Hi Gao:
The number one tip is to join forces with someone already doing it
You will find the geoserver-devel list intersting (they are starting to
provide support for the "open web" part of the WPS. Their email list
archive contains contacts for people working on this over the last year;
in addition to talks with the "FROGS" framework (which is specifically
focused on WPS).
As for tips;
1. produces the WPS just in terms of pure Java interface and so on, with
a couple implementations - just to make sure you have the concepts correct
2. look into the GeoServer dispatch system as documentation is made
available over the next couple weeks (you can set it up to take care of
both the request and response side of WPS)
3. look into the XML binding documentation in the GeoTools library (if
your WPS is going to be working with large volumes of data in an xml format)
Jody
Jody:
I want to implement WPS( Web Processing Service ) specification of OGC in Java language.
The reference is the python project pyWPS http://pywps.wald.intevation.org
I learn that you are also in the maillist of osgeo and have made a great many contribution for udig
I wanna get some tips from you on how to start this project to implement WPS in Java.
Thanks a lot.Gao\_Ang gao\_miao@anonymised\.com 2007\-02\-04
