while setting up the GeoTools "Windows with spaces in path" daily
build I also setup the GeoServer one.
The result is more or less the same as the Geotools one, all fine
until the app-schema related tests start to run, then bye bye.
Hopefully fixing the issues in gt2 will also fix the ones on
the GeoServer side.
If you want to have a look at the test failures you can
find them here:
http://hudson.opengeo.org/win32/job/GeoServer-trunk/org.geoserver.extension$app-schema-test/5/testReport/
(this version of Hudson has a much better integration with
Maven and is able to report the test results in a well laid
out manner)
Andrea Aime
OpenGeo - http://opengeo.org
Thanks very much Andrea. These are almost certainly the same problem encountered in:
http://jira.codehaus.org/browse/GEOT-2644
Andrea Aime wrote:
the GeoServer side.
find them here:
out manner)
Ben Caradoc-Davies <Ben.Caradoc-Davies@anonymised.com>
Software Engineer, CSIRO Exploration and Mining
Australian Resources Research Centre
26 Dick Perry Ave, Kensington WA 6151, Australia
Thanks again. This is a good improvement to our test coverage.
the GeoServer side.
Lamentably, no. There was one more failure in app-schema-test. This has been fixed. There were also failures in restconfig. I have submitted a patch:
http://jira.codehaus.org/browse/GEOS-3357
Once the patch is applied, GeoServer can be built with -PallExtensions in a path with spaces (under Linux).
find them here:
out manner)
Drooool. :-P~
