Hello, I am new developing in Geoserver 2.3.1 and I am writing an extension to adapt an WMS request into a non-standard WMS writen in C++, which provides an image according to their specific parameters. Searching the Geoserver documentation, I found restles services which are used to configure instances through simple HTTP calls. I was wondering if Geoserver use a Restlet service under a WMS request in order to develop a restlet service to invoke the non-standard WMS, and return the image created as response. Any suggestion?
Thanks in advance,
Eduardo
There are a few ways you could handle this. You could write a special wms
service that delegates to the external wms. Since it is an ogc service it
probably makes sense to use the existing ogc service architecture, and
mirror what the current wms service does. Some docs here:
http://docs.geoserver.org/latest/en/developer/programming-guide/ows-services/index.html
You could even override the default geoserver wms service and provide your
own. Look at the WebMapService interface as a place to start.
Hope that helps.
-Justin
2012/4/18 Eduardo de la MontaƱa <emontana@anonymised.com>
Thanks in advance,
Eduardo
Better than sec? Nothing is better than sec when it comes to
monitoring Big Data applications. Try Boundary one-second
resolution app monitoring today. Free.
http://p.sf.net/sfu/Boundary-dev2dev
Geoserver-devel mailing list
Justin Deoliveira
OpenGeo - http://opengeo.org
