[Geoserver-devel] WMS Direct Integration With SLD_BODY NPE
Hello All,
  I'm running up against an issue getting a NullPointerException when
I enable WMS Direct Integration then request a layer using the
SLD_BODY request parameter. This happens regardless of the content of
the SLD_BODY, regardless of which layer is requested in the SLD and
even when tile caching is disabled for the layer requested. When I
drop the SLD_BODY in favor of a LAYERS parameter everything goes back
to normal.
As soon as I turn the direct integration off, this issue goes away. I
have this same problem on Geoserver v2.11.1 and v2.10.0 but NOT in
2.9.1.
Details are below. Thanks in advance for any assistance you can provide!
Example Request:
http://localhost:8080/geoserver/wms?service=wms&version=1.1.0&REQUEST=GetMap&FORMAT=image/png&TILED=true&WIDTH=256&HEIGHT=256&SRS=EPSG:900913&TRANSPARENT=true&bbox=-13149614.849955441,3991847.365165045,-13139830.910334937,4001631.3047855473&viewparams=ids:3\,24\,5\,6\;year:2002;&sld_body=<%3Fxml%20version%3D"1.0"%20encoding%3D"UTF-8"%3F> <StyledLayerDescriptor%20version%3D"1.0.0"%20 xsi%3AschemaLocation%3D"http%3A%2F%2Fwww.opengis.net%2Fsld%20StyledLayerDescriptor.xsd"%20 xmlns%3D"http%3A%2F%2Fwww.opengis.net%2Fsld"%20 xmlns%3Aogc%3D"http%3A%2F%2Fwww.opengis.net%2Fogc"%20 xmlns%3Axlink%3D"http%3A%2F%2Fwww.w3.org%2F1999%2Fxlink"%20 xmlns%3Axsi%3D"http%3A%2F%2Fwww.w3.org%2F2001%2FXMLSchema-instance"> <NamedLayer> <Name>Students<%2FName> <UserStyle> <Title>Default%20Point<%2FTitle> <Abstract>A%20sample%20style%20that%20draws%20a%20point<%2FAbstract> <FeatureTypeStyle> <Rule> <Name>rule1<%2FName> <Title>Red%20Square<%2FTitle> <Abstract>A%206%20pixel%20square%20with%20a%20red%20fill%20and%20no%20stroke<%2FAbstract> <PointSymbolizer> <Graphic> <Mark> <WellKnownName>square<%2FWellKnownName> <Fill> <CssParameter%20name%3D"fill">%23FF0000<%2FCssParameter> <%2FFill> <%2FMark> <Size>6<%2FSize> <%2FGraphic> <%2FPointSymbolizer> <%2FRule> <%2FFeatureTypeStyle> <%2FUserStyle> <%2FNamedLayer> <%2FStyledLayerDescriptor>
Results in:
2017-05-30 17:54:10,267 ERROR [geoserver.ows] -
java.lang.NullPointerException
at org.geoserver.gwc.GWC.dispatch(GWC.java:668)
at org.geoserver.gwc.wms.CachingWebMapService.invoke(CachingWebMapService.java:84)
at org.geoserver.gwc.wms.CachingWebMapService.invoke(CachingWebMapService.java:55)
at org.springframework.aop.framework.ReflectiveMethodInvocation.proceed(ReflectiveMethodInvocation.java:179)
at org.geoserver.ows.util.RequestObjectLogger.invoke(RequestObjectLogger.java:55)
at org.springframework.aop.framework.JdkDynamicAopProxy.invoke(JdkDynamicAopProxy.java:208)
at com.sun.proxy.$Proxy59.getMap(Unknown Source)
at sun.reflect.GeneratedMethodAccessor254.invoke(Unknown Source)
at sun.reflect.DelegatingMethodAccessorImpl.invoke(Unknown Source)
at java.lang.reflect.Method.invoke(Unknown Source)
at org.geoserver.ows.Dispatcher.execute(Dispatcher.java:857)
at org.geoserver.ows.Dispatcher.handleRequestInternal(Dispatcher.java:268)
at org.springframework.web.servlet.mvc.AbstractController.handleRequest(AbstractController.java:147)
at org.springframework.web.servlet.mvc.SimpleControllerHandlerAdapter.handle(SimpleControllerHandlerAdapter.java:50)
at org.springframework.web.servlet.DispatcherServlet.doDispatch(DispatcherServlet.java:959)
at org.springframework.web.servlet.DispatcherServlet.doService(DispatcherServlet.java:893)
at org.springframework.web.servlet.FrameworkServlet.processRequest(FrameworkServlet.java:968)
at org.springframework.web.servlet.FrameworkServlet.doGet(FrameworkServlet.java:859)
at javax.servlet.http.HttpServlet.service(HttpServlet.java:635)
at org.springframework.web.servlet.FrameworkServlet.service(FrameworkServlet.java:844)
at javax.servlet.http.HttpServlet.service(HttpServlet.java:742)
at org.apache.catalina.core.ApplicationFilterChain.internalDoFilter(ApplicationFilterChain.java:231)
at org.apache.catalina.core.ApplicationFilterChain.doFilter(ApplicationFilterChain.java:166)
at org.apache.tomcat.websocket.server.WsFilter.doFilter(WsFilter.java:53)
at org.apache.catalina.core.ApplicationFilterChain.internalDoFilter(ApplicationFilterChain.java:193)
at org.apache.catalina.filters.CorsFilter.handleNonCORS(CorsFilter.java:410)
at org.apache.catalina.filters.CorsFilter.doFilter(CorsFilter.java:169)
at org.geoserver.filters.ThreadLocalsCleanupFilter.doFilter(ThreadLocalsCleanupFilter.java:28)
at org.geoserver.filters.SpringDelegatingFilter$Chain.doFilter(SpringDelegatingFilter.java:75)
at org.geoserver.wms.animate.AnimatorFilter.doFilter(AnimatorFilter.java:71)
