On Mon, 2009-07-13 at 10:53 -0700, jjmbv wrote:
Thanks for the quick answers.
That makes sense. I did what you said but still i have no results.
I'm trying to run a very simple example just like the one i posted earlier.
I built an foo.xlm
<layout>
<decoration type="image" affinity="bottom,right" offset="6,6"
size="124,124">
<option name="url" value="testDecoration.png"/>
</decoration>
<decoration type="scaleratio" affinity="bottom,right" offset="36,6"
size="200,130"/>
<!--<decoration type="legend" affinity="top,left" offset="6,6"
size="auto"/>-->
</layout>
and an image 'testDecoration.png'.
They are both placed in Geoserver 'data' folder along with catalog.xml and
services.xml.
The layout definition files belong in their own directory, layouts. So
it will look like this:
DATA_DIR
+ catalog.xml
+ services.xml
+ layouts/
+ foo.xml
Then i tested the GET request and still no result.
Can you see what am I missing here?
Thank you.
David Winslow-5 wrote:
> The layout feature is only supported for image file formats, not the
> more complex ones such as OpenLayers or Google Earth. Try replacing
> 'application/openlayers' with 'image/png'.
> David Winslow
> OpenGeo - http://opengeo.org/
> On Mon, 2009-07-13 at 10:17 -0700, jjmbv wrote:
>> Hi there..
>> I'm new at this so, having set the layout definition (in my case foo.xlm)
>> and running Geoserver 1.7.5 as you said, if i just add this
>> '&format_options=layout:foo' to my wms GET request url (in my case
>> http://localhost:8080/Geoserver/wms?bbox=-159910.79138881035,-535377.6074146815,716762.6191650174,4633982.90225693&styles=&Format=application/openlayers&request=GetMap&version=1.1.1&layers=cd_gs:test&width=350&height=550&srs=EPSG:27492&format_options=layout:foo)
>> should i be able to see any results?
>> I'm following this
>> 'http://docs.geoserver.org/1.7.5/user/advanced/wmsdecoration.html’ as a
>> guide, but i'm not seeing any evident result.
>> Perhaps I'm doing something wrong or forgetting some details?
>> Thanks once more.
>> > On Mon, 2009-07-13 at 07:57 -0700, jjmbv wrote:
>> >> Hi there,
>> >> I've just checked out Geoserver source code from SVN
>> >> (https://svn.codehaus.org/geoserver/tags/1.7.4/) and i failed to find
>> the
>> >> wmslayout module in the community folder.
>> >> I looked into other releases, and that module isn't there either.
>> >> Is it still there? Am I looking in the wrong place?
>> >> Thanks in advance.
>> > The WMS Layout feature is no longer an extension. You don't have to do
>> > anything except for define a layout definition for it to work on 1.7.5
>> > and 2.0beta1.
>> > Hope this helps.
>> > David Winslow
>> > Enter the BlackBerry Developer Challenge
>> > This is your chance to win up to $100,000 in prizes! For a limited
>> time,
>> > vendors submitting new applications to BlackBerry App World(TM) will
>> have
>> > the opportunity to enter the BlackBerry Developer Challenge. See full
>> > prize
>> > details at: http://p.sf.net/sfu/Challenge
>> > _______________________________________________
>> > Geoserver-devel mailing list
>> > Geoserver-devel@lists.sourceforge.net
>> > https://lists.sourceforge.net/lists/listinfo/geoserver-devel
> This is your chance to win up to $100,000 in prizes! For a limited time,
> vendors submitting new applications to BlackBerry App World(TM) will have
> prize
View this message in context: http://www.nabble.com/wmslayout-community-module-tp24463346p24466340.html
Sent from the GeoServer - Dev mailing list archive at Nabble.com.
the opportunity to enter the BlackBerry Developer Challenge. See full prize
