[Geoserver-devel] xslt module recap
wanted to recap a bit the XSLT module basics before starting to code it.
So, as we said in precedence, XSLT will be a WFS output format generator like
the ogr module.
The basic needs are to have server wide output formats generated like that
(which would be thus independent of the GML contents being transformed),
community feedback demanded it to have a per layer too, which makes sense
since transformations might need to pick on specific attributes as well.
Configuration wise, we'll store the xml config files in $DATA_DIR/wfs/xslt,
using an approach similar to the one of the styles, that is, two files for
each transform:
- myTransform.xslt
- myTransform.xml
where myTransform.xml will be a XStream dump of a TransformationInfo object
(which looks like a CatalogInfo object in case in the future we want
to make this core).
The xml file will contain:
<TransformationInfo>
  <sourceFormat>text/xml; subtype=gml/2.1.2</sourceFormat>
  <outputFormat>text/plain</outputFormat>
  <fileExtension>txt</fileExtension>
  <fileName>myTransform.xslt</fileName>
</TransformationInfo>
whereas a transformation specific to a feature type will look like:
  <featureType>
     <id>FeatureTypeInfoImpl-47cc14ea:13942f810c2:-8000</id>
in order to link to the layer in a way that's layer rename safe.
REST wise we'll allocate the transformations in:
/rest/wfs/transformations/<myTransformation>
Justin suggested we should also have transformations under a feature type
if they are related to it:
/rest/workspaces/.../featureTypes/<featureType>/<myTransformation>
I can go for this as well, although I'm a bit worried about performance,
to do this operation we'll have to scan all configuration files in order
to determine which ones are related to a particular layer, if any
I also guess that under this setup the layer specific transformations would
not appear at the top level... or not?
Perf wise we could keep a cache of the config files in memory, and just
scan the file system to determine which xml files are there, so that
we avoid reloading them often.
All good?
Our support, Your Success! Visit http://opensdi.geo-solutions.it for
more information.
Ing. Andrea Aime
@geowolf
Technical Lead
Via Poggio alle Viti 1187
mob: +39 339 8844549
Sounds good. Just a note on naming consistency on transform vs transformation in the class names, filenames, rest api, etc… i would vote for the shorter :slight_smile:
On Thu, Oct 25, 2012 at 9:20 AM, Andrea Aime <andrea.aime@anonymised.com> wrote:
the ogr module.
Configuration wise, we’ll store the xml config files in $DATA_DIR/wfs/xslt,
each transform:
  • myTransform.xslt
  • myTransform.xml
to make this core).
text/xml; subtype=gml/2.1.2 text/plain txt myTransform.xslt
text/xml; subtype=gml/2.1.2 text/plain txt myTransform.xslt FeatureTypeInfoImpl-47cc14ea:13942f810c2:-8000
in order to link to the layer in a way that’s layer rename safe.
REST wise we’ll allocate the transformations in:
/rest/workspaces/…/featureTypes//
I can go for this as well, although I’m a bit worried about performance,
to do this operation we’ll have to scan all configuration files in order
not appear at the top level… or not?
All good?
more information.
Ing. Andrea Aime
@geowolf
Technical Lead
Everyone hates slow websites. So do we.
Make your web apps faster with AppDynamics
Download AppDynamics Lite for free today:
http://p.sf.net/sfu/appdyn_sfd2d_oct
Geoserver-devel mailing list
Justin Deoliveira
OpenGeo - http://opengeo.org
And to clarify these (and my previous feedback) are suggestions, even though they came off as demands previously. I have no strong argument if they don’t make sense from your point view.
On Thu, Oct 25, 2012 at 6:46 PM, Justin Deoliveira <jdeolive@anonymised.com> wrote:
the ogr module.
each transform:
  • myTransform.xslt
  • myTransform.xml
to make this core).
All good?
more information.
Ing. Andrea Aime
@geowolf
Technical Lead
Justin Deoliveira
Justin Deoliveira
On Fri, Oct 26, 2012 at 1:46 AM, Justin Deoliveira <jdeolive@anonymised.com> wrote:
transformation in the class names, filenames, rest api, etc... i would vote
Yep, good idea
more information.
Ing. Andrea Aime
@geowolf
Technical Lead