at org.geoserver.filters.SpringDelegatingFilter$Chain.doFilter(SpringDelegatingFilter.java:71)
at org.geoserver.flow.controller.IpBlacklistFilter.doFilter(IpBlacklistFilter.java:94)
at org.geoserver.flow.ControlFlowCallback.doFilter(ControlFlowCallback.java:245)
at org.geoserver.filters.SpringDelegatingFilter.doFilter(SpringDelegatingFilter.java:46)
at org.geoserver.platform.AdvancedDispatchFilter.doFilter(AdvancedDispatchFilter.java:50)
at org.springframework.security.web.FilterChainProxy$VirtualFilterChain.doFilter(FilterChainProxy.java:316)
at org.geoserver.security.filter.GeoServerCompositeFilter$NestedFilterChain.doFilter(GeoServerCompositeFilter.java:69)
at org.springframework.security.web.access.intercept.FilterSecurityInterceptor.invoke(FilterSecurityInterceptor.java:126)
at org.springframework.security.web.access.intercept.FilterSecurityInterceptor.doFilter(FilterSecurityInterceptor.java:90)
at org.geoserver.security.filter.GeoServerCompositeFilter$NestedFilterChain.doFilter(GeoServerCompositeFilter.java:73)
at org.geoserver.security.filter.GeoServerCompositeFilter.doFilter(GeoServerCompositeFilter.java:92)
at org.springframework.security.web.FilterChainProxy$VirtualFilterChain.doFilter(FilterChainProxy.java:330)
at org.springframework.security.web.access.ExceptionTranslationFilter.doFilter(ExceptionTranslationFilter.java:114)
at org.geoserver.security.filter.GeoServerAnonymousAuthenticationFilter.doFilter(GeoServerAnonymousAuthenticationFilter.java:54)
at org.springframework.security.web.authentication.www.BasicAuthenticationFilter.doFilterInternal(BasicAuthenticationFilter.java:158)
at org.springframework.web.filter.OncePerRequestFilter.doFilter(OncePerRequestFilter.java:107)
at org.geoserver.security.filter.GeoServerBasicAuthenticationFilter.doFilter(GeoServerBasicAuthenticationFilter.java:84)
at org.springframework.security.web.context.SecurityContextPersistenceFilter.doFilter(SecurityContextPersistenceFilter.java:91)
at org.geoserver.security.filter.GeoServerSecurityContextPersistenceFilter$1.doFilter(GeoServerSecurityContextPersistenceFilter.java:53)
at org.springframework.security.web.FilterChainProxy.doFilterInternal(FilterChainProxy.java:213)
at org.springframework.security.web.FilterChainProxy.doFilter(FilterChainProxy.java:176)
at org.geoserver.security.GeoServerSecurityFilterChainProxy.doFilter(GeoServerSecurityFilterChainProxy.java:152)
at org.springframework.web.filter.DelegatingFilterProxy.invokeDelegate(DelegatingFilterProxy.java:346)
at org.springframework.web.filter.DelegatingFilterProxy.doFilter(DelegatingFilterProxy.java:262)
at org.geoserver.filters.LoggingFilter.doFilter(LoggingFilter.java:87)
at org.geoserver.filters.XFrameOptionsFilter.doFilter(XFrameOptionsFilter.java:89)
at org.geoserver.filters.GZIPFilter.doFilter(GZIPFilter.java:42)
at org.geoserver.filters.SessionDebugFilter.doFilter(SessionDebugFilter.java:48)
at org.geoserver.filters.FlushSafeFilter.doFilter(FlushSafeFilter.java:44)
at org.springframework.web.filter.CharacterEncodingFilter.doFilterInternal(CharacterEncodingFilter.java:121)
at org.apache.catalina.core.StandardWrapperValve.invoke(StandardWrapperValve.java:199)
at org.apache.catalina.core.StandardContextValve.invoke(StandardContextValve.java:96)
at org.apache.catalina.authenticator.AuthenticatorBase.invoke(AuthenticatorBase.java:475)
at org.apache.catalina.core.StandardHostValve.invoke(StandardHostValve.java:140)
at org.apache.catalina.valves.ErrorReportValve.invoke(ErrorReportValve.java:80)
at org.apache.catalina.valves.RequestFilterValve.process(RequestFilterValve.java:319)
at org.apache.catalina.valves.RemoteAddrValve.invoke(RemoteAddrValve.java:88)
at org.apache.catalina.valves.AbstractAccessLogValve.invoke(AbstractAccessLogValve.java:624)
at org.apache.catalina.core.StandardEngineValve.invoke(StandardEngineValve.java:87)
at org.apache.catalina.connector.CoyoteAdapter.service(CoyoteAdapter.java:342)
at org.apache.coyote.http11.Http11Processor.service(Http11Processor.java:498)
at org.apache.coyote.AbstractProcessorLight.process(AbstractProcessorLight.java:66)
at org.apache.coyote.AbstractProtocol$ConnectionHandler.process(AbstractProtocol.java:796)
at org.apache.tomcat.util.net.NioEndpoint$SocketProcessor.doRun(NioEndpoint.java:1366)
at org.apache.tomcat.util.net.SocketProcessorBase.run(SocketProcessorBase.java:49)
at java.util.concurrent.ThreadPoolExecutor.runWorker(Unknown Source)
at java.util.concurrent.ThreadPoolExecutor$Worker.run(Unknown Source)
at org.apache.tomcat.util.threads.TaskThread$WrappingRunnable.run(TaskThread.java:61)
at java.lang.Thread.run(Unknown Source)
