[Geoserver-devel] WMS and ushort data
Dear community,
This issue refers to a fix proposed by Ville Karppinen at Finnish Meterological Institute (FMI) regarding a patch to Geotools. The fix would enable Geoserver to serve raw raster data with 16 bit data trough WMS without it being rescaled to 8 bit. This would allow the user to fully utilize the benefits of 16 bit data trough WMS.
The matter is now current again. The patch indeed works in the sense that it allows 16 bit data to be downloaded trough WMS. However, building Geoserver against the patched Geotools causes some of the unit tests in Geoserver to fail in a null pointer exception. The failing tests are in org.geoserver.wms.map.RenderedImageOutputFormatTest.java, namely testInterpolations and testInterpolationFromLayerConfig.
The issue seems to be with the transparency. The test data used in the aforementioned tests is 16 bit. Geoserver/Geotools does not handle 16 bit data with alpha, and it seems that JAI does not handle TYPE_USHORT_GRAY with an alpha channel either.
It would be very neat to be able to serve 16 bit data trough WMS in case the original data supports it.
Would anyone have any suggestions on how to handle this properly?
One suggestion is to check whether the user requested transparent data and, and rescale to 8 bit in that case. Would this approach make sense?
The patch can be seen here:
        https://github.com/asterycs/geotools/commit/307d4e2a3d0089b9c27d98ba18435599494f8c10
Best regards
Jimmy Envall
Dear Jimmy,
things are slightly more difficult than this I believe.
Going by memory, we cannot simply remove the Switch check on 16bits, we might need also to do some review at the WMS encoders in GeoServer to make sure the proper data type is chose for the proper format as most of them won’t expect us to send them 16 bits but rather 8.
There is also another bit, at the moment all the contrast enhancement operators produce 8 bits by default, this should be extended as well and would require some additional work inside the RsterSmbolizer.
If you are willing to invest some time into making this change we might be able to give some directions or the usual answer to pick someone from this page:
http://geoserver.org/support/
On Mon, Oct 2, 2017 at 12:58 PM, Envall, Jimmy C <jimmy.envall@anonymised.com> wrote:
Dear community,
Best regards
Jimmy Envall
Geoserver-devel mailing list
Geoserver-devel@anonymised.com.366…sourceforge.net
Simone Giannecchini
Visit http://goo.gl/it488V for more information.
Ing. Simone Giannecchini
@simogeo
Founder/Director
Via di Montramito 3/A
mob: +39 333 8128928
