I’m looking at an issue with parsing of some poorly formed WFS GetFeature XML responses. We’re finding a “gml:metaDataProperty” element in a WFS-1.0.0/GML-2.1.2 response. “gml:metaDataProperty” was not introduced until GML 3 so the response will not validate. This is a GeoServer generated response, but I am more concerned about the parsing for now…
An exception is being generated in org.geotools.xml.XMLSAXHandler.startElement(…) on the call to obtain the element handler for “gml.metaDataProperty”, the log entry is as follows.
org.geotools.XMLSAXHandler processException
SEVERE: Could not find element handler for http://www.opengis.net/gml : metaDataProperty as a child of FeatureCollectionType.
org.geotools.xml.handlers.ComplexElementHandler.getHandler(ComplexElementHandler.java:572)
org.geotools.xml.XMLSAXHandler.startElement(XMLSAXHandler.java:411)
org.apache.xerces…
The code that’s generating the exception is as follows:
logger.finest("This Node = " + localName + " :: " + namespaceURI);
URI uri = new URI(namespaceURI);
XMLElementHandler eh = parent.getHandler(uri,
localName, hints);
if (eh == null) {
eh = new IgnoreHandler();
logger.finest("This Node = " + eh.getClass().getName());
The issue here is that instead of a null element handler being returned an exception is being thrown and document parsing stops.
Would it make sense to wrap the getHandler(…) call in a try/catch, log the error state then let the logic fall through the use of the IngoreHandler for parsing of that element? Thoughts?
I don’t know the history of the code but this appears to be the intent of the original design.
Tom Kunicki
Software Engineer | Boundless
tkunicki@anonymised.com
917-460-7212
@boundless
On Mon, Jan 6, 2014 at 12:18 PM, Justin Deoliveira <
jdeolive@anonymised.com> wrote:
Hey Tom,
On Fri, Dec 20, 2013 at 3:37 PM, Tom Kunicki <tkunicki@anonymised.com>wrote:
generated response, but I am more concerned about the parsing for now...
This is odd... if its there then that is definitely a bug, one worth
After lots of digging it looks like there's some app-schema configuration
that's allowing GML 3 elements to sneak into the GML 2 response. But this
situation where a service produces a response that won't validate isn't as
rare as one would hope. This is a 2.1.x server instance that can't be
updated.
org.apache.xerces...
namespaceURI);
localName, hints);
if (eh == null) {
*Would it make sense to wrap the getHandler(…) call in a try/catch, log
IngoreHandler for parsing of that element? Thoughts?*
This one is tough. I am not that familiar with this code so might be off
here but from what i remember the intent of the ignore handler is to handle
elements that are valid with respect to the schema, but that we actually
don't really care about. For example there are things in gml that we don't
really represent with the geotools feature model so rather than error out
we just ignore them. This is different imo than being lax about an invalid
gml document.
In the next generation of the geotools gml parser (which was inspired by
this code) we take the stance of being explicitly lax about stuff like
this, but offer a flag to force the parser to be strict. Maybe something
like that is needed here.
A flag is a great idea, in this case maybe it should be used to enable lax
parsing as strict is the current behavior. I'll look at prior
geotools/geoserver flag usage and submit a PR.
Tom Kunicki
917-460-7212
@tomkunicki
Hey Tom,
now...
updated.
Hmmm... this is still odd. Because metaDataProperty on a feature in GML2 is
just wrong. And if GML3 output is creeping in the GML2 parser is going to
have a heap of problems.
@Ben: any thoughts here?
namespaceURI);
localName, hints);
if (eh == null) {
gml document.
Yeah, my thinking too was to leave the default behaviour as is for
backwards compatibility purposes.
Tom Kunicki
917-460-7212
@tomkunicki
*Justin Deoliveira*
Vice President, Engineering | Boundless
@j_deolive <https://twitter.com/j_deolive>
Hey,
To bring everyone up to speed with the current status. Justin and I looked into the samples our client gave us and it appears the upstream (cascaded) WFS server is a MapServer instance. So effectively we’re seeing a WFS 1.1 DescribeFeature call in the xsi:schemaLocation attribute in a MapServer WFS 1.0 GetFeature response. I incorrectly stated that I thought there was an issue with GeoServer’s app-schema response based on information I had.
There still needs to be some loosening in the GeoTools GML parser to become a little more resilient in the presence of poorly formed responses.
Tom Kunicki
917-460-7212
@boundless
On Mon, Jan 6, 2014 at 12:43 PM, Tom Kunicki <tkunicki@anonymised.com.3839…> wrote:
Hmmm… this is still odd. Because metaDataProperty on a feature in GML2 is just wrong. And if GML3 output is creeping in the GML2 parser is going to have a heap of problems.
Yeah, my thinking too was to leave the default behaviour as is for backwards compatibility purposes.
Justin Deoliveira
@j_deolive
On Mon, Jan 6, 2014 at 12:18 PM, Justin Deoliveira <jdeolive@anonymised.com9…> wrote:
Hey Tom,
After lots of digging it looks like there’s some app-schema configuration that’s allowing GML 3 elements to sneak into the GML 2 response. But this situation where a service produces a response that won’t validate isn’t as rare as one would hope. This is a 2.1.x server instance that can’t be updated.
On Fri, Dec 20, 2013 at 3:37 PM, Tom Kunicki <tkunicki@anonymised.com> wrote:
This is odd… if its there then that is definitely a bug, one worth
A flag is a great idea, in this case maybe it should be used to enable lax parsing as strict is the current behavior. I’ll look at prior geotools/geoserver flag usage and submit a PR.
org.apache.xerces…
localName, hints);
if (eh == null) {
This one is tough. I am not that familiar with this code so might be off here but from what i remember the intent of the ignore handler is to handle elements that are valid with respect to the schema, but that we actually don’t really care about. For example there are things in gml that we don’t really represent with the geotools feature model so rather than error out we just ignore them. This is different imo than being lax about an invalid gml document.
In the next generation of the geotools gml parser (which was inspired by this code) we take the stance of being explicitly lax about stuff like this, but offer a flag to force the parser to be strict. Maybe something like that is needed here.
Tom Kunicki
917-460-7212
@tomkunicki
Ouch!
That could work if you have
outputFormat="text/xml; subtype=gml/2.1.2"
to get a GML2 application schema in the MapServer WFS 1.1 DescribeFeature response. Legal but not moral!
Kind regards,
Ben.
Ben Caradoc-Davies <Ben.Caradoc-Davies@anonymised.com>
Software Engineer
CSIRO Earth Science and Resource Engineering
Australian Resources Research Centre
