The use case is to generate getCapabilities resposnes using Apache Velocity templates, to give a greater degree of control over the formatting and contents of the getCapabilities. We have a starting template prepared and filling it in seems straight forward enough, but I'm just having trouble gaining access to the WMS object.
David Marks
From: andrea.aime@anonymised.com <andrea.aime@anonymised.com> on behalf of Andrea Aime <andrea.aime@anonymised.com>
Sent: Sunday, December 28, 2014 3:53 AM
To: Marks, David
Cc: Geoserver-devel
Subject: Re: [Geoserver-devel] Writing Custom getCapabilities
On Wed, Dec 24, 2014 at 9:26 PM, Marks, David <David.Marks@anonymised.com<mailto:David.Marks@anonymised.com>> wrote:
As part of an ongoing project I am attempting to provide a customized
getCapabilities response via the DispatcherCallback framework. As such, I
am creating a new Response object which overrides the write method in
order to write my own custom content. The problem I am running into,
however, is that I cannot find an efficient way to get access to the WMS
configuration details stored in the WMS class. Is there a callable method
I can use to gain access? Alternatively, is my approach (create a new
Response object that overrides "write") the wrong way to go when creating
a custom getCapabilities?
The approach is fine I believe, but it would be great to know what the use case for a different
response is, maybe it could be solved by adding some extension points to the standard
writer, like we did to allow the inspire plugin to add extended capabilities into it
Please, notice that GeoSolutions will be closed for seasonal holidays
from December the 24th to January the 6th
Ing. Andrea Aime
@geowolf
Technical Lead
Via Poggio alle Viti 1187
mob: +39 339 8844549
http://www.geo-solutions.it/>
Le informazioni contenute in questo messaggio di posta elettronica e/o nel/i file/s allegato/i sono da considerarsi strettamente riservate. Il loro utilizzo ? consentito esclusivamente al destinatario del messaggio, per le finalit? indicate nel messaggio stesso. Qualora riceviate questo messaggio senza esserne il destinatario, Vi preghiamo cortesemente di darcene notizia via e-mail e di procedere alla distruzione del messaggio stesso, cancellandolo dal Vostro sistema. Conservare il messaggio stesso, divulgarlo anche in parte, distribuirlo ad altri soggetti, copiarlo, od utilizzarlo per finalit? diverse, costituisce comportamento contrario ai principi dettati dal D.Lgs. 196/2003.
The information in this message and/or attachments, is intended solely for the attention and use of the named addressee(s) and may be confidential or proprietary in nature or covered by the provisions of privacy act (Legislative Decree June, 30 2003, no.196 - Italy's New Data Protection Code).Any use not in accord with its purpose, any disclosure, reproduction, copying, distribution, or either dissemination, either whole or partial, is strictly forbidden except previous formal approval of the named addressee(s). If you are not the intended recipient, please contact immediately the sender by telephone, fax or e-mail and delete the information in this message that has been received in error. The sender does not give any warranty or accept liability as the content, accuracy or completeness of sent messages and accepts no responsibility for changes made after they were sent or for other risks which arise as a result of e-mail transmission, viruses, etc.
