[Geoserver-devel] WMS and postgreSQL connexions
I need to investigate more, but I think it may be easier than your use
of datastore David. There have been several reports of this, but all
seem to be in WMS land. Looking into the LiteRenderer, it looks to me
like the readers that are being made from the resultSet aren't being
closed anywhere, and thus the resources aren't being freed (at least
this is my guest, I've been away from the codebase for awhile and
forget exactly where the resources should be closed). Gabriel or
Andrea, could one of you look into this possibly? I still have to
figure out all my svn access and whatnot, and thus can not test and
commit. It may be as easy as adding a reader.close() line in the
processStylers() method. I can test this later with geoserver, but it
won't be for a bit, and if this is a geotools problem it should be
fixed soon.
Chris
----- Original Message -----
To: "Richard didier" <dgr@anonymised.com>
Cc: <geoserver-devel@lists.sourceforge.net>; "geotools-devel"
<geotools-devel@lists.sourceforge.net>
Sent: Monday, May 03, 2004 11:51 PM
Subject: Re: [Geoserver-devel] WMS and postgreSQL connexions
Richard and Lists,
I cross-posted this bug as I think this may be bug either in the way I
use the dataStore, or in the way the dataStore connects to the database
(GeoTools land here). Hoping some of these guys might look it over
(Jody, Chris?). I think you are hitting your thread max in you postGis
database, resulting in the error. Wondering if this has to do with the
implementation of the DataStore, or is it possible I'm not cashing the
DataStore object properly.
Thanks in advance, David
Richard didier wrote:
using the following WMS request :
http://localhost:8080/geoserver/wms?request=getMap&bbox=-5.37588,41.11496,10.51521,51.10804&width=548&height=520&srs=4326&format=image/png&layers=map2x0:serie_rouge,map2x0:serie_rouge,map2x0:serie_rouge&styles=sr250c,R21,sr250n&
The first WMS request and postgreSQL connexions :
postgres 1532 1 0 12:20 ? 00:00:00 /usr/bin/postmaster
postgres 1534 1532 0 12:20 ? 00:00:00 postgres: stats buffer
process
postgres 1535 1534 0 12:20 ? 00:00:00 postgres: stats
collector
process
postgres 1627 1532 0 12:20 ? 00:00:00 postgres: mapmaster
cartes
127.0.0.1 idle in transaction
postgres 1629 1532 0 12:20 ? 00:00:00 postgres: mapmaster
cartes
postgres 2852 1532 0 15:34 ? 00:00:00 postgres: mapmaster
cartes
postgres 2855 1532 0 15:34 ? 00:00:00 postgres: mapmaster
cartes
postgres 2857 1532 0 15:34 ? 00:00:00 postgres: mapmaster
cartes
postgres 2859 1532 0 15:34 ? 00:00:00 postgres: mapmaster
cartes
ricci 2865 2041 0 15:34 pts/1 00:00:00 grep postgres
The image is rendered correctly.
The second WMS (same one) shows 6 more connexions ...
Each WMS request gets 6 more connexions !
At the fifth one, I get no more response. Instead, I got a blank page
with the
following log :
11966851 [ATTENTION] org.geotools.renderer.lite.LiteRenderer -
Exception
org.geotools.data.DataSourceException: Could not get connection
rendering
layer org.geotools.map.DefaultMapLayer@anonymised.com
       at
org.geotools.data.jdbc.JDBCDataStore.getConnection(JDBCDataStore.java:930)
       at
org.geotools.data.jdbc.JDBCDataStore.executeQuery(JDBCDataStore.java:795)
       at
org.geotools.data.jdbc.JDBCDataStore.getFeatureReader(JDBCDataStore.java:563)
       at
org.geotools.data.jdbc.JDBCFeatureSource$1.reader(JDBCFeatureSource.java:202)
       at
org.geotools.renderer.lite.LiteRenderer.processStylers(LiteRenderer.java:894)
       at
org.geotools.renderer.lite.LiteRenderer.paint(LiteRenderer.java:496)
       at
org.vfny.geoserver.responses.wms.map.JAIMapResponse.execute(JAIMapResponse.java:294)
       at
org.vfny.geoserver.responses.wms.map.GetMapDelegate.execute(GetMapDelegate.java:135)
       at
org.vfny.geoserver.responses.wms.map.GetMapDelegate.execute(GetMapDelegate.java:95)
       at
org.vfny.geoserver.responses.wms.GetMapResponse.execute(GetMapResponse.java:73)
