[Geoserver-devel] wrong WFS endpoints in WMS DescribeLayer response
issue a DescribeLayer request against a vector layer, results in something like:
<LayerDescription name="topp:states"
wfs="http://localhost:8080/geoserver/wfs/WfsDispatcher?&quot;
owsURL="http://localhost:8080/geoserver/wfs/WfsDispatcher?&quot;
owsType="WFS">
(note the /wfs/WfsDispatcher endpoint instead of just /wfs)
The class responsible for it actually has a comment:
DescribeLayerTransformer, line 153:
// REVISIT: not sure why we need WfsDispatcher, "wfs?" should suffice imho
owsUrl = buildURL(baseURL, "wfs/WfsDispatcher", null, URLType.SERVICE);
First question: can we get rid of /WfsDispatcher or does someone know
a reason not to?
Second question: the endpoint actually work, so does /wfs/foo and
/wfs/bar and so on. Isn't that wrong?
Gabriel
Gabriel Roldan
OpenGeo - http://opengeo.org
On Tue, Sep 20, 2011 at 11:14 PM, Gabriel Roldan <groldan@anonymised.com> wrote:
owsType="WFS">
a reason not to?
I believe it's fine to remove it. Afaik the code in that class was written back
at the time when the actual wfs dispatcher was at that URL.
I guess it migth have been made for backwards compatibility for
whoever was still
calling wfs/WfsDispatcher.
We could make the dispatcher be more strict, but maybe we need to add a flag
to re-enable the old behavior for those that cannot fix the existing
client applications?
Another worry is, do we have anything else in GeoServer linking back to the
wrong url, and thus relying on this tolerant behavior to actually work?
Ing. Andrea Aime
Tech lead
Via Poggio alle Viti 1187
fax: +39 0584 962313
http://www.youtube.com/user/GeoSolutionsIT
http://www.linkedin.com/in/andreaaime
http://twitter.com/geowolf
Well, the only mention to WfsDispatcher is
org.vfny.geoserver.servlets.Dispatcher
and it has an interesting comment:
//JD: kill this class
WfsDispatcher is gone, and neither it nor
org.vfny.geoserver.servlets.Dispatcher are mapped in web.xml anymore.
Which makes the reference to WfsDispatcher in DescribeLayer look even
more like a leftover.
whoever was still
The reason why /wfs/WfsDispatcher and /wfs/foo work is because the wfs
module's applicationContext.xml routes /wfs/* to the current
Dispatcher, so I think we're good anyways?
looks like not.
Ing. Andrea Aime
Tech lead
Gabriel Roldan
On Sat, Sep 24, 2011 at 7:55 PM, Gabriel Roldan <groldan@anonymised.com1501…> wrote:
/wfs/bar and so on. Isn’t that wrong?
whoever was still
module’s applicationContext.xml routes /wfs/* to the current
Dispatcher, so I think we’re good anyways?
looks like not.
I think I misunderstood what you proposed.
I’m ok with killing the class, I’m worried about making the dispatching
more strict and throw errors if one tries to access the wfs using
a url like wfs/WFSDispatcher.
If we want to become more strict, I’m still ok with it, provided we have
a flag to get back the more loose behavior for backwards compatibility
Ing. Andrea Aime
Tech lead
In general I would like to see us continue to support the old url… unless it simply becomes too onerous to do so. I wonder if we could fix this by tweaking the dispatcher mappings. So rather than mapping to /wfs/* we map to “wfs”, and then specifically to “/wfs/WfsDispatcher”.
I would be ok with an option to support the old behaviour… although I would rather just see us deprecate the old endpoints (emitting a warning) and then removing them in the next major release. Rationale being that I can’t imagine many people use the old endpoints (although I could be wrong) so going through the work of adding the flag, documenting it, etc… seems a lot of work for not much gain.
$0.02
On Sun, Sep 25, 2011 at 2:16 AM, Andrea Aime <andrea.aime@anonymised.com> wrote:
On Sat, Sep 24, 2011 at 7:55 PM, Gabriel Roldan <groldan@anonymised.com…> wrote:
whoever was still
looks like not.
Ing. Andrea Aime
Tech lead
All of the data generated in your IT infrastructure is seriously valuable.
Why? It contains a definitive record of application performance, security
threats, fraudulent activity, and more. Splunk takes this data and makes
sense of it. IT sense. And common sense.
http://p.sf.net/sfu/splunk-d2dcopy2
Geoserver-devel mailing list
Justin Deoliveira
On Mon, Sep 26, 2011 at 4:02 PM, Justin Deoliveira <jdeolive@anonymised.com.1501…> wrote:
+1, works for me
Ing. Andrea Aime
Tech lead
On Mon, Sep 26, 2011 at 11:11 AM, Andrea Aime
On Mon, Sep 26, 2011 at 4:02 PM, Justin Deoliveira <jdeolive@anonymised.com>
wrote:
In general I would like to see us continue to support the old url...
to "wfs", and then specifically to "/wfs/WfsDispatcher".
I would be ok with an option to support the old behaviour... although I
can't imagine many people use the old endpoints (although I could be wrong)
so going through the work of adding the flag, documenting it, etc... seems a
+1, works for me
So that would be like emitting a warning on 2.1.x if the
/wfs/WfsDispatcher endpoint is hit, but killing it on trunk?
I'm not sure if getting rid of the /wfs/* dispatcher mapping would
have any other side effect like in for virtual services or so?
Gabriel.
