the GeoServer WMS is not behaving as standard mandates when an invalid dimension
value is provided. Since day one of dimension support, by giving a dimension value that
does not match any one available, one just gets an empty map.
Now, the specification says instead:
If nearest match is enabled, just return the nearest (the search radius and the ability to throw exceptions if outside of the nearest radius are useful, but not compliant)
If nearest is not enabled and the value does not match, throw an InvalidDimensionException instead.
Now, technically implementing point 2 is a fix… but the GeoServer behavior has been different for the past 10+ years.
I’d say:
Implement the behavior controlled by a WMS admin page flag
Default behavior for main branch, make it standard compliant
Default behavior for other branches, make it match the historical behavior
Allow people to flip the flag as they see fit
Opinions?
As discussed in the PMC meeting a couple weeks ago, I think the behaviour should also be able to be configured by a system property / environment variable.
Torben