       at
org.vfny.geoserver.servlets.AbstractService.doService(AbstractService.java:365)
       at
org.vfny.geoserver.servlets.AbstractService.doGet(AbstractService.java:233)
       at javax.servlet.http.HttpServlet.service(HttpServlet.java:743)
       at javax.servlet.http.HttpServlet.service(HttpServlet.java:856)
       at
org.vfny.geoserver.servlets.wms.WmsDispatcher.doResponse(WmsDispatcher.java:135)
       at
org.vfny.geoserver.servlets.wms.WmsDispatcher.doGet(WmsDispatcher.java:106)
       at
org.apache.catalina.core.ApplicationFilterChain.internalDoFilter(ApplicationFilterChain.java:284)
       at
org.apache.catalina.core.ApplicationFilterChain.doFilter(ApplicationFilterChain.java:204)
       at
org.apache.catalina.core.StandardWrapperValve.invoke(StandardWrapperValve.java:257)
       at
org.apache.catalina.core.StandardValveContext.invokeNext(StandardValveContext.java:151)
       at
org.apache.catalina.core.StandardPipeline.invoke(StandardPipeline.java:567)
       at
org.apache.catalina.core.StandardContextValve.invokeInternal(StandardContextValve.java:245)
       at
org.apache.catalina.core.StandardContextValve.invoke(StandardContextValve.java:199)
       at
       at
       at
org.apache.catalina.core.StandardHostValve.invoke(StandardHostValve.java:184)
       at
       at
org.apache.catalina.valves.ErrorReportValve.invoke(ErrorReportValve.java:164)
       at
org.apache.catalina.core.StandardValveContext.invokeNext(StandardValveContext.java:149)
       at
       at
org.apache.catalina.core.StandardEngineValve.invoke(StandardEngineValve.java:156)
       at
       at
org.apache.catalina.valves.RequestFilterValve.process(RequestFilterValve.java:323)
       at
org.apache.catalina.valves.RemoteAddrValve.invoke(RemoteAddrValve.java:131)
       at
       at
       at
org.apache.catalina.core.ContainerBase.invoke(ContainerBase.java:972)
       at
org.apache.coyote.tomcat5.CoyoteAdapter.service(CoyoteAdapter.java:206)
       at
org.apache.coyote.http11.Http11Processor.process(Http11Processor.java:833)
       at
org.apache.coyote.http11.Http11Protocol$Http11ConnectionHandler.processConnection(Http11Protocol.java:732)
       at
org.apache.tomcat.util.net.TcpWorkerThread.runIt(PoolTcpEndpoint.java:619)
       at
org.apache.tomcat.util.threads.ThreadPool$ControlRunnable.run(ThreadPool.java:688)
       at java.lang.Thread.run(Thread.java:534)
Caused by: org.postgresql.util.PSQLException: Backend start-up failed:
FATAL
1: Sorry, too many clients already
       at
org.postgresql.jdbc1.AbstractJdbc1Connection.openConnectionV2(AbstractJdbc1Connection.java:715)
       at
org.postgresql.jdbc1.AbstractJdbc1Connection.openConnectionV3(AbstractJdbc1Connection.java:323)
       at
org.postgresql.jdbc1.AbstractJdbc1Connection.openConnection(AbstractJdbc1Connection.java:213)
       at org.postgresql.Driver.connect(Driver.java:139)
       at java.sql.DriverManager.getConnection(DriverManager.java:512)
       at java.sql.DriverManager.getConnection(DriverManager.java:140)
       at
org.postgresql.jdbc2.optional.BaseDataSource.getConnection(BaseDataSource.java:77)
       at
org.postgresql.jdbc2.optional.BaseDataSource.getConnection(BaseDataSource.java:53)
       at
org.postgresql.jdbc2.optional.ConnectionPool.getPooledConnection(ConnectionPool.java:47)
       at
org.geotools.data.jdbc.ConnectionPool.getConnection(ConnectionPool.java:121)
       at
org.geotools.data.jdbc.JDBCDataStore.getConnection(JDBCDataStore.java:928)
       ... 44 more
Any idea ?
OS: Linux
postgreSQL: 7.2
geoserver: 1.2.0rc1
didier
This mail sent through IMP: https://webmail.limegroup.com/
fixed soon.
Unfortunately I have the same problems, mail pick up, lack svn write
access.
Anyway, the proposed fix is the right one, I've opened a JIRA bug to
avoid forgetting about this... if it works with postgis or not,
it also depends also on the postgres cursors problems...
http://jira.codehaus.org/browse/GEOT-161
Best regards
Andrea Aime
