Ciao Craig,
I have cc'ed Andrea and Jody as I don't seem to have privileges to
give you commit rights.
As I mentioned you can move on with PR anyway meanwhile.
Simone Giannecchini
Visit http://goo.gl/it488V for more information.
Ing. Simone Giannecchini
@simogeo
Founder/Director
Via di Montramito 3/A
mob: +39 333 8128928
nel/i file/s allegato/i sono da considerarsi strettamente riservate.
Il loro utilizzo è consentito esclusivamente al destinatario del
messaggio, per le finalità indicate nel messaggio stesso. Qualora
riceviate questo messaggio senza esserne il destinatario, Vi preghiamo
cortesemente di darcene notizia via e-mail e di procedere alla
distruzione del messaggio stesso, cancellandolo dal Vostro sistema.
Conservare il messaggio stesso, divulgarlo anche in parte,
distribuirlo ad altri soggetti, copiarlo, od utilizzarlo per finalità
diverse, costituisce comportamento contrario ai principi dettati dal
D.Lgs. 196/2003.
The information in this message and/or attachments, is intended solely
for the attention and use of the named addressee(s) and may be
confidential or proprietary in nature or covered by the provisions of
privacy act (Legislative Decree June, 30 2003, no.196 - Italy's New
Data Protection Code).Any use not in accord with its purpose, any
disclosure, reproduction, copying, distribution, or either
dissemination, either whole or partial, is strictly forbidden except
previous formal approval of the named addressee(s). If you are not the
intended recipient, please contact immediately the sender by
telephone, fax or e-mail and delete the information in this message
that has been received in error. The sender does not give any warranty
or accept liability as the content, accuracy or completeness of sent
messages and accepts no responsibility for changes made after they
were sent or for other risks which arise as a result of e-mail
transmission, viruses, etc.
On Wed, Mar 29, 2017 at 12:19 PM, Simone Giannecchini
<simone.giannecchini@anonymised.com> wrote:
Ciao Craig,
I would start with a PR against master GeoServer for which you do not
need commit rights.
I'll check with the others about giving you commit access.
Simone Giannecchini
@simogeo
Founder/Director
D.Lgs. 196/2003.
On Wed, Mar 29, 2017 at 4:16 AM, Craig Jones <Craig.Jones@anonymised.com> wrote:
Thanks Simone,
Given you are on the PSC I'm assuming that I have approval to add the
plugin.
I work for the Australian Ocean Data Network at the Integrated Marine
Observing System and we have previously filled out a corporate
contributor assignment agreement which has been forwarded to info@anonymised.com3...
My github username is: jonescc
Could someone give me the access I need to add the plugin to the
community modules.
Craig Jones
On 29/03/17 04:31, Simone Giannecchini wrote:
Dear Craig,
I would think that this could be a useful community module to have.
Same goes for your feedback.
The procedure to follow is here (it should be pretty relaxed):
http://docs.geoserver.org/stable/en/developer/policies/community-modules.html#creating-a-community-module
Simone Giannecchini
@simogeo
Founder/Director
D.Lgs. 196/2003.
On Tue, Mar 28, 2017 at 8:33 AM, Craig Jones <Craig.Jones@anonymised.com> wrote:
Hi All,
We've developed a geoserver plugin we use to store WPS output artifacts
on AWS S3 and I'm wondering if this may be considered useful by other
members of the community/whether it could be included as a community plugin.
The source code for the plugin can be found at
https://github.com/aodn/geoserver/tree/2.8.4-imos/src/community/wps-s3-artifacts
The plugin implements the ProcessArtifactsStore interface which looked
like it was provided for this purpose.
With this plugin installed, temporary resources are sourced from a local
file system store and process outputs are streamed to s3.
If this sounds useful I'm happy to provide any other details required
and some feedback on issues I encountered using ProcessArtifactsStore.
Craig Jones
Integrated Marine Observing system
University of Tasmania Electronic Communications Policy (December, 2014).
This email is confidential, and is for the intended recipient only. Access, disclosure, copying, distribution, or reliance on any of it by anyone outside the intended recipient organisation is prohibited and may be a criminal offence. Please delete if obtained in error and email confirmation to the sender. The views expressed in this email are not necessarily the views of the University of Tasmania, unless clearly intended otherwise.
Check out the vibrant tech community on one of the world's most
Geoserver-devel mailing list
