Hi Andrea,
thank you for the feedback, find my replies below:
On Mon, Jul 4, 2022 at 5:25 PM Andrea Aime <andrea.aime@anonymised.com…6887…> wrote:
I can understand the desire to use a more structured format rather than fiddling with escape codes when dealing with
complex view params. At the same time, there is a practical limit… let’s look at content and size of your example:
538008302,244060802,53800850522,44acv,rrp;1,0;0,7;22,1
The XML most often cited downside is verbosity, and the above is already 250 chars. URLs have a practical size limit of 2000 chars, adding a few more params in there (or other request parameters) and you’ll quickly get to the maximum… at which point you can still do the request, but it’s going to have to switch to a POST request with form-url-encoded body.
Right, I guess for complex use cases switch to POST encoding will need to be done anyway, that say, we could shorten a bit the syntax:
22,44
From 250 to 180.
Also, the idea of naming layers is at odds with OGC protocols: everything in a GetMap request is positionals, each multi-value parameter is an array of values (layers, styles, filters and so on) where the values are corresponding by position. Having one parameter breaking the well established pattern is weird, not to mention, you’ll have to maintain the positional approach for the current format.
Right, I didn’t think about the storage Java side, I guess relying on the order will help reduce the size even more:
22,44
Down to 126 chars.
Kind regards,
Nuno Oliveira
On Mon, Jul 4, 2022 at 5:20 PM Fernando Mino <fernando.mino@anonymised.com> wrote:
Hi Nuno, thanks a lot for your feedback, replying to your inputs:
Proposed XML alternative format:
The XML alternative format will include the following tags:
- : defines a layer parameters, using the same layers order as the regular view parameters format.
-1 here, I would recommend not relying on the order, but instead tying a parameter to a layer based on an XML tag, for example:
22,44
Indeed having explicit layer name makes sense, since we can have layers without parameters and using the name as identification we can set only the ones we want. The updated example:
&viewParams=538008302,244060802,53800850522,44acv,rrp;1,0;0,7;22,1
- : To be included inside the element. Defines a parameter on its nested element value, setting its parameter name using the “name” attribute.
Example:
I’m assuming that the values will then be used as-is in the downstream SQL query? In terms of XML encoding, this will follow a similar path to other XML parameters currently support in GeoServer? We will be able to escape reserved characters, the XML prefix and namespace will be optional?
- Yes the values will be used in the internal SQL query parameters.
- Yes we will use the same approach as already existing Filter KVP parsers, layers parsers.
- We will use the same escape strategy as current view parameters implementation for all the values.
- Yes, the XML prefix and namespace are optional.
Current format support and backward compatibility:
The new alternative format will be only activated when a well formed XML including the Layer and Parameter tags are provided as value for the viewParams URL parameter in the request.
If this condition criteria is not accomplished, the regular view parameter format will be used, respecting backward compatibility and regular use cases.
I would suggest adding a new parameter, viewParamsFormat to define the view parameters format explicitly, looks to me like it will be more efficient than trying each time to parsing n XML The parameter would be optional, and if not provided the default URL encoding would be used.
This makes sense and is indeed more efficient. I will add it to the plan making the viewParamsFormat parameter optional using the regular view params format as the default (allowing backward compatibility). Example to activate the XML parsing:
&viewParamsFormat=xml
Fernando Mino
Visit http://bit.ly/gs-services-us for more information.
Fernando Mino
Software Engineer
@fmy2kec
GeoSolutions Group
This email is intended only for the person or entity to which it is addressed and may contain information that is privileged, confidential or otherwise protected from disclosure. We remind that - as provided by European Regulation 2016/679 “GDPR” - copying, dissemination or use of this e-mail or the information herein by anyone other than the intended recipient is prohibited. If you have received this email by mistake, please notify us immediately by telephone or e-mail.
On Mon, Jul 4, 2022 at 4:57 AM Nuno Oliveira <nuno.oliveira@anonymised.com> wrote:
Hi Fernando,
overall looks like a good addition, but I have a couple of comments, please see them below:
On Fri, Jul 1, 2022 at 10:13 PM Fernando Mino <fernando.mino@anonymised.com> wrote:
Dear community,
This is an idea proposal to enhance GeoServer view parameters to allow an XML format with more complex values definitions without the limit on not using reserved characters as the current plain format.
Current GeoServer view params documentation:
https://docs.geoserver.org/master/en/user/data/database/sqlview.html#using-a-parametric-sql-view
Motivation:
To have the ability of sending complex values into view parameters, like comma separated sublists, semicolon and comma separated inner sub-parameters, CSV sets, JSON/XML, etc.
Right, JSON support in RDBS is becoming more and more efficient, and I can see this being handy to pass down complex JSON expressions.
22,44
Example:
Implementation hints:
Before writing the complete plan/proposal I would like to know the community feedback about this enhancement idea, but summarizing we should have:
- New KVP parser implementation for XML formatted view parameters.
- New tests checking this new implementation and checking backward compatibility.
- A new section on GeoServer documentation covering this new format.
Naturally, any feedback to this enhancement is welcome. Thanks!!!
Fernando Mino
Fernando Mino
Software Engineer
@fmy2kec
GeoSolutions Group
Geoserver-devel mailing list
Nuno Oliveira
Nuno Miguel Carvalho Oliveira
@nmcoliveira
Technical Lead / Project Manager
GeoSolutions Group
Andrea Aime
Ing. Andrea Aime
@geowolf
Technical Lead
GeoSolutions Group
mob: +39 333 8128928
Nuno Oliveira
@nmcoliveira
GeoSolutions Group
