[Geoserver-devel] Windows Installer GeoServer Compile errors
Hello,
I am new to GeoServer and in need of a little assistance. Let me know if you need any thing else.
I am getting these 4 different errors when running the GEOServer Admin.
Config
OS: Windows XP PRO
Browser: IE 6
Java: j2re1.4.2_05
Console Errors when launching the admin window at http://localhost:8080/Geoserver
10:03:42.324 EVENT Exception: : Compile failed; see the compiler error output for details.
at org.apache.tools.ant.taskdefs.Javac.compile(Javac.java:842)
at org.apache.tools.ant.taskdefs.Javac.execute(Javac.java:682)
at org.apache.jasper.compiler.Compiler.generateClass(Compiler.java:317)
at org.apache.jasper.compiler.Compiler.compile(Compiler.java:370)
at org.apache.jasper.JspCompilationContext.compile(JspCompilationContext.java:473)
at org.apache.jasper.servlet.JspServletWrapper.service(JspServletWrapper.java:190)
at org.apache.jasper.servlet.JspServlet.serviceJspFile(JspServlet.java:295)
at org.apache.jasper.servlet.JspServlet.service(JspServlet.java:241)
at javax.servlet.http.HttpServlet.service(HttpServlet.java:853)
at org.mortbay.jetty.servlet.ServletHolder.handle(ServletHolder.java:358)
at org.mortbay.jetty.servlet.WebApplicationHandler.dispatch(WebApplicationHandler.java:294)
at org.mortbay.jetty.servlet.Dispatcher.dispatch(Dispatcher.java:222)
at org.mortbay.jetty.servlet.Dispatcher.include(Dispatcher.java:127)
at org.apache.jasper.runtime.JspRuntimeLibrary.include(JspRuntimeLibrary.java:822)
at org.apache.jasper.runtime.PageContextImpl.include(PageContextImpl.java:398)
at org.apache.struts.tiles.TilesUtilImpl.doInclude(TilesUtilImpl.java:137)
at org.apache.struts.tiles.TilesUtil.doInclude(TilesUtil.java:177)
at org.apache.struts.taglib.tiles.InsertTag.doInclude(InsertTag.java:756)
at org.apache.struts.taglib.tiles.InsertTag$InsertHandler.doEndTag(InsertTag.java:881)
at org.apache.struts.taglib.tiles.InsertTag.doEndTag(InsertTag.java:473)
at org.apache.jsp.mainLayout_jsp._jspx_meth_tiles_insert_5(mainLayout_jsp.java:1268)
at org.apache.jsp.mainLayout_jsp._jspService(mainLayout_jsp.java:450)
at org.apache.jasper.runtime.HttpJspBase.service(HttpJspBase.java:137)
at org.apache.jasper.servlet.JspServletWrapper.service(JspServletWrapper.java:210)
at org.mortbay.jetty.servlet.Dispatcher.forward(Dispatcher.java:135)
at org.apache.struts.action.RequestProcessor.doForward(RequestProcessor.java:1069)
at org.apache.struts.tiles.TilesRequestProcessor.doForward(TilesRequestProcessor.java:274)
at org.apache.struts.tiles.TilesRequestProcessor.processTilesDefinition(TilesRequestProcessor.java:254)
at org.apache.struts.tiles.TilesRequestProcessor.processForwardConfig(TilesRequestProcessor.java:309)
at org.apache.struts.action.RequestProcessor.process(RequestProcessor.java:279)
at org.apache.struts.action.ActionServlet.process(ActionServlet.java:1482)
at org.apache.struts.action.ActionServlet.doGet(ActionServlet.java:507)
at javax.servlet.http.HttpServlet.service(HttpServlet.java:740)
at org.mortbay.jetty.servlet.ServletHandler.handle(ServletHandler.java:567)
at org.mortbay.http.HttpContext.handle(HttpContext.java:1807)
at org.mortbay.jetty.servlet.WebApplicationContext.handle(WebApplicationContext.java:525)
at org.mortbay.http.HttpContext.handle(HttpContext.java:1757)
at org.mortbay.http.HttpServer.service(HttpServer.java:879)
at org.mortbay.http.HttpConnection.service(HttpConnection.java:790)
at org.mortbay.http.HttpConnection.handleNext(HttpConnection.java:961)
at org.mortbay.http.HttpConnection.handle(HttpConnection.java:807)
at org.mortbay.http.SocketListener.handleConnection(SocketListener.java:197)
at org.mortbay.util.ThreadedServer.handle(ThreadedServer.java:276)
at org.mortbay.util.ThreadPool$PoolThread.run(ThreadPool.java:511)
10:03:43.449 EVENT Error compiling file: C:\Program Files\GeoServer 1.2\server\geoserver\WEB-INF\work\WEB-INF\pages/ac
tionator_jsp.java [javac] Since fork is true, ignoring compiler setting.
