On Fri, Jan 2, 2015 at 8:51 PM, Andrea Aime <andrea.aime@anonymised.com>
wrote:
I disagree, GeoTools stores are not just used by GetMap, they have to work
properly
no matter what the client is.
Your suggestion makes sense only when there is one calling point and many
stores, but in fact
we have a many to many situation and no control over the client code
(GeoTools wise at least).
Thinking about it a bit more, there are also stores that are not written
inside GeoTools and that
we cannot vet for sanity or good practices in general, so having also the
client code
buliding filters do a round of simplification might also make sense.
Streaming renderer does it because it makes a lenghtly combination of rule
filters in OR,
generating a possibly very complex filter that makes some databases choke.
I believe streaming renderer was the first user of the simplifier, and I
made the same reasoning
as you, "hard to apply it to every store, I'll change the renderer instead".
Today the situation is a bit the opposite, new stores not used in demanding
production
environments do not use the simplifier, but the important ones do.
And the GetMap chain ends in the streaming renderer, which should be doing
a step of
simplification.
So all things being equal, I prefer to have the store do the right thing,
and at most, if really
necessary, do an extra step of simplification in GetMap.
Given PropertyDataStore should mimick to the best possible the JDBC ones
(the production
ones), I'd still suggest to have at least the simplfication running in the
store code
Please, notice that GeoSolutions will be closed for seasonal holidays
from December the 24th to January the 6th
Ing. Andrea Aime
@geowolf
Technical Lead
Via Poggio alle Viti 1187
mob: +39 339 8844549
