[Geoserver-devel] WMS . SLD and filter
a quick question - have been playing with a branch (complex-features) based on RC1.5 - and I've noticed that the application of Filters in SLD requests to WMS (using SLD_BODY) seems to apply the filter AFTER selecting all the data from the database, which is a little sad really when you want to display a few elements from millions...
I found the following "For WMS queries, the Filter parameters are handled in both PostGIS and
GeoServer. GeoServer makes a request to PostGIS for all the features
that intersect the view rectangle. It also makes a set of Rules that are
valid for the current scale range.
Once it has those features, it runs the filters on them on the GeoServer
side, as there might be several filters and else clauses."
from Brent which seems to imply its a design decision.
Is there any way around this currently? Any ideas on how hard it might be to fix this - say to apply the filter at the server side if there is only one Rule present? (The client can then at least send multiple SLD's with single rules - would fix the 80% cases and provide a workaround for the 20%)
Rob Atkinson
For SQL datastores, I'd suggest that each Filter of a Rule in SLD should
(or could?) be translated into the where clause. For instance: select *
from foo where [spatialCondition] and ([conditionsOfRule1] or
[conditionsOfRule2] or [conditionsOfRule3]). This should return only the
data that is needed and only 1 SQL-statement is used.
But maybe it's easier to have one SQL-statement per Filter, because WFS is
working that way now. If one sends a
GetFeature-request for each featuretype an SQL-statement is constructed.
The results are combined in one featurecollection. Something similar could
be made for WMS/SLD I think.
In my opinion, rather not implement this for only one filter per SLD.
Would break with the SLD specs...
And what about the optimizedDataLoadingEnabled-option in
queryLayer(MapLayer currLayer, Envelope envelope) in LiteRenderer2? Is
that used or otherwise useful here?
Thijs
-----Original Message-----
To: Geoserver-devel <geoserver-devel@lists.sourceforge.net>
Date: Fri, 23 Dec 2005 23:59:36 +1100
Subject: [Geoserver-devel] WMS . SLD and filter
SLD
are
might
SLD's
for
the 20%)
Rob Atkinson
This SF.net email is sponsored by: Splunk Inc. Do you grep through log
files
for problems? Stop! Download the new AJAX search engine that makes
searching your log files as easy as surfing the web. DOWNLOAD SPLUNK!
http://ads.osdn.com/?ad_id=7637&alloc_id=16865&op=click
Geoserver-devel mailing list
Quoting Thijs Brentjens <thijs.brentjens@anonymised.com>:
should
the
Yes, this improvement is needed. I think David said the reason we're
not doing it is because of the 'else' thing, which we don't have in
WFS, and which basically means you'd want everything - anything that
doesn't match any of the first filter rules. But I think we can be
smarter about it, as there are many times when people use SLD rules
that don't have an else, and some can get huge performance gains. I
think Alessio started to look into this, maybe he can let us know what
might need to be done.
WFS is
constructed.
could
It's actually a lot better to make just one statement, as there's a
decent bit of overhead to make a db connection - the number of db
requests should be minimized as much as possible. I would actually say
that a WMS request as one filter mirrors a WFS getFeature request. If
you request multiple WMS layers, then we would have to make multiple
requests, but we shouldn't have to for a single layer. This is how WFS
works, for each featureType a sql statement is made, not for each
filter - you can have many filters anded and ored together. So too
should a single SLD based request figure out how to pass which filters
in, and figure out which filters to deal with in code. This will take
a decent bit of work, it's tricky code, but it should pay off in terms
of performance gains. I imagine it would take someone who knows the
code 3-5 days to make it solid. And I think you could maybe get some
quick performance gains, like for sld files that just have one rule,
relatively quickly.
Is
Looks like all that does is send the bounding box to the datastore, and
only get attributes that are used by the stylers. So it's already
being used in geoserver.
Chris
Thijs
> Hi,
(complex-features)
in
> SLD
really
features
that
> are
> GeoServer
> might
there is
> SLD's
workaround
> for
> the 20%)
> Rob Atkinson
log
> files
makes
SPLUNK!
> https://lists.sourceforge.net/lists/listinfo/geoserver-devel
log files
SPLUNK!
This mail sent through IMP: https://webmail.limegroup.com/
On 12/23/05, Chris Holmes <cholmes@...13...> wrote:
Quoting Thijs Brentjens <thijs.brentjens@...467...>:
> Hi,
> should
> the
As Chris implied, the translation of the Filter to SQL statement is
already present in WFS.
Currently, I use a hack (creating a view dynamically in the db) for
selecting only desired geometries during a WMS request. It is much
much quicker, esp for large tables. But what happens if 2 or more
people make a WMS request at the same time? Hmm...
I would love to be able to use a good working solution, where the
filter is part of the SQL statement.
Alex
