[Geoserver-devel] Worried about proposed change to home page
our home page at geoserver.org sports a map build with geoserver, and backed by demo.opengeo.org
The server has been down for a while and Jody is now proposing a replacement here:
https://github.com/geoserver/geoserver.github.io/pull/42/files
What worries me is that, while the map seems indeed to have been drawn by the StreamingRenderer,
it has no marks of GeoServer or GeoWebCache in the URL or response, see for example here:
http://api.boundlessgeo.io/v1/basemaps/boundless/osm/13/2413/5114.png
curl -D - -o /dev/null “http://api.boundlessgeo.io/v1/basemaps/boundless/osm/13/2413/5114.png
% Total % Received % Xferd Average Speed Time Time Time Current
Dload Upload Total Spent Left Speed
0 0 0 0 0 0 0 0 --:–:-- --:–:-- --:–:-- 0HTTP/1.1 200
Cache-Control: no-cache, no-store, max-age=0, must-revalidate
Content-Type: image/png
Expires: 0
Pragma: no-cache
X-Application-Context: connect-gateway:8080
X-Content-Type-Options: nosniff
X-Frame-Options: DENY
X-XSS-Protection: 1; mode=block
transfer-encoding: chunked
Connection: keep-alive
If nobody has the resources to keep up a sample map I’d suggest we remove the
map, rather than having it powered by a vendor API and right below it state:
“GeoServer is a OGC compliant implementation of a number of open standards such as Web Feature Service (WFS), Web Map Service (WMS), and Web Coverage Service (WCS).
Additional formats and publication options are available including Web Map Tile Service (WMTS) and extensions for Catalogue Service (CSW) and Web Processing Service (WPS).”
Ing. Andrea Aime
@geowolf
Technical Lead
Via di Montramito 3/A
mob: +39 339 8844549
I will see if I can find a more dirt URL. I think that tile set is fully generated.
http://tiles.boundlessgeo.com/tms/1.0.0
On Fri, Feb 24, 2017 at 5:02 AM Andrea Aime <andrea.aime@anonymised.com> wrote:
Date: Fri, 24 Feb 2017 09:12:53 GMT
Expires: 0
Pragma: no-cache
Ing. Andrea Aime
@geowolf
Technical Lead
engaging tech sites, SlashDot.org! http://sdm.link/slashdot_______________________________________________
Geoserver-devel mailing list
Jody Garnett
Dear Jody,
I would not mind exposing a "real" GeoServer.
I would be happy to sponsor a machine somewhere where we actually
deploy geoserver with some live data.
It can be a small dedicated server or a VM or something on AWS.
Opinions?
Simone Giannecchini
Visit http://goo.gl/it488V for more information.
Ing. Simone Giannecchini
@simogeo
Founder/Director
mob: +39 333 8128928
nel/i file/s allegato/i sono da considerarsi strettamente riservate.
Il loro utilizzo è consentito esclusivamente al destinatario del
messaggio, per le finalità indicate nel messaggio stesso. Qualora
riceviate questo messaggio senza esserne il destinatario, Vi preghiamo
cortesemente di darcene notizia via e-mail e di procedere alla
distruzione del messaggio stesso, cancellandolo dal Vostro sistema.
Conservare il messaggio stesso, divulgarlo anche in parte,
distribuirlo ad altri soggetti, copiarlo, od utilizzarlo per finalità
diverse, costituisce comportamento contrario ai principi dettati dal
D.Lgs. 196/2003.
The information in this message and/or attachments, is intended solely
for the attention and use of the named addressee(s) and may be
confidential or proprietary in nature or covered by the provisions of
privacy act (Legislative Decree June, 30 2003, no.196 - Italy's New
Data Protection Code).Any use not in accord with its purpose, any
disclosure, reproduction, copying, distribution, or either
dissemination, either whole or partial, is strictly forbidden except
previous formal approval of the named addressee(s). If you are not the
intended recipient, please contact immediately the sender by
telephone, fax or e-mail and delete the information in this message
that has been received in error. The sender does not give any warranty
or accept liability as the content, accuracy or completeness of sent
messages and accepts no responsibility for changes made after they
were sent or for other risks which arise as a result of e-mail
transmission, viruses, etc.
On Fri, Feb 24, 2017 at 6:48 PM, Jody Garnett <jody.garnett@anonymised.com> wrote:
generated.
wrote:
replacement here:
for example here:
"http://api.boundlessgeo.io/v1/basemaps/boundless/osm/13/2413/5114.png&quot;
Current
Speed
  0 0 0 0 0 0 0 0 --:--:-- --:--:-- --:--:--
0HTTP/1.1 200
Expires: 0
Pragma: no-cache
If nobody has the resources to keep up a sample map I'd suggest we remove
the
state:
"GeoServer is a OGC compliant implementation of a number of open standards
Service (WCS).
Processing Service (WPS)."
Ing. Andrea Aime
@geowolf
Technical Lead
nel/i file/s allegato/i sono da considerarsi strettamente riservate. Il loro
utilizzo è consentito esclusivamente al destinatario del messaggio, per le
finalità indicate nel messaggio stesso. Qualora riceviate questo messaggio
senza esserne il destinatario, Vi preghiamo cortesemente di darcene notizia
via e-mail e di procedere alla distruzione del messaggio stesso,
cancellandolo dal Vostro sistema. Conservare il messaggio stesso, divulgarlo
anche in parte, distribuirlo ad altri soggetti, copiarlo, od utilizzarlo per
finalità diverse, costituisce comportamento contrario ai principi dettati
dal D.Lgs. 196/2003.
information in this message that has been received in error. The sender does
not give any warranty or accept liability as the content, accuracy or
Check out the vibrant tech community on one of the world's most
Jody Garnett
I am fine; I just want not to have a hole in our website.
On 24 February 2017 at 13:36, Simone Giannecchini <simone.giannecchini@anonymised.com> wrote:
Dear Jody,
I would not mind exposing a “real” GeoServer.
Opinions?
Simone Giannecchini
@simogeo
Founder/Director
D.Lgs. 196/2003.
privacy act (Legislative Decree June, 30 2003, no.196 - Italy’s New
generated.
wrote:
replacement here:
for example here:
Current
Speed
0 0 0 0 0 0 0 0 --:–:-- --:–:-- --:–:–
0HTTP/1.1 200
Expires: 0
Pragma: no-cache
the
state:
Service (WCS).
Ing. Andrea Aime
@geowolf
Technical Lead
(Legislative Decree June, 30 2003, no.196 - Italy’s New Data Protection
Geoserver-devel@anonymised.comsourceforge.net
Jody Garnett
Jody Garnett
I have configured it with a working geoserver / gwc url - what I can use a hand with is filling out the list of cities to be world wide (rather than just Canadian).
On 24 February 2017 at 02:00, Andrea Aime <andrea.aime@anonymised.com> wrote:
Expires: 0
Pragma: no-cache
Ing. Andrea Aime
@geowolf
Technical Lead
Geoserver-devel@anonymised.com.366…sourceforge.net
Jody Garnett
