[Geoserver-devel] Writing a GSIP proposal on Geoserver WIKI
I’m trying to upload a new GSIP proposal on Geoserver Wiki for voting but seems like special access is needed, so I’m wondering how can I send the new proposal file?
Github account: @fernandor777
Fernando Mino
GeoServer Professional Services from the experts! Visit http://goo.gl/it488V for more information.
Fernando Mino
Software Engineer
Via di Montramito 3/A
This email is intended only for the person or entity to which it is addressed and may contain information that is privileged, confidential or otherwise protected from disclosure. We remind that - as provided by European Regulation 2016/679 “GDPR” - copying, dissemination or use of this e-mail or the information herein by anyone other than the intended recipient is prohibited. If you have received this email by mistake, please notify us immediately by telephone or e-mail.
Hi Fernando,
I think the easiest thing is to make you a committer?
Can you list the GS PRs that you have made that got merged?
Regards, Andrea Aime == GeoServer Professional Services from the experts! Visit http://goo.gl/it488V for more information. == Ing. Andrea Aime @geowolf Technical Lead GeoSolutions S.A.S. Via di Montramito 3/A 55054 Massarosa (LU) phone: +39 0584 962313 fax: +39 0584 1660272 mob: +39 339 8844549 http://www.geo-solutions.it http://twitter.com/geosolutions_it ------------------------------------------------------- Con riferimento alla normativa sul trattamento dei dati personali (Reg. UE 2016/679 - Regolamento generale sulla protezione dei dati “GDPR”), si precisa che ogni circostanza inerente alla presente email (il suo contenuto, gli eventuali allegati, etc.) è un dato la cui conoscenza è riservata al/i solo/i destinatario/i indicati dallo scrivente. Se il messaggio Le è giunto per errore, è tenuta/o a cancellarlo, ogni altra operazione è illecita. Le sarei comunque grato se potesse darmene notizia. This email is intended only for the person or entity to which it is addressed and may contain information that is privileged, confidential or otherwise protected from disclosure. We remind that - as provided by European Regulation 2016/679 “GDPR” - copying, dissemination or use of this e-mail or the information herein by anyone other than the intended recipient is prohibited. If you have received this email by mistake, please notify us immediately by telephone or e-mail.
Hi Andrea, thank you for your answer.
Of course, here a list of my merged Geoserver PRs at this date:
[GEOS-8645] NamespaceSupport for WPS XSDParserDelegate default handler
https://github.com/geoserver/geoserver/pull/2854
[GEOT-6035] Expression in channel name, SLD raster
https://github.com/geoserver/geoserver/pull/2923
Openlayers3 Freemarker template parameters fix
https://github.com/geoserver/geoserver/pull/2949
QoS community module
https://github.com/geoserver/geoserver/pull/3064
[GEOS-8909] Layer/LayerGroup Name order ASC on WMS 1.1.1 GetCapabilitiesTransformer
https://github.com/geoserver/geoserver/pull/3070
[GEOS-8799] NULL namespace prefixes used in AppSchema WFS GetFeature responses
https://github.com/geoserver/geoserver/pull/3072
[GEOS-8918] [GEOS-8919] Relax existing constraints on complex feature layer names
https://github.com/geoserver/geoserver/pull/3092
[GEOS-7636] GetLegendGraphic online resource is ignored on rasters
https://github.com/geoserver/geoserver/pull/3096
Wfs3 Tiling Scheme detail endpoint
https://github.com/geoserver/geoserver/pull/3131
Fix for WFS 3 MapBox response on /items breaking georeferencing
https://github.com/geoserver/geoserver/pull/3141
[GEOS-8935] Complex features coordinates formatting fix
https://github.com/geoserver/geoserver/pull/3151
Wfs3 tiling scheme description double format locale
https://github.com/geoserver/geoserver/pull/3152
[GEOS-8972] GS-GWC web GUI sets wrong EPSG:4326 coordinate axis order for topLeftCorner when saving a GridSet fix
https://github.com/geoserver/geoserver/pull/3176
[GEOS-8978] Removing gml:id from GML 3.1 geometry encoding
https://github.com/geoserver/geoserver/pull/3184
WFS3 vtp improvements
https://github.com/geoserver/geoserver/pull/3189
[GEOS-9013] Delegate filter execution matching multiple same-xpath feature chained attribute names to database: Integration test
https://github.com/geoserver/geoserver/pull/3239
[GEOS-9033] Allow configuring services on a per layer basis
https://github.com/geoserver/geoserver/pull/3260
[GEOS-9088] Appschema OR performance improvement on postgresql
https://github.com/geoserver/geoserver/pull/3313
[GEOS-8762] Fix Monitor asynchronous post processing does not play well with security
https://github.com/geoserver/geoserver/pull/3362
[GEOS-9131] App-schema multiple sortBy support on SQL testing
https://github.com/geoserver/geoserver/pull/3377
Added App-Schema Solr Indexes documentation.
https://github.com/geoserver/geoserver/pull/3409
[GEOS-9163] Added ‘https://’ protocol support for default Data Store Edit Panel and URLModel class
https://github.com/geoserver/geoserver/pull/3411
Add schema.cache.dir system property usage to user manual
https://github.com/geoserver/geoserver/pull/3412
Add to developer manual a modified google-java-format version plugin option.
https://github.com/geoserver/geoserver/pull/3413
[GEOS-9165] App-schema indexes integration test for fix solr query row limit
https://github.com/geoserver/geoserver/pull/3415
[GEOS-9132] Style Validation fix for i18N.
https://github.com/geoserver/geoserver/pull/3430
[GEOS-9183] Fix for Solr circular Spring Bean reference exception
https://github.com/geoserver/geoserver/pull/3448
Fix for LDAP modules testing with Apache Directory embedded server.
https://github.com/geoserver/geoserver/pull/3480
[GEOS-9199] Hierarchical LDAP Groups Support
https://github.com/geoserver/geoserver/pull/3487
[GEOS-9209] Enhance StyleInfo with MetadataMap on Catalog object and Rest entpoint.
https://github.com/geoserver/geoserver/pull/3489
[GEOS-9218] Parameter Extractor plugin prevents the Monitor plugin to log requests
https://github.com/geoserver/geoserver/pull/3502
[GEOS-9243] Upgrade Jetty to 9.4.18.v20190429 version
https://github.com/geoserver/geoserver/pull/3535
[GEOS-9240] Add App-Schema MongoDb PropertyIsNull filter testing.
https://github.com/geoserver/geoserver/pull/3560
[GEOS-9241] Enhance mongodb schema generation.
https://github.com/geoserver/geoserver/pull/3561
[GEOS-9268] Make MongoDB App-Schema schema rebuilder endpoints only rebuild schemas present in mappings
https://github.com/geoserver/geoserver/pull/3613
[GEOS-9271] NullPointerException on WFS ComplexGeoJsonWriter Link check
https://github.com/geoserver/geoserver/pull/3616
[GEOS-9288] Azure Blobstore shows values instead of parameter names if ALLOW_ENV_PARAMETRIZATION is active
https://github.com/geoserver/geoserver/pull/3667
Fernando Mino
Double checking - we have “Restrict edits to collaborators only” turned on: https://help.github.com/en/articles/changing-access-permissions-for-wikis
While I would like to be more welcoming, after confluence wiki I do not want to clean up vandalism…
Jody Garnett
Yep, agreed, it was a mess best not repeating
