using the following WMS request :
http://localhost:8080/geoserver/wms?request=getMap&bbox=-5.37588,41.11496,10.51521,51.10804&width=548&height=520&srs=4326&format=image/png&layers=map2x0:serie_rouge,map2x0:serie_rouge,map2x0:serie_rouge&styles=sr250c,R21,sr250n&
The first WMS request and postgreSQL connexions :
postgres 1532 1 0 12:20 ? 00:00:00 /usr/bin/postmaster
postgres 1534 1532 0 12:20 ? 00:00:00 postgres: stats buffer process
postgres 1535 1534 0 12:20 ? 00:00:00 postgres: stats collector
process
postgres 1627 1532 0 12:20 ? 00:00:00 postgres: mapmaster cartes
127.0.0.1 idle in transaction
postgres 1629 1532 0 12:20 ? 00:00:00 postgres: mapmaster cartes
postgres 2852 1532 0 15:34 ? 00:00:00 postgres: mapmaster cartes
postgres 2855 1532 0 15:34 ? 00:00:00 postgres: mapmaster cartes
postgres 2857 1532 0 15:34 ? 00:00:00 postgres: mapmaster cartes
postgres 2859 1532 0 15:34 ? 00:00:00 postgres: mapmaster cartes
ricci 2865 2041 0 15:34 pts/1 00:00:00 grep postgres
The image is rendered correctly.
The second WMS (same one) shows 6 more connexions ...
Each WMS request gets 6 more connexions !
At the fifth one, I get no more response. Instead, I got a blank page with the
following log :
11966851 [ATTENTION] org.geotools.renderer.lite.LiteRenderer - Exception
org.geotools.data.DataSourceException: Could not get connection rendering
layer org.geotools.map.DefaultMapLayer@anonymised.com
at
org.geotools.data.jdbc.JDBCDataStore.getConnection(JDBCDataStore.java:930)
at
org.geotools.data.jdbc.JDBCDataStore.executeQuery(JDBCDataStore.java:795)
at
org.geotools.data.jdbc.JDBCDataStore.getFeatureReader(JDBCDataStore.java:563)
at
org.geotools.data.jdbc.JDBCFeatureSource$1.reader(JDBCFeatureSource.java:202)
at
org.geotools.renderer.lite.LiteRenderer.processStylers(LiteRenderer.java:894)
at
org.geotools.renderer.lite.LiteRenderer.paint(LiteRenderer.java:496)
at
org.vfny.geoserver.responses.wms.map.JAIMapResponse.execute(JAIMapResponse.java:294)
at
org.vfny.geoserver.responses.wms.map.GetMapDelegate.execute(GetMapDelegate.java:135)
at
org.vfny.geoserver.responses.wms.map.GetMapDelegate.execute(GetMapDelegate.java:95)
at
org.vfny.geoserver.responses.wms.GetMapResponse.execute(GetMapResponse.java:73)
at
org.vfny.geoserver.servlets.AbstractService.doService(AbstractService.java:365)
at
org.vfny.geoserver.servlets.AbstractService.doGet(AbstractService.java:233)
at javax.servlet.http.HttpServlet.service(HttpServlet.java:743)
at javax.servlet.http.HttpServlet.service(HttpServlet.java:856)
at
org.vfny.geoserver.servlets.wms.WmsDispatcher.doResponse(WmsDispatcher.java:135)
at
org.vfny.geoserver.servlets.wms.WmsDispatcher.doGet(WmsDispatcher.java:106)
at
org.apache.catalina.core.ApplicationFilterChain.internalDoFilter(ApplicationFilterChain.java:284)
at
org.apache.catalina.core.ApplicationFilterChain.doFilter(ApplicationFilterChain.java:204)
at
org.apache.catalina.core.StandardWrapperValve.invoke(StandardWrapperValve.java:257)
at
org.apache.catalina.core.StandardValveContext.invokeNext(StandardValveContext.java:151)
at
org.apache.catalina.core.StandardPipeline.invoke(StandardPipeline.java:567)
at
org.apache.catalina.core.StandardContextValve.invokeInternal(StandardContextValve.java:245)
at
org.apache.catalina.core.StandardContextValve.invoke(StandardContextValve.java:199)
at
at
at
org.apache.catalina.core.StandardHostValve.invoke(StandardHostValve.java:184)
at
at
org.apache.catalina.valves.ErrorReportValve.invoke(ErrorReportValve.java:164)
at
org.apache.catalina.core.StandardValveContext.invokeNext(StandardValveContext.java:149)
at
at
org.apache.catalina.core.StandardEngineValve.invoke(StandardEngineValve.java:156)
at
at
org.apache.catalina.valves.RequestFilterValve.process(RequestFilterValve.java:323)
at
org.apache.catalina.valves.RemoteAddrValve.invoke(RemoteAddrValve.java:131)
at
at
at
org.apache.catalina.core.ContainerBase.invoke(ContainerBase.java:972)
at
org.apache.coyote.tomcat5.CoyoteAdapter.service(CoyoteAdapter.java:206)
at
org.apache.coyote.http11.Http11Processor.process(Http11Processor.java:833)
at
org.apache.coyote.http11.Http11Protocol$Http11ConnectionHandler.processConnection(Http11Protocol.java:732)
at
org.apache.tomcat.util.net.TcpWorkerThread.runIt(PoolTcpEndpoint.java:619)
at
org.apache.tomcat.util.threads.ThreadPool$ControlRunnable.run(ThreadPool.java:688)
at java.lang.Thread.run(Thread.java:534)
Caused by: org.postgresql.util.PSQLException: Backend start-up failed: FATAL
1: Sorry, too many clients already
at
org.postgresql.jdbc1.AbstractJdbc1Connection.openConnectionV2(AbstractJdbc1Connection.java:715)
at
org.postgresql.jdbc1.AbstractJdbc1Connection.openConnectionV3(AbstractJdbc1Connection.java:323)
at
org.postgresql.jdbc1.AbstractJdbc1Connection.openConnection(AbstractJdbc1Connection.java:213)
at org.postgresql.Driver.connect(Driver.java:139)
at java.sql.DriverManager.getConnection(DriverManager.java:512)
at java.sql.DriverManager.getConnection(DriverManager.java:140)
at
org.postgresql.jdbc2.optional.BaseDataSource.getConnection(BaseDataSource.java:77)
at
org.postgresql.jdbc2.optional.BaseDataSource.getConnection(BaseDataSource.java:53)
at
org.postgresql.jdbc2.optional.ConnectionPool.getPooledConnection(ConnectionPool.java:47)
at
org.geotools.data.jdbc.ConnectionPool.getConnection(ConnectionPool.java:121)
at
org.geotools.data.jdbc.JDBCDataStore.getConnection(JDBCDataStore.java:928)
... 44 more
Any idea ?
OS: Linux
postgreSQL: 7.2
geoserver: 1.2.0rc1
didier
