had a hard time trying to get this filter correctly parsed in a geoserver
getFeature request:
<Filter><PropertyIsEqualTo><PropertyName>Gsml/member/MappedFeature/specification/GeologicUnit/age/GeologicAge/value/CGI_TermRange/upper/CGI_TermValue/value</PropertyName><Literal>TEST_VALUE</Literal></PropertyIsEqualTo></Filter>
FilterFilter should generate a compare filter with the complete path as
attribute expression, but the resulting attribute path is truncated.
Problem tracked down to be xerces. Crimson (default with JDK1.4) makes it just
well. Tried with both xerces 2.4 and latest 2.8, same results. I'm going to
avoid including xerces in cpx branch, should't be an issue as long as it is
used with a 1.4 jdk.
Gabriel Roldán (groldan@anonymised.com)
Axios Engineering (http://www.axios.es)
Tel. +34 944 41 63 84
Fax. +34 944 41 64 90
Quoting GabrielRoldán <groldan@anonymised.com>:
geoserver
getFeature request:
as
makes it just
going to
it is
Hmmmm... Xerces is actually used directly for SLDValidation. Like if
it's not on the class path sld validation won't work. If you can
validate with crimson then I guess it may be reasonable to use it.
Also is crimson the default for 1.5? Also note that you can probably
set params for the factory on which implementation to use. We do that
in the GetCaps stuff, for xalan I think. Just relying on xerces not
being in the classpath is not the best idea, it will be on for many.
Chris
This SF.Net email is sponsored by xPML, a groundbreaking scripting
language
that extends applications into web and mobile media. Attend the live
webcast
and join the prime developer group breaking into this new coding
territory!
http://sel.as-us.falkag.net/sel?cmd=lnk&kid0944&bid$1720&dat1642
Geoserver-devel mailing list
Chris Holmes
The Open Planning Project
thoughts at: http://cholmes.wordpress.com
This mail sent through IMP: https://webmail.limegroup.com/
yeah, I figured out. Looks killer, though.
found xerces is needed by struts too, so no option.
> geoserver
> getFeature request:
> as
> makes it just
> going to
> it is
Chris
> language
> webcast
> territory!
> https://lists.sourceforge.net/lists/listinfo/geoserver-devel
Chris Holmes
ok, my bad.
Actually the answer was so obvious that I didn't seen it but waked up this
morning with the answer: xerces is making multiple calls to
ContentHandler.characters (char,... ) and and crimson just one.
idiot me, will create a jira issue for our content handler correctly
iplementing characters()
> > geoserver
> > getFeature request:
>ic
>e/v
>ter
> > as
> > makes it just
> > going to
> > it is
> Chris
> > language
> > webcast
> > territory!
> > _______________________________________________
> Chris Holmes
