[Geoserver-devel] Xalan in app-schema
[Correct list this time]
More followup from Monday's meeting:
The JDK Xalan looks to be 2.6.0. It will not compile the GMLOutputFormat stylesheet used for app-schema WFS output:
https://jira.codehaus.org/browse/GEOS-5352
xalan-2.7.0 is shipped with the app-schema plugin.
On 29/10/12 22:15, Ben.Caradoc-Davies@anonymised.com wrote:
Dropping xerces (and friends)
Justin: cleaning up the explicit deps on Xerces using the one in the JDK
Last issue: app-schema resolver. Ben?
app-schema-resolver: move validation support to test and port to new non-xerces api - BCD/RA (and Justin to send draft patch to Ben)
Other? JDOM, streaming parsers, Xalan
Ben Caradoc-Davies <Ben.Caradoc-Davies@anonymised.com>
Software Engineer
CSIRO Earth Science and Resource Engineering
Australian Resources Research Centre
Justin,
please consider pull request:
https://github.com/geoserver/geoserver/pull/54
See also: https://jira.codehaus.org/browse/GEOS-5352
In addition to app-schema pom changes, this commit makes two tiny changes in wfs to the XSLTs used by GML3OutputFormat and GML32OutputFormat to workaround a problem in the the Xalan 2.6.0 shipped with the JDK.
The fix, which was suggested by Pavel Golodoniuc, is to add brackets "()" after processing-instruction.
xalan is still used in geoxacml (community) and in the test phase of ows and wms, so there is a remaining dependency version set in the top-level pom. Until this change, xalan was included in the app-schema plugin, but now we no longer need to ship xalan with GeoServer .
Kind regards,
Ben.
Software Engineer
Nice work Ben! I will try merge/cleanup this branch later in the week / on the weekend.
On Tue, Nov 6, 2012 at 3:36 AM, Ben Caradoc-Davies <Ben.Caradoc-Davies@anonymised.com> wrote:
Justin,
The fix, which was suggested by Pavel Golodoniuc, is to add brackets “()” after processing-instruction.
Kind regards,
Ben.
More followup from Monday’s meeting:
Ben Caradoc-Davies Ben.Caradoc-Davies@anonymised.com
Software Engineer
Justin Deoliveira
OpenGeo - http://opengeo.org
Justin,
this pull request is for master and can be applied immediately. It has no dependency on the xerces cleanup. I can push it myself one you are happy with the four extra characters added to the wfs module.
Kind regards,
Ben.
on the weekend.
<Ben.Caradoc-Davies@anonymised.com <mailto:Ben.Caradoc-Davies@anonymised.com>> wrote:
    Justin,
    https://github.com/geoserver/__geoserver/pull/54
    <https://github.com/geoserver/geoserver/pull/54&gt;
    See also: https://jira.codehaus.org/__browse/GEOS-5352
    <https://jira.codehaus.org/browse/GEOS-5352&gt;
    GeoServer .
    Kind regards,
    Ben.
        GMLOutputFormat
            ------------------------------__---------
            one in the JDK
            draft patch to Ben)
    Software Engineer
Justin Deoliveira
Software Engineer
Ahh, sorry my bad :slight_smile: Sounds great to me. +1
On Tue, Nov 6, 2012 at 7:10 PM, Ben Caradoc-Davies <Ben.Caradoc-Davies@anonymised.com> wrote:
Justin,
Kind regards,
Ben.
on the weekend.
<Ben.Caradoc-Davies@anonymised.com mailto:[Ben.Caradoc-Davies@csiro.au](mailto:Ben.Caradoc-Davies@anonymised.com)> wrote:
Justin,
<https://github.com/geoserver/geoserver/pull/54>
<https://jira.codehaus.org/browse/GEOS-5352>
GeoServer .
Kind regards,
Ben.
GMLOutputFormat
one in the JDK
draft patch to Ben)
Software Engineer
Justin Deoliveira
Software Engineer
Justin Deoliveira
