Hi
Does anyone know where I can get the WPS code from? Ie. JTS:intersection?
Dominique Bessette
Engineer, Software
General Dynamics Information Technology
Supporting Fleet Numerical Meteorology and Oceanography Center (FNMOC)
Office: 619-881-2748
If it’s just the JTS code you want you can find it here:
http://tsusiatsoftware.net/jts/main.html
On Tue, Jul 2, 2013 at 10:44 AM, Bessette-Halsema, Dominique E <Dominique.Bessette@anonymised.com> wrote:
Hi
Dominique Bessette
Engineer, Software
This SF.net email is sponsored by Windows:
Build for Windows Store.
http://p.sf.net/sfu/windows-dev2dev
Geoserver-devel mailing list
you can have a look at these two place http://docs.geoserver.org/stable/en/developer/programming-guide/wps-services/implementing.html http://suite.opengeo.org/docs/processing/wpsjava/index.html for a base code.
Ing. Francesco Bartoli
CTO & Owner
GeoBeyond Srl
Via M. Augusta 68
02040 - Vacone (RI) - Italy
http://www.geobeyond.it
Mob: +39 333 2997173
Twitter: twitter.com/geobeyond
SkypeId: francesco_bartoli
Il giorno 02/lug/2013, alle ore 19:44, Bessette-Halsema, Dominique E ha scritto:
Hi
Dominique Bessette
Engineer, Software
http://p.sf.net/sfu/windows-dev2dev_______________________________________________
On Tue, Jul 2, 2013 at 7:44 PM, Bessette-Halsema, Dominique E <
Hi ****
Part of it is in the WPS module, the rest is in GeoTools in the process-*
modules,
for example, JTS:intersection is coming from an annotated set of static
methods (since
these are really one liners):
https://github.com/geotools/geotools/tree/master/modules/unsupported/process-geometry/src/main/java/org/geotools/process/geometry
Ing. Andrea Aime
@geowolf
Technical Lead
Via Poggio alle Viti 1187
mob: +39 339 8844549
Just a note that the “JTS” prefix was changed to “geo” in 2.3 although the JTS prefix is still usable as long as the DeprecatedProcessFactory is enabled.
https://github.com/geoserver/geoserver/blob/master/src/extension/wps/wps-core/src/main/java/org/geoserver/wps/DeprecatedProcessFactory.java
On Wed, Jul 3, 2013 at 2:04 AM, Andrea Aime <andrea.aime@anonymised.com> wrote:
On Tue, Jul 2, 2013 at 7:44 PM, Bessette-Halsema, Dominique E <Dominique.Bessette@anonymised.com> wrote:
Justin Deoliveira
OpenGeo - http://opengeo.org
Hi
Part of it is in the WPS module, the rest is in GeoTools in the process-* modules,
for example, JTS:intersection is coming from an annotated set of static methods (since
Ing. Andrea Aime
@geowolf
Technical Lead
