Howdee,
IT WORKS, see details below, the first hurdle has been conquerored, I need to add the other modules into the pom.xml, but in order to do this I need to firstly write their pom's then I can add it. Then comes the test to see if the MVN WAR will work. The problems we were getting with maven war (version 1.0), we need to see if those factors we ironed out by the apache boys.
So will keep you guys posted..
ps: Cannot submit my coded yet, no svn access, but as soon as it up and running you will get the scripts..
Good day
[INFO] [compiler:compile]
Compiling 167 source files to C:\projects\1.4.x\org.vfny.geoserver.main\target\classes
[INFO]
[INFO] ----------------------------------------------------------------------------
[INFO] Reactor Summary:
[INFO] GeoServer .............................................. SUCCESS [0.000s]
[INFO] Geotools Libraries ..................................... SUCCESS [1.891s]
[INFO] GeoServer Main Module .................................. SUCCESS [11.171s]
[INFO] BUILD SUCCESSFUL
[INFO] Total time: 13 seconds
[INFO] Finished at: Mon Apr 03 14:38:24 CAT 2006
[INFO] Final Memory: 5M/33M
