[Geoserver-devel] WMS GetLegendGraphic
Hi, I would like to propose a couple of new options for the GetLegendGraphic WMS request:
  • labelMargin, to set the margin between icons and the related labels; I would use a default of 2/3 pixels so that labels have a small distance from the icons; currently for icons that are filling the given space (usually external images) there is no space between the icon and the label
An example with the (default) 3 pixels:
Immagine incorporata 3
An example with a 10 pixels margin:
Immagine incorporata 4
  • absoluteMargins (true|false): this is for raster legends; currently a proportional margin is applied, so that space between columns depends (for example) from labels text length; when absoluteMargins is true, I would use a fixed space margin (configurable with the already existing dx option); I would also switch to absolute margins by default (I don’t really understand the usage of proportional space between columns)
An example with proportional margins:
Immagine incorporata 2
With absolute margins I would get:
Immagine incorporata 1
Any thoughts?
Mauro
Dott. Mauro Bartolomeoli
@mauro_bart
Senior Software Engineer
Via di Montramito 3/A
Hi Mauro,
looks good to me. I’m just wondering about the labelMargin vs dx, like, would it make sense to use the same name of options across
raster and vector, or is it not possible due to different semantics?
(attachments)
On Thu, Oct 27, 2016 at 2:28 PM, Mauro Bartolomeoli <mauro.bartolomeoli@anonymised.com> wrote:
Any thoughts?
Mauro
@mauro_bart
The Command Line: Reinvented for Modern Developers
Did the resurgence of CLI tooling catch you by surprise?
Reconnect with the command line and become more productive.
Learn the new .NET and ASP.NET CLI. Get your free copy!
http://sdm.link/telerik
Geoserver-devel mailing list
Geoserver-devel@anonymised.com.366…sourceforge.net
Ing. Andrea Aime
@geowolf
Technical Lead
mob: +39 339 8844549
Hi Andrea, I will check if there is any conflict, and eventually use dx for both.
Thanks
Mauro
(attachments)
2016-10-30 11:24 GMT+01:00 Andrea Aime <andrea.aime@anonymised.com>:
Hi Mauro,
On Thu, Oct 27, 2016 at 2:28 PM, Mauro Bartolomeoli <mauro.bartolomeoli@anonymised.comsolutions.it> wrote:
Any thoughts?
Mauro
@mauro_bart
Geoserver-devel@anonymised.comrge.net
Ing. Andrea Aime
@geowolf
Technical Lead
@mauro_bart
unfortunately there is a conflict, so I need to mantain the labelMargin option.
Here is the PR: https://github.com/geoserver/geoserver/pull/1940
Mauro
(attachments)
2016-11-02 9:34 GMT+01:00 Mauro Bartolomeoli <mauro.bartolomeoli@anonymised.com>:
Thanks
Mauro
Hi Mauro,
@mauro_bart
On Thu, Oct 27, 2016 at 2:28 PM, Mauro Bartolomeoli <mauro.bartolomeoli@anonymised.comons.it> wrote:
Any thoughts?
Mauro
@mauro_bart
Ing. Andrea Aime
@geowolf
Technical Lead
@mauro_bart
