Following Andrea's advice, I implemented it... but for now it works only with
absolute paths to the properties file.
On the topic, Andrea wrote "Possibly so that the path can be a
relative reference into the GeoServer data dir, would be nice to have
wktlib://mylib#star where the data dir contains $data_dir/styles/mylib.properties.
Should be doable by allowing for pluggable path resolvers of some kind... or to make it easier, just do the abstract class in GeoTools and then make a subclass in GeoServer that has the lookup logic."... which did not enlighten my way that much: could someone provide a sample of it ?
Luca Morandini
www.lucamorandini.it
