[Geoserver-devel] WMS Layers Out of Alignment
I have installed Geoserver 1.7.0 and installed the Geowebcache plugin which is listed on the Geoserver datastore extensions area for geoserver 1.7.0 - http://geoserver.org/display/GEOS/GeoServer+1.7.0 - http://downloads.sourceforge.net/geoserver/geoserver-1.7.0-gwc-plugin.zip
When using the geoserver WMS directly my layers appear fine, with a google map client. But, when using the GWC wms service, my layers appear out of alignment. I also have this strange thing where my layer is displayed twice on the map, in 2 different geographical locations depending on the zoom level. Very strange.
I have attached screenshots of my alignment problem.
The request for the non aligned layer:
http://[hostname]/geoserver/gwc/service/wms?&REQUEST=GetMap&SERVICE=WMS&VERSION=1.1.1&LAYERS=[layer-name]&FORMAT=image/png&BGCOLOR=0xFFFFFF&TRANSPARENT=TRUE&SRS=EPSG:4326&BBOX=138.66943359375,-18.79191774423444,138.69140625,-18.77111506233701&WIDTH=256&HEIGHT=256
The request for the aligned layer:
http://[hostname]/geoserver/wms?&REQUEST=GetMap&SERVICE=WMS&VERSION=1.1.1&LAYERS=[layer-name]&FORMAT=image/png&BGCOLOR=0xFFFFFF&TRANSPARENT=TRUE&SRS=EPSG:4326&BBOX=138.7353515625,-18.687878686034182,138.779296875,-18.646245142670608&WIDTH=256&HEIGHT=256
Any help you could give me, or some reasoning as to why this is happening would be greatly appreciated. I have read the following post, but the issue appears to still be in limbo - http://www.nabble.com/out-of-phase-tiles…-td16479491.html
cheers
Mat
Mathew Wyatt
Software Engineer, CSIRO Exploration and Mining
Australian Resources Research Centre
26 Dick Perry Ave, Kensington WA 6151, Australia
(attachments)