[javac] Compiling 1 source file
[javac] C:\Program Files\GeoServer 1.2\server\geoserver\WEB-INF\work\WEB-INF\pages\actionator_jsp.java:79: cannot re
solve symbol
[javac] symbol : method split (java.lang.String)
[javac] location: class java.lang.String
[javac] String array = forwards.split(“:”);
[javac] ^
[javac] 1 error
This error appears on the Left pain of the admin window at http://localhost:8080/Geoserver
[ServletException in:/WEB-INF/pages/actionator.jsp] Unable to compile class for JSP An error occurred at line: -1 in the jsp file: null Generated servlet error: [javac] Since fork is true, ignoring compiler setting. [javac] Compiling 1 source file [javac] Since fork is true, ignoring compiler setting. [javac] C:\Program Files\GeoServer 1.2\server\geoserver\WEB-INF\work\WEB-INF\pages\actionator_jsp.java:79: cannot resolve symbol [javac] symbol : method split (java.lang.String) [javac] location: class java.lang.String [javac] String array = forwards.split(“:”); [javac] ^ [javac] 1 error ’
This error appears on the Main pain Header side of the admin window at http://localhost:8080/Geoserver
[ServletException in:/WEB-INF/pages/locator.jsp] Unable to compile class for JSP An error occurred at line: -1 in the jsp file: null Generated servlet error: [javac] Since fork is true, ignoring compiler setting. [javac] Compiling 1 source file [javac] Since fork is true, ignoring compiler setting. [javac] C:\Program Files\GeoServer 1.2\server\geoserver\WEB-INF\work\WEB-INF\pages\locator_jsp.java:75: cannot resolve symbol [javac] symbol : method split (java.lang.String) [javac] location: class java.lang.String [javac] String array = forwards.split(“:”); [javac] ^ [javac] 1 error '
Login
This error appears on the Main pain Left side of the admin window at http://localhost:8080/Geoserver
[ServletException in:/WEB-INF/pages/menuator.jsp] Unable to compile class for JSP An error occurred at line: -1 in the jsp file: null Generated servlet error: [javac] Since fork is true, ignoring compiler setting. [javac] Compiling 1 source file [javac] Since fork is true, ignoring compiler setting. [javac] C:\Program Files\GeoServer 1.2\server\geoserver\WEB-INF\work\WEB-INF\pages\menuator_jsp.java:79: cannot resolve symbol [javac] symbol : method split (java.lang.String) [javac] location: class java.lang.String [javac] String array = forwards.split(“:”); [javac] ^ [javac] 1 error ’
Sorry for the late response, this slipped past my active attention.
I believe the problem is that you need a SDK (software developers kit),
not just a JRE (java run time). You can download it at
http://java.sun.com/j2se/1.4.2/download.html
Get the j2se sdk 1.4.
If that is installed I believe this should work.
(actually looking into it it appears you may have an older sdk on your
machine, you need 1.4)
best regards,
Chris
Quoting Gerald Fey <gerald_fey@anonymised.com>:
Hello,
Admin.
Config
OS: Windows XP PRO
Browser: IE 6
Java: j2re1.4.2_05
        at
        at
        at
        at
        at
        at
        at
        at
        at
        at
        at
        at
        at
        at
        at
        at
        at
        at
        at
        at
        at
        at
        at
        at
        at
        at
        at
        at
        at
        at
        at
        at
        at
        at
        at
        at
        at
        at
        at
        at
        at
        at
        at
        at
        at
        at
        at
        at
        at
        at
        at
1.2\server\geoserver\WEB-INF\work\WEB-INF\pages\/ac
setting.
cannot re
solve symbol
    [javac] String array = forwards.split(":");
    [javac] ^
    [javac] 1 error
Files\GeoServer
String array = forwards.split(":"); [javac] ^ [javac] 1 error '
Files\GeoServer
Login
Files\GeoServer
This SF.Net email is sponsored by: YOU BE THE JUDGE. Be one of 170
Project Admins to receive an Apple iPod Mini FREE for your judgement
on
who ports your project to Linux PPC the best. Sponsored by IBM.
Deadline: Sept. 24. Go here: http://sf.net/ppc_contest.php
Geoserver-devel mailing list
This mail sent through IMP: https://webmail.limegroup.com/
