Andrea,
This looks like precisely what I was looking for but having trouble finding. Thanks a ton for assisting me in pinpointing how I needed to interface with the system.
Thanks again,
David Marks
From: Andrea Aime <andrea.aime@anonymised.com<mailto:andrea.aime@anonymised.com>>
Date: Monday, December 8, 2014 at 9:21 AM
To: David Marks <david.marks@anonymised.com<mailto:david.marks@anonymised.com>>
Cc: Geoserver-devel <geoserver-devel@lists.sourceforge.net<mailto:geoserver-devel@lists.sourceforge.net>>
Subject: Re: [Geoserver-devel] WMS Request Intercept Extension
On Mon, Dec 8, 2014 at 2:12 PM, Marks, David <David.Marks@anonymised.com<mailto:David.Marks@anonymised.com>> wrote:
Good morning GeoServer-devel,
For a project I am currently working on I need to intercept incoming WMS getCapabilities/getMap requests and their outbound responses in order to perform some arbitrary pre- and post-processing. Is inserting my control flow into the WMS request/response capable via GeoServer extensions and, if so, could anyone provide some help in identifying the programmatic hooks I should be grabbing onto in order to get that level of control? If not, could I use a side-servlet to capture incoming responses and pass them to GeoServer programmatically? Again, if yes, identification of what classes/methods provide said access would aid me greatly.
The generic OGC service lifecycle callback is called DispatcherCallback:
https://github.com/geoserver/geoserver/blob/793476e348e906a2ee9db8fa8f73a4fb464f3288/src/ows/src/main/java/org/geoserver/ows/DispatcherCallback.java
There are several instances of these in GeoServer, for example to monitor and log requests:
https://github.com/geoserver/geoserver/blob/793476e348e906a2ee9db8fa8f73a4fb464f3288/src/extension/monitor/core/src/main/java/org/geoserver/monitor/ows/MonitorCallback.java
to check security:
https://github.com/geoserver/geoserver/blob/793476e348e906a2ee9db8fa8f73a4fb464f3288/src/main/src/main/java/org/geoserver/security/OperationSecurityCallback.java
or to manipulate requests:
https://github.com/geoserver/geoserver/blob/793476e348e906a2ee9db8fa8f73a4fb464f3288/src/community/wms-eo/src/main/java/org/geoserver/wms/eo/EOGetFeatureInfoChecker.java
All of them are registered in the Spring applicationContext.xml file contained in the same module.
The main advantage of these is that you get the request already parsed into a Java object, which is handy since each OGC
request can be sent in a variety of ways. If instead you want something lower level, you can always implement a ServletFilter
Please, notice that GeoSolutions will be closed for seasonal holidays
from December the 24th to January the 6th
Ing. Andrea Aime
@geowolf
Technical Lead
Via Poggio alle Viti 1187
mob: +39 339 8844549
The information in this message and/or attachments, is intended solely for the attention and use of the named addressee(s) and may be confidential or proprietary in nature or covered by the provisions of privacy act (Legislative Decree June, 30 2003, no.196 - Italy's New Data Protection Code).Any use not in accord with its purpose, any disclosure, reproduction, copying, distribution, or either dissemination, either whole or partial, is strictly forbidden except previous formal approval of the named addressee(s). If you are not the intended recipient, please contact immediately the sender by telephone, fax or e-mail and delete the information in this message that has been received in error. The sender does not give any warranty or accept liability as the content, accuracy or completeness of sent messages and accepts no responsibility for changes made after they were sent or for other risks which arise as a result of e-mail transmission, viruses, etc.
