Hi Ian,
I have fixed it.
You probably need to do a rebase.
Daniele
On Tue, May 18, 2021 at 10:31 AM Daniele Romagnoli <daniele.romagnoli@anonymised.com> wrote:
Hi Ian,
I’m checking right now.
Daniele
On Tue, May 18, 2021 at 10:25 AM Ian Turton <ijturton@anonymised.com3…> wrote:
I’m seeing my CI tests fail (https://github.com/geoserver/geoserver/pull/5059/checks?check_run_id=26081848070 with
2021-05-18T08:04:14.9943458Z 08:04:14,993 [ERROR] testDownloadEstimatorWriteLimitsRaster(org.geoserver.wps.gs.download.DownloadProcessTest) Time elapsed: 0.076 s <<< FAILURE!
2021-05-18T08:04:14.9946962Z org.junit.ComparisonFailure: expected:<…ocessException: java[.io.IOException: Download Exceeded the maximum HARD allowed size!: java.io.IOException: Download Exceeded the maximum HARD allowed siz]e!> but was:<…ocessException: java[x.imageio.IIOException: I/O error writing TIFF file!: javax.imageio.IIOException: I/O error writing TIFF fil]e!>
2021-05-18T08:04:14.9951369Z at org.geoserver.wps.gs.download.DownloadProcessTest.testDownloadEstimatorWriteLimitsRaster(DownloadProcessTest.java:2134)
2021-05-18T08:04:14.9953981Z
2021-05-18T08:04:14.9955940Z 08:04:14,994 [ERROR] testDownloadEstimatorWriteLimitsScaledRaster(org.geoserver.wps.gs.download.DownloadProcessTest) Time elapsed: 0.05 s <<< FAILURE!
2021-05-18T08:04:14.9959548Z org.junit.ComparisonFailure: expected:<…ocessException: java[.io.IOException: Download Exceeded the maximum HARD allowed size!: java.io.IOException: Download Exceeded the maximum HARD allowed siz]e!> but was:<…ocessException: java[x.imageio.IIOException: I/O error writing TIFF file!: javax.imageio.IIOException: I/O error writing TIFF fil]e!>
2021-05-18T08:04:14.9965335Z at org.geoserver.wps.gs.download.DownloadProcessTest.testDownloadEstimatorWriteLimitsScaledRaster(DownloadProcessTest.java:2223)
Which I’m pretty sure I haven’t caused.
Does anyone know what’s happening in there?
Ian
Ian Turton
Geoserver-devel mailing list
Daniele Romagnoli
GeoServer Professional Services from the experts! Visit http://goo.gl/it488V for more information.
Ing. Daniele Romagnoli
Senior Software Engineer
Via di Montramito 3/A
This email is intended only for the person or entity to which it is addressed and may contain information that is privileged, confidential or otherwise protected from disclosure. We remind that - as provided by European Regulation 2016/679 “GDPR” - copying, dissemination or use of this e-mail or the information herein by anyone other than the intended recipient is prohibited. If you have received this email by mistake, please notify us immediately by telephone or e-mail.
Daniele Romagnoli
