geoserver-devel mailing list
On Mon, Oct 22, 2012 at 2:51 PM, Justin Deoliveira <jdeolive@anonymised.com> wrote:
Eh, I’ve tried to see who owns that list but failed, so I believe we should stay away from it.
How about a geotools-extra-builds and geoserver-extra-builds?
For the time being I’ve reserved those two names and created the groups, it’s possible to rename them
later if we want.
Ing. Andrea Aime
@geowolf
Technical Lead
spaces
Great work, Andrea.
I use tricky workspace customisation to get build paths with spaces; it never crossed my mind to use a job name with a space! This is so much easier. I think you have discovered a new Jenkins best-practice.
Kind regards,
Ben Caradoc-Davies <Ben.Caradoc-Davies@anonymised.com>
Software Engineer
CSIRO Earth Science and Resource Engineering
Australian Resources Research Centre
